Which way to face new stove location installation?
Discussion in 'Modern EPA Stoves and Fireplaces' started by wildwest, Sep 8, 2023.
  1. wildwest
  2. wildwest
    I'm sorry it's sideways, I took both a portrait and a landscape and they both posted like sideways.
  3. wildwest
    upload_2023-9-11_13-19-48.png .
    Better :)
    Not to scale.
    Buzz Benton likes this.
  4. wildwest
    Is there such a thing as an angled wall thimble?
    JimBear and brenndatomu like this.
  5. brenndatomu
    Never seen one...or anything other than a 90* tee/clean out...
    JimBear and wildwest like this.
  6. Hoytman
    Hoytman
    OH
    Actually, yes there is…give me a segundo…be right back…
    wildwest likes this.
  7. Hoytman
    Hoytman
    OH
  8. Hoytman
    Hoytman
    OH
    I try to be of help as much as I can. :D:handshake::dex:
    RGrant and wildwest like this.
  9. wildwest
  10. moresnow
    moresnow
    How much vertical pipe will you have from the collar up before turning? The King asks for 3 feet. BK's can be rather draft sensitive. Nothing worse than being married to an unresponsive, full on puker! Puker of smoke that is. :)
    Not sure if I understood your description?
    wildwest and brenndatomu like this.
  11. wildwest
    Oh Boy! Thank you for pointing that out, I understood 2', and right there under the diagram is an asterisk I did not see.
    Including clearance to from ceiling for the out the wall to the tee we can get to, or close to 3'. I was glad for the 2' for pipe sweeping for me (my height and arms not too high) but I CANNOT afford a lazy draft. Thanks again!
    theburtman likes this.
  12. wildwest
    Something you said Old Nate brought me to the solution, and Backwoods Savage this allows it to face the living room properly.
    3' up from stove, 90*/horizontal to porch wall beyond door swinging open, 45* still in the horizontal run to wall thimble then clean out tee. Extra 2' on the stack for the additional 45*. We require pipe braces on the roof anyway.
    Where does the damper go? The first 3' vertical ?
    brenndatomu likes this.
  13. Backwoods Savage
    Don't forget in the horizontal section there needs to be a slight raise. Code says 1/4" per foot of horizontal. I put ours at 1/2" rather than 1/4".
    wildwest, brenndatomu and theburtman like this.
  14. brenndatomu
    About how long is that horizontal run to the 45 going to be? That will affect draft more than the 45 will...but if the chimney is tall enough, it should still work...I'd use double wall stove pipe on it though...and yes, the ideal spot for the damper would be right above the stove.
  15. wildwest
    Thanks on the damper, the horizontal run is 3' to 45* and another 12" to clean out tee.
    Thanks Dennis, how do you get a rise, or, what adapters will put rise on a horizontal run?
    Backwoods Savage and brenndatomu like this.
  16. Canadian border VT
    Just because Dennis hasn’t pointed it out; a stove that’s higher requires less bending and squatting to fill.. is there room to elevate hearth?
  17. Chvymn99
    X 2 the older you get the more you’ll appreciate getting this done right off the bat…
  18. brenndatomu
    You use the slop in the fit of the pipe/fittings to just tweak it a bit, then pin it in place with 3 stainless screws
  19. wildwest
    Yes there is a bit of room that I already used. I bought the taller pedestal, and it's sitting on 2.5" roofing pavers. Previous home he built an elevated hearth and I've missed it ever since. LOL, I just did the math, this configuration including Dennis's tip for rise will use 95.5" of our 96" tall room.
    The firebox door will open right about our knees.
    Backwoods Savage and Hoytman like this.
  20. wildwest
    Tx :)
    Note to self, don't get the Duravent that threads together.
    Backwoods Savage and MikeInMa like this.
