Who has insulation in their basement rafters?
Discussion in 'The Wood Pile' started by CHeath, Feb 2, 2018.
  1. ironpony
    ironpony
    Mid Ohio
    3/4 inch screws, unsnap the snap edge and remove screws if need be, most of the time if you unsnap the edge you can get to what you need to or to run wire above soffit. unsnapped it creates about a 11 inch opening. also being it is in a space with a constant temp, it is less critical to allow it to float. A few degrees it does not move much as opposed to outside temp changes of 50 degrees.
    Maina, Chaz, Eric VW and 1 other person like this.
  2. Eric VW
    Maina, coutufr, mat60 and 4 others like this.
  3. Canadian border VT
    Now he gives us this great idea:headbang:
    Maina, mat60, Eric VW and 2 others like this.
  4. brenndatomu
    Its not too late for me :D
    Maina, mat60, Eric VW and 1 other person like this.
  5. Canadian border VT
    Me either, Sheetrocked right now, but that can change..
  6. brenndatomu
    I'm still finishing the walls...hadn't decided what to do with the ceiling yet.
    Is that vinyl or metal ironpony ?
    Maina, mat60 and Eric VW like this.
  7. Eric VW
    Ima say vinyl. Metal wouldn’t perform favorably when loosening and “hinging” out of the way.
    :yes:
    My opinion of course... we’ve seen ironpony pull off some serious chit! :salute:
  8. brenndatomu
    Yeah, may be. I'd lean toward metal for the bit of fire stop it could add
  9. Eric VW
    In your and my case with the heater in the basement, I’d be prone to warn that that super light gauge (in the case of it being metal) stuff would nearly evaporate like a pop can in a fire pit during the worst case scenario. :handshake:
    Maina, mat60 and brenndatomu like this.
  10. brenndatomu
    Yep, still better than vinyl.
    That brings up a good point...when I put my Yukon furnace in back in 2012, I sprayed all the wood in the furnace room with "No Burn" flame retardant spray No-Burn, Inc. Fire Retardant, Intumescent Paint, Spray-Applied Specialty Coatings Manufacturer and Supplier
    To test it I sprayed a scrap piece of 2x4 with it, then went outside to torch it...it eventually kinda "burnt"...with the torch held on it, but as soon as you pulled the flame away, it went out. :yes:
  11. Eric VW
    Agreed....:yes:
    Maina likes this.
  12. ironpony
    ironpony
    Mid Ohio
    Vinyl, aluminum would defeat the purpose of being easily opened.
    huskihl, brenndatomu and Eric VW like this.
  13. wood and coal burner
    Quakertown,PA
    I have a 1840's vintage farmhouse and no insulation in the basement which makes it easy to see when I leave the lights on through the cracks in the floor.
    Buffalo Plaid and Eric VW like this.
