  1. Gasifier
    The fire tower. 86D63C1D-CA99-4E6D-9DA9-B4AB75171E4F.jpeg And a few pictures from....
    savemoney, bogieb, Horkn and 10 others like this.
  2. Gasifier
    An awesome day for it!
    74BDB70F-E8E3-4AF6-9E59-13B0D843E04A.jpeg 92A9FF67-9C78-4CCB-8E1B-31900685FD56.jpeg C202DA77-9563-4F6F-93F8-E7A61621015C.jpeg
  3. rottiman
  4. Beetle-Kill
    Beetle-Kill
    Near the Divide, Colorado
    For me, I throw the breaker on the pump, hook up a hose to the cleanout valve and flush. Mine does have a screw valve plumbed in so it can be flushed.
    Once the tank is flushed, I throw the breaker on the pump and let it run for about 4-5 minutes, then shut it off. Once the tank if fully flushed, I'll check the pressure on the bladder. If good, I seal up the system. Then I can do the water heater.
    bogieb, Horkn, TrinitySouth99 and 4 others like this.
  5. Chazsbetterhalf
    Chazsbetterhalf
    Well I contacted a tree service that had taken down some trees for us. Yes they left us the wood but we didn't think of ask to become a dump site for their wood. :doh: but they also said that haven't had any jobs in our area but said of they do they will contact us. Well it is a start.
  6. Canadian border VT
    Had to take a trip to Stowe today, driving over the Smugglers Notch was an absolutely beautiful trip. But I cannot work the camera on the phone and drive at the same time, especially on that narrow passage.:emb:
    savemoney, bogieb, Horkn and 8 others like this.
  7. Chaz
    Chaz
    Southwestern NY
    My pressure tank has no cleanout valve.
    Worked on it all day today with no luck.
    Replaced pressure switch because the pressure line was gunked up.
    Opened system up, compressor section spins freely, but I didn't tear it apart to examine the impeller fins/blades.
    Put things back together, primed system, it seems like it's building pressure according to the gage, but no water in house.
    :hair::hair::headbang:
    We currently have cold water though.
    :cool:
    I disconnected and capped off the water system in trailer, ran hose from trailer to house and backfeeding the system.
    One benefit of having two wells on the property.
    :thumbs:
    I'm sure I'm missing something, but obviously don't know what.
    o_O
    A friend mentioned the foot valve, told him I considered that, but don't want to think about the $$ if that's the case.
    I'd have to have a well service company come do that, the well casing is thick steel with concrete cap.
    :confused:
    Have a call out for more advice from a contractor we've dealt with previously.
    We'll see what he thinks.
    :tears:
    savemoney, bogieb, wildwest and 7 others like this.
  8. Gasifier
    Ugh! Hope something easy works out for you!
    bogieb, wildwest, Horkn and 4 others like this.
  9. Chaz
    Chaz
    Southwestern NY
    Thanks Gas
    Well, things are seldom easy at times, but we'll make it work.
    :thumbs:
    Worst case scenario in my mind, I have to use the tractor to make a ditch, and plumb the house into the other well.
    :eek::yes:
    The house runs on a shallow well jet pump, trailer is connected to a deep well submerged pump that got replaced a few years ago.
    Either way, I just need to figure out the plan before snow flies.
    :bug:
    Should have hot water back tomorrow, just didn't feel like a third trip to town today.
    :picard:
    I know.. slacker
    :emb:
    bogieb, wildwest, Horkn and 8 others like this.
  10. Chaz
    Chaz
    Southwestern NY
    bogieb, Chvymn99, Gasifier and 3 others like this.
  11. TrinitySouth99
    TrinitySouth99
    New Harbour, NFLD
    Seems this will be a gas station, but with something attached. Probably a fast food joint or coffee shop which would explain the Industrial A/C. The orange white and green are the colors of the company that operates our refinery. Still wonder if something else will be built right on the corner. It would definitely benefit the gas station to have access from both roads.
    savemoney, bogieb, Horkn and 5 others like this.
  12. Chazsbetterhalf
    Chazsbetterhalf
    Mama hot cold but won't be for long
    Thanks baby. Look close and you should see our wolves.
  13. Chazsbetterhalf
    Chazsbetterhalf
    I think forks for around here will find more use. :rofl: :lol:
    NortheastAl, bogieb, Horkn and 2 others like this.
  14. Midwinter
    Are you seeing a lot of red trees this year? I think we are down here, maybe because of all the rain. You weren't as wet up there, though.
  15. Horkn
    Why does "carved spalted maple whale" sound tasty? I'm not even Japanese. ;)
    NortheastAl, schlot, bogieb and 3 others like this.
  16. Gasifier
  17. Horkn
    03, those Polaris 350's were pretty well ironed out. Ours is a sportsman 500ho and a 2004, so a little different, but it's been really good to us. I know a few guys with the 350l magnums, and they are really good. It's a Fuji motor.
    NortheastAl, bogieb, Gasifier and 3 others like this.
  18. Horkn
    Don't forget the bacon!
    Extra yummmm:flipeggs::drool:
  19. Chaz
    Chaz
    Southwestern NY
    Huh, I'll have to get both obviously.
    :yes:
    :banana::dancer::rootintootin:
    :tractor:
  20. Horkn
    Bladder tanks just don't last really long.
