What's on your bench now?
Discussion in 'Chainsaws and Power Equipment' started by Czed, Jun 29, 2020.
  1. Czed
    Czed
    Wv
    I built this 372 clone with a hyway popup bb kit
    A couple year's ago
    Then mounted it in a alaskan mill
    And never used it.
    It sat in a unheated barn
    It had regular pump gas with ethanol.
    I got it out and it would barely pull over
    The aluminum cases had corroded
    And the bearings were full of a caulk like
    Putty.
    No rust on the crank or bearings
    So I cleaned and flushed the case.
    It freed the bearings up
    The are very smooth now.
    I've since ran 10 tanks through it
    No issue's at all it's a strong saw
    I mixed 8 gallons of efree for my saws.
    Sandhillbilly, J. Dirt and M2theB like this.
  2. J. Dirt
    J. Dirt
    Ever do an ethanol fuel test? I had heard about taking a glass jar putting some water in and marking the water line with a sharpie. Then put some fuel in and shake it up. If there’s ethanol the water will be higher than the original mark once it settles and sits a while. Haven’t tried it, but heard it works.
  3. Czed
    Czed
    Wv
    The stihl dealer here tested fuel
    And even though it's supposed to be 10% max
    He had some over 30%
    I just left old mix in it from a job I did
    All my other saws are in a heated garage
    And stored dry.
  4. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    I think I finally got rid of the off of idle bog. New after market carb .... $20 fix to cure hours of aggravation .:mad: I’ll know for sure Saturday
  5. The Wood Wolverine
    SKEETER McCLUSKEY likes this.
  6. M2theB
    M2theB
    Central Massachusetts
    Been dealing with the 572 running poorly but haven’t gotten into it other than to talk about it and have it checked on the CST, with no flags coming up.
    Yesterday I did a vacuum on the primer of the carb, sat! Moved to pressure test and got the above results
    Actually pretty happy I found it, or something
    Explains how it was running
    Czed, The Wood Wolverine and Chud like this.
  7. M2theB
    M2theB
    Odd that new saw with less than 10 tanks would do this.
    All VP Non E fuel and XP oil.
    Thinking this crap was a stow away between the tank and the carb from manufacture
    Cleaned the carb and hold pressure like a champ
  8. M2theB
    M2theB
    And?
    Sandhillbilly likes this.
  9. Sandhillbilly
    Sandhillbilly
    Seems ok, no bogging, but don’t seem seem to wrap up enough. I think I need to lean up the high side. Starts nice. So it’s damm sure better than it was.
    M2theB likes this.
  10. Czed
    Czed
    Wv
    It has several cups of water in the tank and the lines had crap in them IMG_20210417_131711.jpg IMG_20210417_133410.jpg
    Runs perfect mowed the yard.
    If these set a while the plastic tanks will pull moisture
    Just unhook the fuel line at the pump
    And pressurize the tank
    It will purge the water and crap out.
    M2theB and Chud like this.
  11. The Wood Wolverine
    Replacing the low frequency amp in a Klipsch 2.1 speaker system. Also a few other caps and resistors that are a know issue.
    31766E70-5AAA-4939-93ED-11D145BCEE6B.jpeg 23281736-9998-4587-80A1-8EC0FEC56733.jpeg
    Toasty!
    M2theB likes this.
  12. MAF143
    MAF143
    North Central OH
    I always liked working on audio equipment. I used to build custom speakers. I haven't done much of that stuff in years though. I always enjoyed having a system that sounded like 5th row center at a concert.
    :dancer:
    M2theB and The Wood Wolverine like this.
  13. The Wood Wolverine
    Yep, I have that..
    MAF143 likes this.
  14. The Wood Wolverine
    Got the amp/power supply boards fixed.
    System sounded good for about 30 seconds, then I turned it up a bit. Distortion from the sub. Dammit.
    Replacement driver on order. :makeitrain"
    Tonight’s job:
  15. M2theB
    M2theB
    is that for the tweeter?
    what are we looking at ? Some in line 4 barrel for....?
  16. The Wood Wolverine
    The low frequency sub amp was a problem for these systems and burned out regularly. There’s a guy that sells refurb kits that replace that board and a few other pieces on the power supply board (that got damaged from the heat of the toasted amp/board). And they used an inferior foam surround on the 6.5” subwoofer. I inspected mine and it appeared ok when I bought the kit. He also sells refoam kits and I passed on that. After firing it up, mine tore the whole way around. Most people’s disintegrate completely.
    Screenshot:
    And the cooling fan kit he sold me is not working.
    https://youtube.com/shorts/s2t8Axt9oLk?feature=share
    Plan is to try a 12v supply in place of the current 7.5v one.
    Did a full carb rebuild on a Yamaha 600cc sport bike. I’ve been moonlighting at the bike shop. :yes:
    Chud likes this.
  17. Czed
    Czed
    Wv
    Digging through old totes
    I found a new 272 hyway popup piston kit and a 288 piston kit
    They must've come with parts
    I bought from someone.
    I just ordered 2 266/268 popup and 2 272 popup Piston kits from hyway
    They are only 23.00 or so if you buy from the company IMG_20210424_111825.jpg
    I like the one in a 266 I run all the time
    Need to find the time to finish
    These and 2 288s and for a neighbor another 288 and 272.
    Sandhillbilly and M2theB like this.
  18. Czed
    Czed
    Wv
    Got a 266 in from kansas
    It's a 84 model
    The choke lever was popped out of socket
    I'll refresh everything
    Before using it.
  19. MAF143
    MAF143
    North Central OH
    There are several places that sell the re-foam kits. I've done several over the years, even my beloved EV Interface Bs. I've often heard other speakers and thought they might be better, but after getting home and sitting down to listen, I have always ended up satisfied with my EVs. I find it hard to justify spending thousands to replace something that I find rather pleasing. I had purchased some Polk towers when the foam surrounds on the EV's failed and they sound pretty good, but... I guess my ears have been tuned into the EV's over the years. I had purchased them new in 1978.
  20. The Wood Wolverine
    I've watched a bunch of videos about surround replacement. Some of those I feel are straight up hacks doing it. The one method that I buy into is removing the drivers dust cap and properly centering the voice coil in the gap. Then gluing the new surround. That's pretty invasive surgery and I'm not sure I wanna. Glad my main listening speakers don't have the kind of surrounds that rot. I bought equipment as a way to establish credit when I was living at home, and still in high school, so I didn't skimp. Glad I did as I still enjoy that quality gear. I grew up around good sound as my parents were music lovers. They bought a Marantz receiver when I was a young pup and they still use it. Had Ultra Linear speakers that I remember well. Looked like this:
    I also remember the day he burned them in a huge junk pile. I sold them my old Polk 10b's when I bought the K's. I've grown accustomed to them over the years and continue to be satisfied, for the most part.
    MAF143 likes this.
