  1. Backwoods Savage
    That's the first thing I though of too and yes, I've used those wagons. They saved us a lot of work.
    Horkn, bogieb, wildwest and 5 others like this.
  2. 41FanForLife
    41FanForLife
    Absolutely beautiful day here in Pittsburgh. I would take this weather all winter long.
  3. wildwest
    Is this left over after baling? Or the entire plant?
  4. TrinitySouth99
    TrinitySouth99
    New Harbour, NFLD
    That's a great shot.
  5. Eric VW
  6. lukem
    Got my deer processed and In the freezer this evening. I still need to finish cleaning up but that's going to wait until tomorrow.
    Im about 50% done making a cherry cabinet for my mom. Just need to make the doors, sand, and finish. Should have it done by Thanksgiving.
    Two more days of work and the wife and I are going in a nice little getaway.
    Horkn, theburtman, wildwest and 6 others like this.
  7. brenndatomu
    Entirely different process.
    The hay is cut, but not left to dry as much as when baling it, then it's chopped up finely and blown into that wagon shown in the video. From there it's stored packed into some kind of oxygen limiting storage area (silo, giant silage bag, bunker, etc) where it ferments into silage, which is great cow food. This process is done with corn too...the whole plant is chopped up, not just the corn kernels.
    Horkn, theburtman, wildwest and 5 others like this.
  8. Gasifier
    Caffeine!
    Time for my beautiful fence to come back down.
  9. Backwoods Savage
    Chopped corn that we put in silo for cow feed in winter.
  10. Backwoods Savage
    You know that won't happen but it is a nice thought.
  11. Backwoods Savage
  12. Backwoods Savage
    We used to do that with hay in summer because cows ruin much of the pasture so chopping the hay then feeding it to them gave more acreage to other crops. On the other hand, corn is what is more normal. Chop it in fall to fill silo (of course not many use silos today because the herds are so much larger), fill silo and let it ferment. We also found it was best to chop the corn right after the first frost or freeze. Some wait too long then have to add water as they store it.
    Horkn, theburtman, bogieb and 5 others like this.
  13. brenndatomu
    Down here, I'd lay odds that quite a bit more hay goes for silage than corn, but there is lots of that too.
  14. Canadian border VT
    brenndatomu Besides silage what are other major uses of hay. I mean I get horses and landscaping etc but that’s a small percentage I assume. Well here it is as our climate is 120 days between frosts and that less at elevation, over 2000 feet 90 days on good year
  15. brenndatomu
    Hay is almost totally animal feed (critters of all kinds) its just a matter of if its made into silage, or further dried and baled (silage, which involves fermentation has different nutritional qualities than baled hay does, even though it may from the exact same field)
    When I was a kid 1st cutting hay usually went into the silo, then 2nd and 3rd crop may be baled. (we can get 3, sometimes 4 crops per year in our neck of the woods here in NEOH)
    Corn can be harvested for silage, (whole plant is chopped up) or just the ear may be plucked off and stored whole, or the corn kernels shelled off and used for feed (or whatever...ethanol/fuel :mad:)
    If the corn is not used for silage (whole plant) then often times the farmer will come back after the corn itself is taken off and cut the stalks down, then bale it for bedding...which the critters will often eat some of that too.
    You mentioned landscaping...generally that's wheat or oats straw that gets put down over newly seeded grass, but I've used hay before (because I had some junk hay, and no straw) it's not real common though.
  16. wildwest
    Thank you :)
  17. wildwest
    Thank you, I missed this last night.
  18. wildwest
    Lease it to your neighbor with cows so they can eat it? Harvest and schuck it if appocolypse.
  19. wildwest
  20. Canadian border VT
    Great answer brenndatomu thanks because it’s so different here. No wheat or oats available so landscaping is hay or straw. Here mostly dairy farms short season
