  1. Ohio
    Not Ohio
    Bingo.
    The wire looked like it was still in the connector but was not making contact. Gave a little pull and it came right out. I stripped it and jammed it into the connector and the fuel pump came on with the key and it fired right up.
    Ford forums had somebody with the same problem. Good thing i did not load the parts cannon. Now to get it fixed more permanently.
  2. brenndatomu
    Not unusual...good job on finding it! :yes:
  3. Warner
    Warner
  4. Theashhole
    Theashhole
    Osceola, In
    Got myself a 48" hi-lift jack, I've heard they can be very dangerous but also very useful, I don't have any plans to lift the pick up etc. just start on small stuff and learn to use it[​IMG]
    Sent from my LE2127 using Tapatalk
  5. NortheastAl
    NortheastAl
    Putnam County NY
    It would make sense to have everyone use snow and ice tires again, like we did in the old days. They brine before almost every winter storm even if it turns out to be mostly rain. They used to sand our roads and we had no problem getting around. Plus, we were surrounded by reservoirs and the runoff cant be good for drinking water.
  6. NortheastAl
    NortheastAl
    Putnam County NY
    Awesome! Glad it turned out to be an easy fix.
  7. lukem
    Got 9 out of 17 rafters cut and set today. Hoping for the rest and purlins by the weekend.
    In other news, it's too damm hot.
  8. JackHammer
    JackHammer
    Looks like it has a spot to attach a chain, that could be useful. Good lookin' tool.
  9. bogieb
  10. Canadian border VT
  11. eatonpcat
    X3
  12. NortheastAl
    NortheastAl
    Putnam County NY
  13. yooperdave
  14. EODMSgt
    EODMSgt
    White Mountain Region, NH
    Congrats. I've been using those for almost 40 years and never had an injury. They're like any other tool, just use common sense. The most common ways I see people getting injured are overestimating the tipping/slipping factor when using it to lift a vehicle (not really designed to be a bumper jack so use caution) and people getting whacked in the head when lowering the jack (the lever will come flying up very quickly when under a load if you don't hang onto it). Countless uses for them.
  15. NortheastAl
    NortheastAl
    Putnam County NY
    Standing directly behind them led to the reintroduction of the castrati singer.
  16. EODMSgt
    EODMSgt
    Yup. Getting 'whacked in the head' by the handle can cover two different parts of the male anatomy. :rofl: :lol:
  17. Eggshooterist
    Eggshooterist
    Erff
    I've had one fir years. Only thing I kept when I sold the last modded Jeep. They are dangerous when letting them down as the handle wants to fly up and clobber you about the noggin. Being aware of that little personality trait should keep you safe. From that anyway. They also have a base you can set it on for soft ground. I have that too.
  18. eatonpcat
    Replacing a spring on the trail...Now this is manly!
  19. Theashhole
    Theashhole
    Osceola, In
    Any length/size of chain you guys keep with them?
    I'm gonna pull up some stumps with it first
  20. EODMSgt
    EODMSgt
    Somehow a spring clip failed while going up a gnarly section of trail and the driver's side front spring popped out. Used a combo of the hi-lift and the winch to lift up the driver's side front and had the spring back in in no time. Felt like a NASCAR pit stop.
