When you see something and it scares you!
Discussion in 'The DIY Room' started by Canadian border VT, Aug 19, 2018.
  1. Canadian border VT
    LodgedTree Tube and Knot??
    Is that the same as knob and Tube??
  2. Unhdsm
    Unhdsm
    Bradford, Vermont
    :jaw:That’s putting a lot of faith in the GFI- if it’s even on one.
  3. papadave
    :whistle:
  4. chris
    chris
    SE WI
    actually tube and knob are very safe from a wiring stand point vs everything since, just not very convenient . think about it this way - if the dielectric strength of the wrap material breaks down it shorts out creating a high heat or sparks setting adjacent materials on fire, with the average distance between lines of tube and knob that can't happen. High tension lines are still tube and knob.
    J. Dirt, brenndatomu, Eric VW and 2 others like this.
  5. Eric VW
    :whistle:
    yooperdave and brenndatomu like this.
  6. Eric VW
    :handshake:
    yooperdave, Chaz and brenndatomu like this.
  7. Semipro
    Semipro
    SW Virginia
    I doubt it does. I don't think its required for a wall heater.
    I'm installing a 240v heater in one of our bathes and wanted to GFCI protect it -- turns out a 240v GFCI breaker is a little hard to find and fairly expensive.
    The fact that that box is probably not GFCI protected makes that install all the scarier.
    Chaz and Canadian border VT like this.
  8. Eric VW
    It appears to be a junction box, so why would it/how would it qualify for a GFCI?
    Is there a GFCI box on the market that offers no receptacle?
    :whistle:
    J. Dirt likes this.
  9. brenndatomu
    You could install a 120V GFCI outlet on each leg of the 240V feeding the heater...wired "through" so to protect anything downstream too...obviously. If it worked out that could be your sink or vanity outlet...4 receptacles might be a lil overkill, but better than not enough!
    I guess this wouldn't work if the heater pulled more than 15A per leg though...but that would be a pretty serious heater too! :bug:
    Chaz, papadave and Eric VW like this.
  10. Eric VW
    I thought this was a no-no....? I’m no electrician, just thought I’ve heard a 220 line should be dedicated to its intended end, and not split for 120....ICBW. :yes:
    brenndatomu and Chaz like this.
  11. chris
    chris
    SE WI
    true. proper way would be at the breaker box with a GFI breaker. ($$$)
    Chaz likes this.
  12. brenndatomu
    Oh, you guys wanna follow the rules...dang! :emb:
    Eric VW, Chaz and papadave like this.
  13. Semipro
    Semipro
    SW Virginia
    I was thinking GFCI protection not for an outlet but for that circuit - at the breaker box.
    A short to the plumbing could shock someone through the plumbing - maybe depending upon how well the plumbing system itself is grounded.
    GFCI protection on that circuit would prevent that.
    Chaz and Eric VW like this.
  14. Eric VW
    Yes, you’re right.
    :yes:
  15. Canadian border VT
    I called friend who is master and sent him pic.. Its NOT against code!
    His comment, just proves regardless of how many rules there are. You CAN'T make enough to fix stupid!
    basod, Chaz, milleo and 3 others like this.
  16. ironpony
    ironpony
    Mid Ohio
    Makes me feel better that I could not find anything saying it was against code, I can still read and comprehend what I read.
    But really if you think about a laundry room there is 220V and water in hoses, most likely to leak, right above the floor mount 220 for the dryer. When the wire and piping is sound it is safe, if either is compromised it is unsafe.
    "We" voluntarily bring fire into our homes, if everything is working and maintained properly it is safe, when something is neglected or corners cut on install things go bad very bad.
    Maybe they ran the copper water pipe thru the box for the ground, being I do not see a ground wire in there.
  17. chris
    chris
    SE WI
    just what you need electrolysis on the copper pipe.
    Chaz, Canadian border VT and Eric VW like this.
  18. Firefighter
    Firefighter
    Southern indiana
    The nec book like akot if things is bare minimal to pass code unfortunately anymore people don't use there noggins either when I rewired my house I had to shake my head so much was rigged from the start :bug:
  19. ironpony
    ironpony
    Mid Ohio
    why would this happen ?? did I miss something ??
    I understand dissimilar metals etc.
  20. chris
    chris
    SE WI
    minerals in water + ph of water, adding a low grade electrical current even if intermittent...... For many years neutral and ground were one in the same. For years if you had copper plumbing it was against code to bring it through the drywall , that section had to be steel- Must have been written by a plumber looking to make money down the road as those connections will always rot out at about 20 years or so again depending on PH of water. Closer to home back when they started the high efficiency furnaces and Hot water heaters without a standing pilot- fast forward 10 or more years and we are having failing flue systems ( as well as rusting out combustion chambers) due to the mortar being attacked by the creation of acids by moisture( condensation due to temp. swings) and residuals of combustion. A very prevalent problem in the more northern climes on older homes. That little bit of heat from the standing pilot kept the moisture at bay in the flue. I had to correct 3 of my homes with this in the last 35 years, By the time I got to the 3rd one I was on top of it prior to closing. Slow learner I guess, actually the information wasn't readily available prior as to the actual cause, just chalked up to age of components. ( won't even get into the acid rain debate in the high concentration industrial areas, funny though cause we almost never hear about that any more)
