  1. Ohio
    Not Ohio
  2. brenndatomu
    Very likely a fuel pump relay...I've changed a ton of them on that vintage truck.
    Its in the black electrical box under the hood on the drivers side...I don't recall which relay, I'm sure googlefoo will tell you that...but pop that box open and pull the relay(s) out, look for corrosion that needs cleaned up...sometimes just the act of pulling the relay and putting it back in will get it working again (for a bit) but often times you can hear it click when the key is turned on, but the fuel pump does not run...if the terminals are not corroded and the relay clicks with no fuel pump, relay is very very likely bad...used to be just about every parts store stocked those...
  3. Ohio
    Not Ohio
    Just changed it out back from orileys. Still the same. I am not to great at electrical, Ill probably check the wires going into the relays tomorrow. Ill figure out how to jump the inertia switch and the tank selector switch to remove them from the equation. If all that looks good I guess I could take the rail pump off and hook it to a battery to see if it works. I'm hoping there isn't a short somewhere. Thanks for the help.
  4. brenndatomu
    Hit the Ford truck forums...they can be super helpful in honing in on a problem like this.
  5. brenndatomu
    I'm sure you already went through the fuses...can't remember if that one has 2 fuse boxes..1 under the dash and one under the hood...I think it does.
    Maybe Warner would have some good pointers on this one too?
  6. yooperdave
    Where's Horkn when you need him? :handshake:
  7. eatonpcat
    Just take the Ram!!
    Good luck getting her back up and running!
  8. Lennyzx11
    Lennyzx11
    Bennington Vermont USA
    You can jumper the pump at the relay rather than taking it off the truck. Pin 30 to pin 87.
    I’d also check the inertia switch button.
    Look for power on the yellow wire at connection 30 of the relay. That’s your input and will divid the problem into two halves.
    I’ll be happy to help also.
    Here’s this to help.[​IMG]
  9. Eggshooterist
    Eggshooterist
    Erff
  10. EODMSgt
    EODMSgt
    White Mountain Region, NH
    It's almost that time of year...
  11. Ohio
    Not Ohio
    In today's market heres the ad for it.
    F150 $10,000
    1989 f150 basically brand new, only 325,000 miles. No lowballs, no tire kickers, I know what i got.
  12. Eggshooterist
    Eggshooterist
    Erff
    Will you take $9500? Lol
  13. Ohio
    Not Ohio
    No, I know what I got!
  14. Eggshooterist
    Eggshooterist
    Erff
    Lol.
  15. Canadian border VT
    Yeah a truck that won’t run or start:eek:;)
  16. brenndatomu
    Been AWOL lately...
  17. lukem
    It feels hotter than the blazes of hell out there. Last week's highs were in the low 60's and today the heat index is dang near 100. I tried doing a little framing on the lean-to a while ago and had so much sweat running in my eyes I had to quit.
  18. Theashhole
    Theashhole
    Osceola, In
    It's 80-90⁰ here, I wanted summer, finally got it and I am certainly not ready for it, forgot to put my short summer socks on today!
    Sent from my LE2127 using Tapatalk
  19. NortheastAl
    NortheastAl
    Putnam County NY
    Nice looking truck. If that truck lived in NY it would be totally rusted out or already gone to the crusher. I don’t know how you guys can keep Fords in good shape past 10 years old?
  20. Ohio
    Not Ohio
    Thanks! My uncle had one of these when I was a kid.
    That truck spent the first ten years of its life in Virginia and then in Tennessee up until about 8 years ago. Its got some rust on the wheel wells but the frame looks pretty darn good. I've put more time and money into it than its probably worth but I've learned a lot and the 4.9 straight six just won't quit.
    My dad bought a ford truck in Washington state just as covid hit. He bought a plane ticket to Washington state almost to the Canadian border. Drove it all the way back home to central ohio. It cost him more in gas to drive the truck back than it cost to fly to Washington.
    Its incredible how a vehicle will hold up without salt and brine on the road.
