What's your nightly routine?
Discussion in 'Modern EPA Stoves and Fireplaces' started by LumberJacked, Dec 18, 2019.
  1. motoguy
    motoguy
    MO
    I've had conversations with you on either Hearth.com or Arboristsite.com in the past. I believe the knowledge of adjusting the temp pot may have originated with you, and I later had Daryl confirm it. I believe I also spoke with you regarding a normally-open electronic damper for the trunk line (controlled by the energizing of the propane furnace board), to ensure the gravity flow is not impeded during a power outage. My return-air ductwork for the Kuuma feeds from the top of the wall in the downstairs area, in hopes of getting a few extra degrees of heat. I've not gone so far as to scavenge heat from above the loading door, however.
    JRHAWK9 and brenndatomu like this.
