which way should the ceiling fan spin?
Discussion in 'Everything Else (off topic)' started by jetjr, Feb 15, 2015.
  1. JoeyD
    JoeyD
    What Backwoods says for all the reasons he listed. Also a fan on the floor as far from the stove as possible blowing cool air towards the stove helps with the convection. I have one two rooms away from my stove near my stairway that will raise the temperature upstairs by at least 2 degrees.
    Backwoods Savage, wildwest and basod like this.
  2. jetjr
    jetjr
    Pa/Md line
    Now what would you guys recommend to push air to the bedrooms. They are above the stove but no air comes up. I mean the main part of the house is 70 couple usually with the bedrooms in the upper 60's which is fine for sleeping. Just wonderin.
    Stinny and wildwest like this.
  3. basod
    basod
    Mount Cheaha AL
    depends on the layout of the house and current heating/cooling systems available? Don't go cutting vents from the stove room - big no-no on codes
    Insulation above the rooms in the attic(if accessible would be the first thing to explore)
    wildwest likes this.
  4. jetjr
    jetjr
    Pa/Md line
    Yea I heard about the vents being a no no luckily as the thought had crossed my mind. The heat is electric baseboard so that is no help. The ac unit and all duct work is in the attic. Eventually I would like to add more insulation up there but can't do the blow in type because of the ac and all. The house is a typical split foyer. Stove at one end with bedrooms above. Walk into a small landing to go up or down, open area to the living dining room and kitchen opposite the stove. Basement is half open floor plan, bed room, bathroom and laundry room. I know if the house was tightened up it would help, but if a frog had wings he wouldn't bump his arse either. I plan on doing new windows, doors, sheathing and siding when $$$ allows. Figure when I pull the sheathing off I can insulate as needed.
  5. basod
    basod
    Mount Cheaha AL
    Jet I resided my entire house myself - it is a big project, but if taken in stride is rewarding. Took me 1-1/2 yrs and was less cash flow but more motivation by the end
    If the AC unit is in an area of the attic that(should be) is accessible from a panel adding insulation over the duct work could allow you to use the fan for some recirculation - really depends on where the main return is located
  6. jetjr
    jetjr
    Pa/Md line
    Return is in the hallway ceiling. The duct work is metal main with the bubble wrap stuff and the flexible lines off that. Did you resheath the house as well? Mine is that cellotex fiber type stuff. Did not realize this until after I bought the place unfortunately. :headbang: Worst part is I don't know if I want to put out that kind of money on a house I don't plan on living in the rest of my life, but hey it might help someone else too.
  7. basod
    basod
    Mount Cheaha AL
    Yes I resheathed with OSB as the substrate on my house was Jimmy Carter Board - foil backed Styrofoam. Only the corners of my Cape had 4x8 sheets of plywood - they had to come off during demo as the termite damage was extensive in a couple sides.
    It gave me the chance to fill in all the holidays - or rather the random acts of insulation from original construction in 80-81.
    If you don't plan on living in the place for a while it's probably not worth the time unless the existing siding is in terrible need of it.
    In my place 6-8ft tall by 15-20ft wide swath had been devoured by termites where all that was left was the paint and a thin bit of clapboard. I went back with Hardiboard - 50yr siding and was able to treat the exterior studs to prevent any future pests
  8. Stinny
    I'd get a couple Muffin fans (stove shops). They use next to no elec and you can try them in different locations and directions for best results. Same thing with your ceiling fan direction, with all heating sources set the same way... just try one direction for a week and take note on it's effect. Then, try the other direction. One should feel better than the other. You could try dif speeds too.
    jetjr and wildwest like this.
  9. jetjr
    jetjr
    Pa/Md line
    wife says the fan makes it feel cooler to her either way. Right now I got one regular fan in the basement going towards the stove from across the room, ceiling fan off. I had one in the hallway upstairs pushing cold air out but it was a noisy bugger. I think the one in the basement makes it feel warmer. The boys wanted me to camp out with them in the living room so that may be why too, not used to being out here.
  10. jetjr
    jetjr
    Pa/Md line
    I'm thinking the height of the fan compared to actual room/ceiling height may be a factor too.
    HDRock, Stinny and wildwest like this.
  11. wildwest
    My previous home sounded similar, the living room was 15' cathedral ceilings and the fan hung about 3' down on rods. We usually kept it on the lowest speed, blowing down in the summer for sure, but honestly in the winter be it up or down, anything above the lowest speed chilled me too. That said we did not have a floor above. Can you swing space heaters for now til you can figure it out better? I tend to be a cranky wife when chilled LOLOL.
  12. wildwest
    Our bedroom was the similar, 11' ceilings, flat not cathedral, same result, lowest speed be it blowing up or down though down in the summer helped.
  13. jetjr
    jetjr
    Pa/Md line
    House is actually still plenty warm enough. We have baseboard heat in all the rooms and don't use it. It was cold the other day and I was sitting there watching the fan spin from the heat rising up the stairwell. That's where all this came from
  14. wildwest
    :picard:I apologize, I will own up to being the cranky wife on the board :rofl: :lol:
    Stinny and jetjr like this.
  15. Stinny
    All things considered WW, I doubt if your honey has ever even thought of the term "cranky wife", much less said it... :)
  16. Brad38
    Brad38
    S. Indiana
    Question about that... How do you find the offending fan blade? I have a wobbly ceiling fan...
  17. Stinny
    Sometimes, it's easy to figure out why those fans can get out of balance...
  18. jetjr
    jetjr
    Pa/Md line
    Mine came with a balancing kit. I think most any hardware store should sell them.
    Brad38, basod and wildwest like this.
  19. basod
    basod
    Mount Cheaha AL
    The slip on clips work easy so you can move them around.
    a piece of tape with pennies works as well, just glue them down after you've found the right balance
    Brad38, Stinny and wildwest like this.
  20. HDRock
