Which way to face new stove location installation?
Discussion in 'Modern EPA Stoves and Fireplaces' started by wildwest, Sep 8, 2023.
  1. Hoytman
    Hoytman
    OH
    I would advise against raising the hearth. Raise the stove, instead. A raised hearth could prevent you or the next homeowner from removing existing stove to install another stove down the road.
    However, I agree with not wanting to bend and/or squat.
    EDIT:
    When I made this post I had somehow missed the part about getting the higher base and using bricks.
  2. Hoytman
    Hoytman
    OH
    Just in case the angled thimble was still a consideration…
    I would also be willing to wager that the links I provided to an angled thimble would more than satisfy needing 3ft of horizontal stove pipe…if that’s still a consideration.
    They’re sort of ugly to me, but I don’t think their performance enhancements can be argued against with a thimble install…as it’s as near a straight off the stove an up through the roof install as one can attain with a thimble.
  3. brenndatomu
    You talking stovepipe, or chimney pipe? Never seen stovepipe that screws together.
    And to Hoytman s point...I agree with maximizing 45* angles, and minimizing 90's/horizontal pipe whenever possible, just not sure if BK is cool with that, or if they would still insist on 3' initial rise...
  4. wildwest
    Yes, like Hoytman mentioned, also the BK manual recommends two 45's and not a straight 90* and what we'll use. I thought it was clearer to say 90* instead of two 45's to make a 90*, sorry.
    B, I don't know the difference between those 2 pipes, it will be double wall 8" from out dealer which I assume the ends will be crimped for connections. We used double wall DuraVent PelletPro (?) on our pellet stove, it has wide threads to connect the straight lengths and zero play, and thought I better avoid it for the 1/2" per foot rise.
  5. Hoytman
    Hoytman
    OH
    Are you talking about 3ft of vertical rise off if the stove before a horizontal? I would agree.
    However, we all know straight off the stove vertical is fine…and I personally can’t see anything wrong with a shorter amount of vertical going into a 30degree thimble…heck it’s near vertical anyway and those thimbles have been available for quite a few years now that I feel BK would have already addressed them if there was a problem…they likely would have already specified what to use or not use with them. Not only are they better than using a 90, as well as using 45’s, but they further eliminate the horizontal run that even a 45 can do, allowing for much closer-to-wall installs…which I’m sure most understand.
    Myself, I consider the angled wall thimble to as close replicate a totally vertical install that I myself wouldn’t be concerned with draft, or not installing according to that “3ft straight before bend” written in the BK manual. What others think and decide is up to them.
    You could be right though. BK might still insist on 3 ft of vertical…if for no other reason but legal protection. Of course, making assumptions is just that…making assumptions.:cool:
  6. Hoytman
    Hoytman
    OH
    At any rate I’m sure you’ll be fine however you get it installed, else you wouldn’t be here as a moderator.:D
  7. wildwest
    Thank you H, that idea was to put the thimble sideways for the horizontal run into the porch, I kind of settled on the 45* to go perpendicular through a straight thimble instead. We'll see, will be a few more weekends to get installation going :)
    Backwoods Savage and brenndatomu like this.
  8. wildwest
    You'd be surprised, most moderating doesn't involve expertice and I am by no means expert. Thus this thread getting help from you all are so generously sharing :)
  9. wildwest
    :picard:
    Uncrated the stove last night, I ordered the 10.5" H pedestal, received 8" legs. Called today, 3 people work there, Owner, his daughter, and her husband. Son in law who took the firmed up the order (WWW ordered it on Friday but didn't know what options I wanted so owner said he'd hold it til I called).
    I called that monday (May 8), son in law took my order. Today he doesn't remember our phone call though he assured me then he'd take care of it. Today he wants $440 to order the pedestal, but again assured me he'd take care of it.
    Let's see what happens. He's supposed to call back with lead time on the ped.
    Idk guys, if getting the ped is 4-6 months out like the stove was, we can't wait that long and will have to use the legs. If that happens the stove is SO heavy compared to others I don't see switching them after it's installed.
  10. Hoytman
    Hoytman
    OH
    Big RED flags!!
    Had a hard time following your post, but people need to make things right. Stop dealing with SIL if he can’t remember his own name.
    Above all, be polite, but stand firm and demand the service you expect, or else withhold funds. Call credit card company if you have to and have them intervene. Don’t be afraid to shop another dealer.
  11. brenndatomu
    So you paid to have a pedestal, and now they want another $44o to order something that they screwed up? Yeah, I don't think so Jim...
  12. wildwest
    Yes, I was. Asked him how many men work there and he stated him and the owner, and that the owner was on vacation after I already said it was YOU that I spoke to. There is no other BK dealer within a hundred miles and we paid with a check, didn't bother to check my specs against the order.
    Not quite B, I called and concreted the order with blower and pedestal, WWW went down a day or two later and paid with a check.
    The other issue is, we'll have to see if BK has peds in stock or not, we can't wait another several months and will have to make do with the legs. They charged me for legs, $220. Now they want to charge me for the ped, $440. SIL said he'd make me whole, but not sure on this after the order....
