What's the best 2-stroke oil?
Discussion in 'Chainsaws and Power Equipment' started by clemsonfor, Oct 4, 2013.
  1. mdavlee
    mdavlee
    You'll be fine with R50 then. I do cut when it's below 20 since I can't pick the times I cut around weather.
  2. clemsonfor
    Mike aren't you in Tennessee? Do you have that many days a year your cutting below 20F?
  3. mdavlee
    mdavlee
    I'm right on the TN/VA line. I went the other day and it was 18 when we started. I have cut as low as 4° before.
    PullinMyPoulan likes this.
  4. clemsonfor
    I was just thinking its not that it doesnt and couldnt happen but we usually warm up.
  5. mdavlee
    mdavlee
    It's not that often but some oils say not to use below 32 so I do look at that more.
  6. Sunfish
    Sunfish
    Success Mo
    I'll just work in the shop next to the wood stove if it's below 20...
    PullinMyPoulan and mdavlee like this.
  7. clemsonfor
    Below 32 ouch thats not that cold.
    $ooline likes this.
  8. MasterMech
    Says the guy in SC. :rofl: :lol:
    I put on a sweatshirt if I gets below 32 here. :D
    $ooline, clemsonfor and mdavlee like this.
  9. clemsonfor
    Not sure what I meant here?
    I think I was trying to say its not hard to hit 32F when cutting?
    $ooline likes this.
  10. Moparmyway
    Moparmyway
    New York
    Now its time to mix one tank at a time and see how they each do with the VP94.
    Horkn, LongShot, Chvymn99 and 3 others like this.
  11. Moparmyway
    Moparmyway
    New York
    Does anyone remember which 2 cycle oil VP uses in their 50:1 pre-mix ?
  12. $ooline
    $ooline
    WI
    Will be interesting to see what you can determine. FWIW I've put 3 tanks through my new 461 with lucas at 40:1 at the richest the H will allow with limiter tabs in place. Saw runs good and the carbon that is deposited on the clutch cover, not much by the way, pretty much wipes right off. H1R was like this, maybe a touch better in this regard. Now is this anyway to judge an oil? No idea really, just was something I noticed.
  13. redneckdan
    redneckdan
    Northern Minnesota
    If it gets below 32 I put pants on...
  14. mdavlee
    mdavlee
    I think it is motul 710 or 800
    Moparmyway likes this.
  15. Moparmyway
    Moparmyway
    New York
    Thanks !!
    Thats the first one I will try then :yes:
  16. mdavlee
    mdavlee
    You're welcome. I'm in my last liter of it now. I have one more of K2 then I've got to buy some more.
  17. Moparmyway
    Moparmyway
    New York
    Which oil will you be getting ?
    More K2 ?
  18. mdavlee
    mdavlee
    Probably be klotz since it's cheaper.
  19. Moparmyway
    Moparmyway
    New York
    R50 ??
    Lucas was the least costly from all I have purchased, want some to try ?
    I have a few empty 379ml bottles from H1R that I use to mix gas and oil in before I put it in the jug. I can fill it with 12oz of Lucas and send it
  20. mdavlee
    mdavlee
    R50 or original techniplate. I can get Lucas at OReilly's.
    clemsonfor likes this.
