  1. wildwest
    They wouldn't have customers if they cured us.
  2. theburtman
    theburtman
    That's what I'm saying. They make more money under the current circumstances. We all pretty much know that big pharma is corrupt, but I submit that the medical community is profiting as well from not curing anything.
  3. theburtman
    theburtman
    And the worst part is they are all getting federal money without results.
  4. Jeffrey Svoboda
    Jeffrey Svoboda
    Just keep paying your taxes...... Lol
    Dok440, Horkn, theburtman and 4 others like this.
  5. TrinitySouth99
    TrinitySouth99
    New Harbour, NFLD
  6. Woodwidow
    That will be a nice room when finished.
  7. TrinitySouth99
    TrinitySouth99
    New Harbour, NFLD
    Thanks, I think so too.
  8. lukem
    I installed fiberglass insulation in 2 of the shop walls today...12 rolls worth. I'm itchy.
    Went to put some OSB up afterward and most of the studs are about 1.5" out of plumb over the 9' wall height....so the top of the board is on one side of the stud and the bottom is on the other. I guess the only thing I can do now is cut an angle on the bottom and put up some trim along the top....or vice versa.
    Gong to pour myself a drink and come up with some strategery on what to do now.
    Once the OSB is on 2 walls I can move everything in the shop over to the other side and start all over again. I wonder what surprises it has in store.
  9. Horkn
    We had way too much fun last night laughing at this t shirt that is available for Dildo Newfoundland Screenshot_20250803-210309.png
  10. Dok440
    Dok440
    NorCal
  11. Dok440
    Dok440
    NorCal
    I agree, plus a good use of space. How is the view out that window?
  12. Dok440
    Dok440
    NorCal
    The dryer vent partially clogged a couple days ago. I cleared it out the best I could, but it is made of that semi rigid expanding aluminum stuff. Almost impossible to run a brush through it especially with the lack of hangers keeping it in place. Replacing it with sheet metal ducting just got moved to the today list. What a job, everything was fighting me. I barely fit in this part of the crawl space. The ducting had to avoid a gas line hung 4" below the joists (because why not?), ABS sewer line and several copper water lines. What should have taken an hour took all day. I'm also covered in bruises, cuts and scrapes from all the broken up concrete that was strewn on the ground in that area. I don't drink anymore so I had a Dr Pepper instead. :picard:
    Stephiedoll, JD Guy, Horkn and 8 others like this.
  13. brenndatomu
    Sounds like a nightmare...good call though, get rid of that fire hazard!
    bogieb, Dok440, Horkn and 5 others like this.
  14. yooperdave
    Hmm.....maybe hang the OSB sideways? You know, 4' high by 9' long? Then, since the vertical seams would not quite line up, you could cover them with a furring strip?
    BTW, how did the "talk with the GC" go about those studs not being plumb??? :whistle:
    :D
  15. TrinitySouth99
    TrinitySouth99
    New Harbour, NFLD
    Thanks. I'll show you soon.
  16. TrinitySouth99
    TrinitySouth99
    New Harbour, NFLD
    Thanks!
  17. yooperdave
    Do you think you could get away with throwing that onto a WNBA basketball court? :rofl: :lol::rofl: :lol::rofl: :lol:
  18. Canadian border VT
    lukem is it’s exactly 1.5” and it’s all the studs A rookie nailed on wrong side of the line. Let GC know. How much sheeting and siding from outside missed the studs? That’s when you usually find it
  19. lukem
    Well, this thing was built 60+ years ago so the GC is probably in the ground. The studs are about 1/4 bubble out of plumb...I'm pretty sure the whole building is leaning to the north. When they put the outside sheeting on they used a bunch of scabs.
    I went out for a little bit this morning and trimmed 3/4" to nothing off of opposite corners and they fit good. Just need to add a trim piece to the top to cover the gap.
  20. 41FanForLife
    41FanForLife
    That stomach virus showed back up over the weekend. I think my body purged all the poison this time. Hopefully I'm on the road to 100%
