Which is the best way to load a stove?
Discussion in 'The Wood Pile' started by Star Gazer, Jan 29, 2016.
  1. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    But apparently not too old for a good spanking:banana:
    Oldman47, 1964 262 6 and Star Gazer like this.
  2. Star Gazer
    Star Gazer
    Right behind you
  3. bushpilot
    bushpilot
    Eastern Washington
    When I lived in the Congo, we would bundle up and shiver when it was in the 60s. :fire:
  4. Backwoods Savage
    Excellent point Star Gazer. I well remember the years we wintered near Yuma, AZ. Down there if it got down to 60 (daytime), it was cold. Seems at that temperature there was always a real stiff north wind that really drove the cold into you. Worse than a still morning at 30-35, which we also experienced down there. But here at home, I love it at 60 degrees!
  5. 1964 262 6
    1964 262 6
    williamsburg, ohio
    all i know is the older i get, the colder cold feels. i can't say i like cold weather at all, but ohio is all i know.
  6. HDRock
    X2 on that ,the older i get, the colder cold feels. i can't say i like cold weather at all, but Michigan is all i know :shiver:
    Spring, summer ,fall :yes::thumbs:
  7. Wood Duck
    Wood Duck
    I load my stove both ways, but one way at a time. I never criss-cross the wood because that leaves too much air space and it would burn too fast. With my stove I can fit a split about 17 inches long into the stove east/west. If I get a piece a little too long I set it aside and cut it in half, which is just about right for north/south loading. I cut a fair bit of wood 8 or 9 inches long for north/south loading because I think it is better for quick heat in a cold stove. Long, rectangular straight pieces are great for longer burns.
  8. Horkn
    No, it's not old age, it's thinning of the blood from living in a warmer climate.
    My botherr that grew up with me in Wisconsin (normal but you can never assume nowadays) moved to Florida. We had a 73 degree Easter that he came to visit us for. Both my brother and his wife, were cold.
    Weirdos.:headbang:
    Star Gazer, 1964 262 6 and Eric VW like this.
  9. HDRock
    Not only that but I couldn't get that much wood in my stove loading criss-cross.
    My stove is square 18" so can load ether way but , I load N/S , it's easier and I can get it packed tighter, being square I can use any of my 17" splits E/W for burning down coals
  10. bushpilot
    bushpilot
    Eastern Washington
    N-S, then 2nd layer E-W to light. When it is burning well, I'll pull it all N-S. Adding wood is generally done N-S.
  11. HDRock
    Edit: I actually do cold start ,small loads ,criss-cross sometimes in shoulder season when I need small fires that start easy and don't last long
    Star Gazer likes this.
  12. firecracker_77
    firecracker_77
    IL
    I go in through the side. I guess that's EW for me. I'm still confused on this topic. I never open the front and EW is easier to load full. I get clean burns provided that I have good coals prior to loading. I get small fires going with pine 2X4's cut short and split with a hatchet.
  13. hman
    hman
    Chillicothe,Ohio
    My stove loads either way 16". I load e w when it is not real cold and burning hard,n s when it gets real cold and need more heat and using more wood.
    fox9988 and Star Gazer like this.
  14. ranger bob
    ranger bob
    Leeburn Ontario
    When do you harvest the bananas? We put on a jacket when it's 30 below zero!
    Keweenaw, Star Gazer and bobdog2o02 like this.
  15. Star Gazer
    Star Gazer
    Right behind you
    While they're still green! :D
    ranger bob likes this.
  16. ranger bob
    ranger bob
    Leeburn Ontario
    Forgive my earlier post! I have twisted sense of humor. I like east west the best and the firebox is deep enough and big enough never have to worry about rolling against the glass. It takes 22 inch pieces either way with room to spare but burns a lot better and longer when east west. I seldom have to load more than 3 splits at night and it stays around 80F when above zero F. When it gets cold we go to a couple of larger splits that weight 15-20 lbs each.
    Keweenaw and Star Gazer like this.
  17. ranger bob
    ranger bob
    Leeburn Ontario
    O shoot! - Now I have to comment. "At my age we don't buy green bananas!" lol
    Oldman47, bobdog2o02 and Star Gazer like this.
  18. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    You should, it's a challenge between you and the banana who can last the longest.
    ranger bob and Star Gazer like this.
  19. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    I agree with others, it is based on the stove. My wood furnace will take a 24-26" piece north to south, or around 18-20" east to west. It is too hard to wrestle a 14 inch diameter piece through the door and try to rotate it. Since the stove is nothing more than a heat exchanger, I do have one practice I would suggest you use where possible. The combustion gases from my stove exit through the top in the back, therefore I always rake coals to the front causing the high end of the logs to be opposite of the door. The fire to some extent travels back towards the door, allowing the hot combustion gases to contact more of the surface area in the stove prior to exit. In other words if you can stack the wood such that the flames are directed away from the flue. Will work for some, but I am certain not for all. :dex:
    Oldman47 and Star Gazer like this.
  20. Ronaldo
    Ronaldo
    I load mine with the ends facing the glass front door as its deeper than it is wide and that's how the owners manual suggests.
    I beileve the combustion air comes in to the front of the stove too, because it tends to burn from front to back.
    Star Gazer and Elvisss222 like this.
