Who heats 100% with wood?
Discussion in 'The Wood Pile' started by fuelrod, Jan 30, 2016.
  1. Scotty Overkill
    We heat our house 100% with wood. We have the Napoleon 1900p in the kitchen and our super efficient Napoleon NZ3000 ZC fireplace in the living room.
    We still heat our water with NG and also use NG for our clothes dryer, and I do have two NG furnaces in the house but we only have them for backup in case something goes would happen to either me or the wood appliances......
  2. bear_hunter
    bear_hunter
    indiana
    100% heat and hot water with my Central 6048
  3. Gasifier
    I like those times of lazy beyond normal levels! :thumbs:
  4. fox9988
    fox9988
    NW Arkansas 72717
    100% wood heat. Electric hot water.
    Star Gazer, milleo, fuelrod and 4 others like this.
  5. Star Gazer
    Star Gazer
    Right behind you
    I use wood for 100% of my heat. No electric heaters! I do have an electric water heater (and appliances) though, and my electric bill had dropped to less than a 3rd of what it was. I average 285kwh a month vs about 1000kwh average when I had both propane and oil heat. Both the oil and propane systems were completely removed (by me)
  6. red oak
    red oak
    Not to hijack the thread, but to those of you who heat your water with wood, I'm assuming this is done with an OWB? Or is there another setup that you have?
  7. gboutdoors
    gboutdoors
    S.E. Massachusetts
    70% wood 30% propane. Jane has never wanted to feed the stove so when I am at work the heat will come on at times and hot water on demand gas unit. But my company has a propane gas devision so the cost is negligible.
  8. northwinds
    northwinds
    Wisconsin
    100% wood unless I'm gone overnight. It is nice to have backup gas furnace for the occasional getaway.
  9. Backwoods Savage
    Welcome to the forum Lone_Gun
    Good for you with 15 years off the furnace. We sold our furnace back in 1979!
  10. Backwoods Savage
    Welcome to the forum walt
    I'd like to hear more about that hot tub!
  11. CDE2020
    CDE2020
    Snohomish WA
    100% wood heat. Two stoves - one at either end of the first floor. Can't imagine any other way.
  12. Backwoods Savage
    House heated 100% with wood. Water heated with LP and food is cooked with LP and wood stove.
  13. Lone_Gun
    Lone_Gun
    Washington
    Thanks Backwoods! Our furnace needs to be replaced, but I'd much rather burn wood. I enjoy the processing, the gathering, the whole lot! And as you well know, there's nothing like wood heat!
  14. MN woodcutter
    MN woodcutter
    MN
    Probably 90% wood heat. The natural gas furnace only kicks on during the coldest of nights and in MN that's pretty cold.
  15. rebelduckman
    rebelduckman
    Pulaski,Ms
  16. capetownkg
    capetownkg
    southern, MD
    100% here in southern md for me. Unit only kicks in if we are gone for more then a day. Take a look at this chart from my electric company. Probably think I am stealing power.
    Now granted it was much colder last december but still 78% less is great
  17. yooperdave
    Red, mine is done with an OWB through the use of a "side arm assembly.
    It consists of a tube in a tube. The bottom of the side arm receives from the OWB and is forced (by means of the circ pump) though the side arm exit at the top to continue on its destination of the water coil in the forced air furnace plenum, then back to the OWB.
    The bottom of the side arm is plumbed into the drain valve of the water tank and the top of the side arm enters back into the water tank where the old anode was located. The domestic water is circulated only by means of convection. That all! You would think (I did) that this would never keep up with hot water demand, but I have never been without hot water in all the years I have used OWBs!
  18. yooperdave
    Big OWB! Small woodpile.
  19. bear_hunter
    bear_hunter
    indiana
    LOL. I have more wood behind the barn and a bunch of ash trees and a giant hickory layed down in a woods about 2 miles from me.
  20. RParrotte
    RParrotte
    Saranac, NY
    The Woodchuck runs 100% of the time when I'm home. I only get about 4-5 hour burn out of it. I have a propane monitor that I leave on 60* when I'm not home.
