whats the new famdangled oil to use these days?
Discussion in 'Chainsaws and Power Equipment' started by Freakingstang, Nov 20, 2014.
  1. Sunfish
    Sunfish
    Success Mo
    WKEND LUMBERJAK likes this.
  2. haveissues
    haveissues
    Hudson Valley
    I used to use the stihl orange bottle oil for no reason in particular. I tried the husqvarna xp oil after I got some with a saw and gave the stihl stuff away. It wasn't until then that I realized just how bad the stihl oil stink. I like using oil that has stabilizer in it since you can't get anything other than 10% ethanol around here and sometimes a saw or blower sits a while between uses.
    macpolski, Cut4fun and Chvymn99 like this.
  3. MasterMech
    Some Husky's really do appreciate 40:1 or 32:1 mixes for extra lube in the bottom ends.
    clemsonfor, NH_Wood, Cut4fun and 3 others like this.
  4. Freakingstang
    Freakingstang
    I don't like discussing mix ratios because it becomes peepee measuring contests with some. I run 40:1, just because I have since I worked tree service in the 90's and thats what we ran before epa changed to 50:1. If a saw is ported and it runs higher rpm, it is a good idea to go a little more on the oil, but then you have to retune for it.
    clemsonfor, Chvymn99, mdavlee and 2 others like this.
  5. Kg461
    Kg461
    Provencal, La.
    Motul 800t offroad
    Adirondackstihl likes this.
  6. mdavlee
    mdavlee
    I would consider running it at 2 packs a gallon. I know a few guys run it with success in n work saws that are used falling daily out west.
    clemsonfor likes this.
  7. Adirondackstihl
    Adirondackstihl
    Before I actually knew much about saws I just figured that all 2 smoke oil was the same. I had a 96' Formula Z 583 and always had a gallon of Klotz Super Techniplate or Polaris VES Gold layin around so that's what I used.
    Never measured either.....just dumped oil in till the color looked right.
    Never blew anything up, but my Eager Beaver acted funny on some mix I made one time :)
    By the way, both oils smell super yummy especially the VES Gold
    clemsonfor and mdavlee like this.
  8. the GOAT
    the GOAT Banned
    Maine
    I've started mixing 32:1 now that I buy the oil by the gallon.
    I have a two gallon gas can and a few 8 0z mason jars that I fill with oil. That way there is no measuring. One full jar with one full can of gas.
  9. NH_Wood
    NH_Wood
    Thanks MM - I've somehow evolved to a mostly Husq line of keeper saws - if you think more oil is good I'll do it. 40:1 or 32:1 with the Belray- what you you mix? Cheers!
    Chvymn99 and clemsonfor like this.
  10. MasterMech
    I personally run 40:1 but not with BelRay. I do believe that some oils like to be mixed heavier, I've heard that 32:1 is the recommendation if you are running the BelRay. Also, modified saws need more oil as the bottom ends see more stress for sure. Nobody I know of has destroyed a saw with too much oil. :thumbs:
  11. bogydave
    Didn't you run some at 100:1 ? Then you noticed some bearing wear .
    Forget the original post, was it the Amsoil racing 2-cycle Dominator ?
  12. MasterMech
    It was Mastermind that posted the ArboristSite thread about a Ported Stihl 066 that destroyed the bottom end running AMSOIL Saber Pro at 80:1.
    I have run AMSOIL Sabre Pro at 80:1 in stock equipment. I would never recommend trying it in a modified saw. It works well in many applications that do not turn the rpms a high-performance professional grade saw sees but even AMSOIL does not recommend 100:1 for "racing" or "commercial" applications. I consider any engine that typically turns 10K rpm under load a racing engine. Most modern pro-grade saws easily fit that description. Sabre Pro is a fine oil but knowing what I know about small engines and the conditions they see, I just can't recommend anything leaner than 50:1. And that goes for anybody's oil, not just AMSOIL.
  13. bogydave
    Yea
    a little extra oil never hurt a thing :)
    Had a yamaha outboard, fuel mix recommended was 100:1 .
    Ran great on 50:1 :)
    Outboards mostly going 4 cycle now, many waters require 4-stroke.
    Thru the prop exhaust, with no oil, better for the fish :)
  14. Sunfish
    Sunfish
    Success Mo
    Bought a few more qts of Lucas yesterday. Need to see if they can order it in galon jugs
  15. Freakingstang
    Freakingstang
    unless you are going through 10-15 gallons of mix every couple of weeks, I wouldn't buy gallon oil jugs. i wouldn't risk the chance of it collecting moisture. A quart will last a while feeding a few saws...
  16. Sunfish
    Sunfish
    Success Mo
    I go through a fair bet of mix this time of year. I also keep my oil & mix can in a dry heated shop,
    so I'm not worried about collecting any moisture. But you do make a good point.
  17. Freakingstang
    Freakingstang
    synthetic oils attract moisture, its just the nature of the beast. I see that on my service truck with HIGH dollar compressor oils once you open it, its basically useless unless you use it within a very short time frame. not 10-12 dollar bottles of oil, stuff that is 5K a 55gal drum
  18. Sunfish
    Sunfish
    Success Mo
    Well, maybe best just to stay with the quarts. Likely not much savings by the gallon anyway...:pete:
  19. Freakingstang
    Freakingstang
    I run my junk a lot... I bought a case of quarts about 4 yeas ago... other than a few 2 gal mix bottles here and there, I still have half that case... its cheaper by the case than the bottle...
  20. clemsonfor
    Any of these synthetic oils mixed at 32/40:1 will be fine in anything.
