  1. Gasifier
    No doubt Saves. Agreed. It WILL be nice to do what I want, and when I want, after retirement though.
    Horkn, bogieb, brenndatomu and 7 others like this.
  2. Gasifier
    Caffeine! Might have to cut some firewood today. Will definitely get some outdoor activities in. A little chilly out there, but dress right, and once I get going I will be plenty warm.
    I’m a Grandpa again! :) My daughter gave birth to a healthy baby girl! She and Mom were discharged the very next day and home and doing well. Sydney was born on her father’s Birthday. Grandparents on the other side live close by. So we will give them all time to settle and relax. Then it’s time to plan out a trip!
    Horkn, Chvymn99, bogieb and 12 others like this.
  3. yooperdave
    Congrats!
    Horkn, Chvymn99, brenndatomu and 6 others like this.
  4. yooperdave
    Our bernese mountain dog developed a limp yesterday. Don't know the cause yet but I suspect it twisted it's leg just enough to create a problem when it was chasing the other dog through the snow. Sharp turns can do that to you.
    He's worse this morning-we'll see just how the day plays out for him.
    JD Guy, Chvymn99, bogieb and 6 others like this.
  5. eatonpcat
    X2 Gasifier...Waiting for pictures!
    Horkn, Chvymn99, wildwest and 6 others like this.
  6. eatonpcat
    Well this sucks!! Good luck and hopefully it is just a twisted joint!
    Horkn, Chvymn99, bogieb and 7 others like this.
  7. Eric VW
  8. savemoney
    That is wonderful. Enjoy!
    Horkn, yooperdave, eatonpcat and 6 others like this.
  9. lukem
    Spent the morning under the truck changing transmission fluid and sealing up the pan gasket. Lots of itty bitty bolts, some of which are in hard to reach places. No drain plug so dropping the fluid is a mess waiting to happen. Not a hard job, but it is far from enjoyable. It must have been pretty low because the shifts are pretty crispy now compared to before...whoops. Fluid looked and smelled fine so I don't think I hurt it much, if at all.
    Took another try and getting the 4th O2 sensor out but I think it's just going to have to stay unless I drop the exhaust. They threaded it in there just right where I can't turn the wrench enough to any meaningful pressure on it. You win some, you lose some.
    Horkn, bogieb, yooperdave and 8 others like this.
  10. Jeffrey Svoboda
    Jeffrey Svoboda
    I could go on and on about changing O2 sensors..... but i won't. Lol. Have you tried to use a pry bar against a wrench? Like put the open end of the wrench on the O2 sensor and the tip of the pry bar on the closed end. Then find a spot on the trans case, frame or whatever is solid to use as your pivot point. A little heat goes a long way also. Just gotta be careful not to pull threads with the sensor.
    Horkn, bogieb, yooperdave and 4 others like this.
  11. lukem
    No matter which way I get a wrench, O2 socket, whatever on it...I can only get about 1/64 of a turn on it. I can barely get the slack out of the wrench before it hits the exhaust pipe.
    Horkn, bogieb, savemoney and 5 others like this.
  12. Jeffrey Svoboda
    Jeffrey Svoboda
    I can understand that. Does a stubby wrench help any?
    Edit: If you can't stand under the vehicle the "prybar trick" might be kinda tough.
    Horkn, savemoney, brenndatomu and 2 others like this.
  13. Backwoods Savage
    Horkn, bogieb, savemoney and 4 others like this.
  14. brenndatomu
  15. brenndatomu
    What year make model and engine do you have?
  16. lukem
    09 F150 24V 4.6
  17. brenndatomu
    I assume 4x4?
    Any tool or procedure advice Warner ?
  18. lukem
    2WD
  19. Warner
    Warner
    These are the tools I use on pretty much all o2 sensors. I have also cut the wires off and used a flex ratchet wrench. I have seen guys take the y pipe out but have never had to go that far. IMG_4384.jpeg IMG_4383.jpeg
    Horkn, Chvymn99, metalcuttr and 6 others like this.
  20. savemoney
