What's the best 2-stroke oil?
Discussion in 'Chainsaws and Power Equipment' started by clemsonfor, Oct 4, 2013.
  1. Moparmyway
    Moparmyway
    New York
    Worst 2 stroke oil for 2 cycle engines with non-adjustable carbs (except autotune and mtronic) is; BelRay H1R
    Reason; The Belray H1R does such a great job at lubricating and not burning in the combustion process, that non-adjustable carbs just cant get enough fuel and tend to run lean. The backpack blower and mini-bike have a lean bog at throttle tip in with BelRay @ 32:1, and without any adjusting needles, there isn't any chance of getting rid of it. Lean down at low RPM worries me at high RPM use under load. Maybe 40:1 would be better and the machines won't have the bog, will wait to try that until after I try all of the other oils @ 32:1.
    mdavlee likes this.
  2. clemsonfor
    But if its 32:1 there is still the same gas in the mix in belray as lucas? So how could one be lean and the other not?
    Curious not trying to pick a fight or anything
  3. Moparmyway
    Moparmyway
    New York
    I believe BelRay H1R oil doesn't contribute to combustion like some other oils do, causing fuel adjustment needles to be open more with BelRay H1R. The non-adjustable carbs just don't deliver enough fuel to feel confident in using BelRay H1R @ 32:1 ..................... will try H1R @ 40:1 in the backpack blower in the future as it was the most effected and had the worst lean bog at tip in. I actually thought I heard it slow down in RPM a few times @ WOT, like when the fuel filter just starts to get restricted. Never ran like that with the Echo synthetic.
    Clem, I think we all know by now that you don't pick fights !
    mdavlee likes this.
  4. MasterMech
    Belray H1R is ester based yes?
  5. Moparmyway
    Moparmyway
    New York
    100% synthetic ester
    MasterMech likes this.
  6. mdavlee
    mdavlee
    When I tride belray first I had a ported 066. It was run with klotz and tuned to 13.7k or so. When I checked it with belray it was 14.6k. It was almost bad enough I needed the bigger jet to tune it. The H was 1.5 turns out. That and the sinus problems I have with it is why I won't use it.
    clemsonfor and Moparmyway like this.
  7. Moparmyway
    Moparmyway
    New York
    Everything I ran it in needed more fuel, but I didn't have any adverse effects from running it.
    I did notice that it made VP smell very differently. Couldn't even tell I was running VP
    mdavlee likes this.
  8. Hedgerow
    Hedgerow
    SW Missouri
    Maybe its a viscosity issue with the belray...
    mdavlee likes this.
  9. mdavlee
    mdavlee
    It may be. The flash point is low on it.
  10. MasterMech
    They don't publish a data sheet on it? Should list the viscosity there.
  11. Moparmyway
    Moparmyway
    New York
    9. Physical & Chemical Properties
    Appearance Oily.
    Oily.
    Physical state Liquid.
    Form Liquid.
    Liquid.
    Color Red.
    Red.
    Odor Mild.
    Mild.
    Odor threshold Not available.
    pH Not available.
    Vapor pressure 0.000009161 hPa estimated
    Density 949.00 kg/m3
    Vapor density Not available.
    Boiling point 539.6 °F (282 °C) estimated
    Melting point/Freezing point Not available.
    Solubility (water) Not available.
    Material name: Bel-Ray H1-R Racing 100% Synthetic Ester 2T Engine Oil
    99280 Version #: 3.0 Revision date: 08-30-2013 Print date: 08-30-2013
    MSDS US
    2 / 5
    Page 3 of 5
    Solubility (other) Not available.
    Specific gravity 0.949
    Relative density Not available.
    Flash point 395.60 °F (202.00 °C) Pensky-Martens Closed Cup
    Flammability limits in air,
    upper, % by volume
    Not available.
    lower, % by volume
    Not available.
    Auto-ignition temperature Not available.
    VOC < 0.5 %
    Viscosity 121 cSt
    Percent volatile < 0.5 %
    Other data
    Flammability class Combustible IIIB estimated
    Viscosity temperature 104 °F (40 °C)
    MasterMech and concretegrazer like this.
  12. Hedgerow
    Hedgerow
    SW Missouri
    So for the same reason it does not carbon up the works, it may not flow as easily...
    Seems there's a trade off for everything in this world eh?
    :coffee:
    Chvymn99 and MasterMech like this.
  13. Moparmyway
    Moparmyway
    New York
    Maple syrup is thinner than H1R, and it takes a lot of agitation for it to completely mix
  14. MasterMech
    I have ester based oils that we use at work, specifically for large industrial vacuum pumps. That chit does not burn. It is awfully hard to get it to ignite. Somebody got the idea to try it in a waste oil furnace. Nuh Uh. I imagine that has quite a bit to do with why it keeps the carbon away.
    Moparmyway likes this.
  15. Hedgerow
    Hedgerow
    SW Missouri
    So does H1R suggest 50:1 mixture? If so, that may be why...
  16. clemsonfor
    H1R recommends 32:1 on engines smaller than like 125cc if I remember right?
    $ooline likes this.
  17. Hedgerow
    Hedgerow
    SW Missouri
    Hmmm... Just when ya think it's figured out, someone throws a monkey wrench in yer theory...
    MasterMech, Moparmyway and mdavlee like this.
  18. mdavlee
    mdavlee
    R50 flashpoint is 550 F.
  19. mdavlee
    mdavlee
  20. mdavlee
    mdavlee
