  1. yooperdave
    :picard:
  2. bogieb
    Nice work that you and 99 did yooperdave ! I'm usually of the mindset that if it ain't broke, don't fix it, but you probably did the right thing by getting to that pressure tank now, as to waiting until it went. Being out of water for a day or so, with temporary overnight is much better than an emergency service bill and still being out of water for a week or so until they can find parts and/or time.
    savemoney, mat60, wildwest and 5 others like this.
  3. Warner
    Warner
    Or have to thaw the ground enough to dig it up! Having a hard time wrapping my head around why the tank (that commonly fails) would be buried outside!
    savemoney, mat60, wildwest and 6 others like this.
  4. brenndatomu
    X2
    Have never seen that before...not too bright IMO
  5. Gasifier
    Maybe they were under pressure to do it that way.:):emb:
    savemoney, mat60, wildwest and 7 others like this.
  6. Gasifier
    Caffeine! Back to the real job later this morning. But first I have to pull both the batteries out of the 300B. Again. No start! :picard:Took them both out yesterday and tried charging them. Back in they went, nothing. Dates on them from early 2017. Hoping that is all it is.
  7. yooperdave
    It is actually an approved by the state type of system.
    For this application, I understand completely just why it was done that way.
    When the guy bought the land, he had the well drilled, built a garage, and had a trailer that was used for quite a few years. It was hooked up to electric, which explains why you can see some discarded wiring sticking out of the ground near the well, septic, and of course water from the well.
    The house was built 12 years ago and obviously, he elected to leave the working pressure tank set up just the way it was. Buried.
    The first time I viewed the house, I noticed the absence of the pressure tank in the basement. The owner said that there had never been any issues what-so-ever with it.
    I just know that "Murphy" was planning an unannounced visit some time in the future..........
    savemoney, bogieb, mat60 and 7 others like this.
  8. yooperdave
  9. Gasifier
    Ha! I thought about it some more and before I pulled the batteries I tried the old fashion way to see if there was any spark. Sure enough, plenty. So I knew batteries were okay. Took the side steel panel off next to the key switch thinking maybe bad switch or selenoid. Started moving some wires around and lightly pushing and pulling on things hoping for a short or bad connection. And the dash lights come on! Yea! Pulled the wiring connector off the back of the key switch. Ugh. Grungy mess. Took a wire brush to all the metal tabs and carefully cleaned them up. Pushed the connector back on tight and there we go. Each time I turn the key on now the dash lights come on. It started right up.
    So in the meantime I have charged the batteries, cleaned all post on both. Cleaned inside of lead connectors. Cleaned ground connectors. And now cleaned key switch connectors.
    It looks as though I should eventually replace the electrical connector at back of key switch. And maybe the key switch as well. But that will require some time to label all wires, etc., etc., etc.
    Future project.
    savemoney, bogieb, mat60 and 6 others like this.
  10. rottiman
    Now that the terminals are clean, give them a light coating of Dielectric grease
  11. Gasifier
    Good idea. Thanks.
  12. rottiman
    I would spray the key slot of the switch with a little Contact Cleaner and WD-40 as well.
  13. eatonpcat
    X2
    savemoney, mat60, wildwest and 4 others like this.
  14. Horkn
  15. Canadian border VT
  16. HighCountry
    HighCountry
    New Mexico
  17. Chazsbetterhalf
    Chazsbetterhalf
    Lol we are mid 60s today.
    savemoney, mat60, wildwest and 3 others like this.
  18. Eric VW
    HBD, HC!!!
    savemoney, HighCountry, Horkn and 6 others like this.
  19. wildwest
    SHOCKED!!
    I've had "gut feelings" before and they are somewhat accurate, though not all the time. I got some well needed sleep last night and one dream was I was driving to the bus stop and there was the big yellow bus waiting for me on the hill a couple blocks ahead. I left at my normal time today to get there which is more than 10 minutes early, sure enough, I get one block down the road where the bus stop is in view and it's there, parked! I'm amazed. :banana:
    Kiddo says some on the second bus were out sick, and several missing on the 3rd bus for after school orchestra practice which is why they were early. I'll pay better attention next time. This was a dream, not guy feeling.
  20. mat60
    mat60
    ME
