What's the Biggest Log You've Ever bucked?
Discussion in 'The Wood Pile' started by buZZsaw BRAD, Dec 5, 2024.
  1. brenndatomu
    Rough...:saw:
    metalcuttr, eatonpcat, Horkn and 4 others like this.
  2. Rick Capper
    Rick Capper
    Pennsylvania
    41 inch pin oak.and that’s big enough
  3. Dunmyer mowing llc
    Dunmyer mowing llc
    Indiana
    IMG_20241013_132302.jpg i failed on this giant chunk of ash.
    My 362c just couldn't do it.
    I didn't have any equipment to move it around with
    We picked it up with my bosses skid steer and will process it there
  4. buZZsaw BRAD
    You could invite Rickyblazin over. :saw:
    metalcuttr, eatonpcat, Chud and 4 others like this.
  5. Horkn
    I'm pretty sure my biggest trees were Max of 50". I've had a few over 40" and that gets difficult when a 20" b&c is the biggest I've got.
    Uh yeah, that was a big one. I recall Scotty Overkill needed to tag team that with 2 saws.
  6. The Wood Wolverine
    My strategy on monsters is to make several vertical noodle cuts like this:
    Then as you buck from either side, a row falls off allowing you to get to the center more. And wedges, lots of wedges, are your friend. I also use a digging iron to pry chunks if they happen to be at or below ground level, so I don't touch dirt with the chain. Massive 118yr old + Oak base
  7. Horkn
    That's probably a better attack mode than I've used on bigger stuff. I'll have to try that out the next time I get some big stuff to cut.
  8. Dunmyer mowing llc
    Dunmyer mowing llc
    Indiana
    Good idea
    John D, metalcuttr, Horkn and 2 others like this.
  9. billb3
    42 inches red oak and with an 026Pro with a 16 inch bar.
    Course, the red oak had stump rot so the heartwood was gone in the trunk until about 15 feet up the trunk so the base of the tree was actually the easiest part.
    The 026 says it still counts.
    John D, metalcuttr, Horkn and 3 others like this.
  10. eatonpcat
    This was a big one, but I believe the one directly across the road from Dennis's was bigger.
    Stumpy75, John D, metalcuttr and 9 others like this.
  11. brenndatomu
    For sure
  12. Scotty Overkill
    Yes.the one across the road was prolly almost twice as big. We measured it but I forget, wasn't it like 13-15' circumference? This is a pic when we were setting climbing ropes in it.....
  13. metalcuttr
    metalcuttr
    western WA
    Those old time logging crew pictures got nothin on you guys! Cool picture!:yes:
  14. metalcuttr
    metalcuttr
    western WA
    Largest I ever bucked was a Doug Fir with my 362c with a 25"bar. It was a downed log about 22 ft long and I could cut all around it except for 10 or 12 inch area in the center that I just couldn't get to. I had an antique one man bucking saw stored in the shop that was still fairly sharp. It reached into the kerf with enough left over for about a 12" stroke. Old technology saved the day! I never actually measured the dia. but you get the idea. 50 something inches.:saw:
  15. iowahiker
    iowahiker
    NE Iowa
    21 1/2 inch red oak downed by stump rot in the home woods with a `14" Makita battery chainsaw. 180 watt-hrs for one cut, all of two 5 amp-hr 18 volt batteries. Makita runs two 18 volt batteries in series to create 36 volts. Oddly, my research indicates there are no "40 volt" lithium batteries, they are all 36 volt. Battery volts have to follow the innate voltage potential of a single lithium cell in a geometric progression, i.e a battery car has LOTS of cells in series and parallel. Anyway, I am up to 5 years of wood using only the 14" Makita.
  16. buZZsaw BRAD
    Broke my record today and almost forgot about this thread. Silver Maple. It was the bottom log off the stump cut in two. Used his MS660 with a 28" bar. Same location as OP. Second pic is their stump cut. IMG_7822.JPG IMG_7823.JPG