    Last, not worth making a big stink over $220 in an isolated town. Too many other things involved in being a business in town too.
    I have a feeling the owner will make things right for us, except if the peds are too far out time wise we'll have to use the legs anyway.
  13. Hoytman
    Hoytman
    OH
    Don’t worry about raising a stink. Not saying you should raise a stink, but to be fair, apparently their not worried about it either. Just try to get them to work with you.
    If the stove was ordered with a pedestal, then that is what you should get…especially if you already paid for it.
    If they only had legs, and you paid for those, then tell them to consider that as half down payment for the pedestal and that when pedestal arrives you’ll pay the difference and return the legs.
    That’s the least they should do for your troubles. You could always opt to keep the legs having paid for both. Later if you sold it the price would be higher because you have both.
    Hold the phone!!!
    Wait just a cotton pick’n minute!!
    Isn’t that pedestal supposed to have an ash drawer in it? If so, then that means the inside of the stove is also different, having an ash dump, from that of just a stove with legs…which has no ash pan.
  14. wildwest
    Phew! I just went and checked, it appears they are universal? (sorry for the weird pic, I had to take the pic in pitch dark, I'll add it to this post from my phone soon after I post this).
    That is what I told the SIL I expect, either a refund or taken off the price of the ped.
    I'll try to get ahold of the owner soon. Lol if I have to leave a message with the SIL to have the FIL call me LOL!
  15. Hoytman
    Hoytman
    OH
    I was thinking of a BK King 40 and/or Princess models with the big base. Is one of those what you ordered? If so, you’re dealings with the SIL need to be dealt with of the owner pronto. Not good!
    Perhaps it’s just a case of removing some bricks to expose the ash dump, but you’ll need everything, all the parts plus the base you ordered to make the conversion…let alone possibly removing the stove while in use to swap it all out.
  16. Hoytman
    Hoytman
    OH
    I figured maybe BK would make a removable plate, but you’ll still need everything for the conversion. Your luck seems about as good as mine. If it weren’t for bad luck I wouldn’t have any.
  17. moresnow
    moresnow
    I bet a fair $ that a pipe damper will never be required. With the venting 90's you're far more likely to be adding chimney length to improve/induce draft.
    Hope you get the order/delivered product issues resolved!
  18. Hoytman
    Hoytman
    OH
    I don’t think anyone in this conversation disagrees with you about him not needing to use a damper, or needing to add additional pipe to offset the 45’s or 90’s.
    The thermostat on BK stoves, or a bi-metallic thermostat on any stove really, is remarkable at running the stove.
    Personal opinion here…
    Whether it’s used or not, always…always install a pipe damper in the stove pipe. No rule or law saying it must be used. It can be left open and with todays SootEater cleaning rods can be cleaned right through and past the damper from below.
    Whomever started this trend of not recommending to install a pipe damper should really rethink such a recommendation.
    Again, no one is saying that they are needed.
    Men I used to know, some would be over 100 years old and long since gone on to meet their maker, all of them told me to always install a pipe damper. I consider their words as words of wisdom in spite of modern stove design.
    Now some in modern times using modern stoves say they’re not needed. Indeed, that may be true with modern stove design…but that same modern stove design, unlike the better pre-epa stoves of the day that could be totally shut down if the situation arose, the modern stoves are designed to NOT be fully air tight. That is, there’s no control to fully close off secondary air and often even primary air and the air wash…which means there’s always a supply of incoming air. So in an emergency situation your only help in an emergency situation is the stove pipe damper to further slow the stove draft.
    I believe stove designers and manufacturers, as well as dealers, and anyone else promoting not needing a stove pipe damper have done a disservice to the public by removing the option of a safety device, if nothing else.
    Conversely, using a pipe damper in the wrong stove at the wrong time can also present a safety issue by helping creosote to accumulate.
    Education is the answer…informing people that the pipe damper isn’t to be feared, rather learn when and how to use it, if at all, but if nothing else leave it alone and open until an emergency arises.
    I say this all the time…
    Better to have it and not need it, than to need it and not have it.
    brenndatomu and wildwest like this.
  19. wildwest
    Thanks, we'll make it work either way :) We live in a high wind area, hurricane strength is not uncommon, so installing a damper anyway. The pre-epa stove here when we bought the place had one and was needed, TBH that pre-epa is in our fireplace now and can get spooky in high winds, we keep a close eye on it (not enough space between the stove the chimney liner for damper), - that said we've never had a functioning cat stove. There was a slammer cat stove here when we bought this home and the cat, or what was left of it was crumbles, and I don't want to take the chance that over fires fried it. It gets so bad here for extended periods of time it sucks the water up the waste watervent pipes o_O , the water in the toilet bowl goes up and slushes down :eek:, imagine what that would do to a fire. Hopefully we won't need it but I'm going to edge on the side of caution ;)
  20. wildwest
    You are describing the stove we burned for 20 years and also the one we have in the fireplace now. Yep, installing a damper whether we need it or not.
