What's wrong with this picture? Sharpening question
Discussion in 'Chainsaws and Power Equipment' started by Casper, Jan 27, 2017.
  1. Grizzly Adam
    Grizzly Adam Guest
    If that's the only problem you see the. You are in trouble.
    chipper1, papadave and clemsonfor like this.
  2. concretegrazer
    concretegrazer
    Southwest MO
    Looks like he took a grinder to the rakers & got into the tooth a bit.
    clemsonfor likes this.
  3. jtstromsburg
    jtstromsburg
    Stromsburg, Nebraska
    Ohhh. Now I see it. He only used a phone for recording purposes and for a professional with 20000+hours of experience he should have better recording gear.
    And a Stihl
    Stephiedoll likes this.
  4. Casper
    Casper
    Yeah, he got into it a little but it was very consistent on all the teeth both sides. I was able to clean up the teeth on the other chains that still have the depth gauges intact.
  5. clemsonfor
    So that would explain it, he got into the teeth on that chain with a grinder causing all the damage that I pointed out, and you cant file said damage out of the chain with a similar am out of work on other chains that have not had the rakers cut off, and the teeth hit at the same time.
  6. Casper
    Casper
    Here's a pic of a cutter I haven't touched
  7. clemsonfor
    Yea he hit it with just some random Dremel bit I think?
  8. Casper
    Casper
    Tell me if I understand your post correctly. These chains would have taken forever to correct with a file so I used the Harbor Freight sharpener to true them up and make them somewhat uniform. I file most of the season unless something happens like hitting a spiel, nail or fencing is embedded in the wood or if I hit a rock.
    FYI, there is enough to slop in the pivot arm on the HF to compensate for the narrow wheel.;)
  9. Casper
    Casper
    Honestly, it almost looks like he used some kind of jig to hold the tooth vertical and used a chopsaw on the thing.
    I'm half joking with the chopsaw part, but the grinding marks look to be caused by a wheel that hasn't seen a dressing stone since install.
    papadave likes this.
  10. clemsonfor
    It looks like what ever he used was way bigger in diameter than it should of been.
    And the slop can't really make up for the wrong wheel. I Have a HF grinder and both wheels. The right size wheel sharpens just that much better
  11. Pallet Pete
    Pallet Pete Moderator
    Ovid
    I usually set mine low but not that low! Good lord talk about speed bumps :rofl: :lol:
  12. clemsonfor
    I also have a northern tool knock off oregon grinder that really makes the HF model look chinky
  13. Oldman47
    Oldman47
    Illinois
    If you can see the raker gap that easily with just a file laid across the top, there is no way to file the cutters enough to get back in spec. Trash that chain.
  14. papadave
    Took the words outta' my mouth, or my keyboard.
    chipper1 and clemsonfor like this.
  15. g60gti
    g60gti
    NY West
    I'm not sure on your chain except that it doesn't look good.
    I just had to post because this video is too good, seriously? Is that suppose to be a joke? Proof right there that you can't believe everything you see on the net. I gotta see if he's got any other videos.
    jtstromsburg and clemsonfor like this.
  16. JustWood
    JustWood Guest
    I'll agree that the cutter was bumped with grinder while whoever was trying to perform some kinda wizardry on rakers. All the rakers are shaped differently
    clemsonfor and saskwoodburner like this.
  17. hdtoolmkr765
    hdtoolmkr765
    Kokomo, IN
    Believe it or not, I've watched tree guys in the field file rakers down like that. I've seen chains that bad come to me to be sharpened, they go straight in the scrap barrel.
  18. Khntr85
    Khntr85
    Indiana
    I bet I know what he did, looks like he used an angle grinder to knock down the rakers, and accidentally bumped the point of the cutter.... it's funny the things people do to saws and chains!!!!!!!
    concretegrazer likes this.
  19. clemsonfor
    I think concretegrazer called that one a page or so back. But I agree with the both of you on that and think that's a correct assumption
  20. Spencer
    Spencer
    Indiana
    This is probably the funniest post i have read in awhile. The "mangle" chain lol.
    Felter, clemsonfor and Grizzly Adam like this.
