  1. concretegrazer
    concretegrazer
    Southwest MO
    If it's a chain drive double check the chain tension. I've had them jump on the drive sprocket.
  2. Smokinpiney
    Smokinpiney
    "South" Jersey
    I waited until dark to load wood just for you loon ! ;) I'd say they work pretty dang good! That's one light.o_O
    Now what to do with the other one?
    papadave, cnice_37, Chvymn99 and 9 others like this.
  3. jetjr
    jetjr
    Pa/Md line
    Do you know much about garage door openers? Mine will open a little than stop about 10" up than a little more. Doesn't do it all the time.
    Stinny likes this.
  4. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
    I wonder if the cold affects them?
  5. jetjr
    jetjr
    Pa/Md line
    Was thinking that myself.
    Jack Straw likes this.
  6. Loon
    Loon
    North of the border
    Those things work great Smokin. :thumbs: Anywhere on the back for the other one?
    Edit this as went back to your first post and you mentioned it.:drunk:
    Those being that bright i'd be hooking the other one on the house somehow.:yes:
    Smokinpiney likes this.
  7. rottiman
    Check your safety eyes, they might be slightly out of alignment and the vibration may just be enough to stop the door now and then. Happened to me a couple of times.
    Stinny and wildwest like this.
  8. wildwest
    I had the same problem with our safety eyes, only it was going down, not on the way up.
  9. concretegrazer
    concretegrazer
    Southwest MO
    Can you put it on the front?
  10. Stinny
    Are the elec eyes blocked in any way? Dirt/crud on them? Wires corroded? I had a wire break in it's jacket once and acted a little like that.
    Edit: I shoulda read the other posts first... :whistle:
    concretegrazer likes this.
  11. concretegrazer
    concretegrazer
    Southwest MO
    More than I care to.:headbang: Modern ones have safety pressure switches for up & down. So if it's constantly stalling at the same height check the rollers that would be under pressure there as well as the panel seam that's opening. Could just need to bump that switch setting up a hair. As far as I know the eyes only matter when the door is closing.
    jetjr likes this.
  12. Chvymn99
    Awww... Good to be home...
  13. Gasifier
    The wife and kids helped me load the wood bin on the rolling platform I made for under the porch. We did that several times this morning and I used the tractor and forks and loaded a full truckload of nice dry wood and delivered it to a customer around 1pm. That money will go toward the property taxes I just got in the mail. :picard:
    Then stopped at the grocery store for wife on the way home for some things she needed for dinner. By this time it was almost 2pm. Time to go in the woods:thumbs:! Didn't have much time though, dinner was at 4. :( But I used the bucket on the tractor and scraped down the new trail I am making into the new cutting area. This is going to work out well. I am going to make some new trails around the property while cutting wood and thinning the woods!:thumbs: So I only took a small load out today. But got some good things done today.
    Then after dinner, and a needed rest, I went down down to the basement for the boiler cleaning. Cleaned the boiler out. Then cleaned the pipe from the boiler to the outside chimney. That is quite a job. Not hard really. But messy and takes a little time. Altogether about an hour for the boiler and the pipe. Waiting for the new cement to dry before I cure it with some heat.
    Several good things done today.:thumbs: I tired. Beer time.
  14. concretegrazer
    concretegrazer
    Southwest MO
    :drunk:
    Chvymn99 likes this.
  15. jetjr
    jetjr
    Pa/Md line
    Thanks I'll check it out.
    wildwest likes this.
  16. wildwest
    Our old school double garage door was abused with by the wind, we had to adjust the track joints that are closer to the motor a few times over the years. Wind vibrates door, wheels get loose, and it would jam on the tracks near the top. Tighten wheels, lubricate, adjust and tighten tracks. I hope you have a fix that was that easy :)
  17. lukem
    Colts getting spanked. Sigh.
  18. rottiman
    Who woulda thunk it....................................
    greendohn likes this.
  19. Chvymn99
    Awwww....beer and fire.....ready for bed in just a few...:BrianK:
  20. Gasifier
    That's what I'm doing Chvymn99. Boiler fired back up and almost to temperature already. On my second cold one. Won't be long before I am completely horizontal!
    Chvymn99 and prell 73 like this.
