What's on your bench now?
Discussion in 'Chainsaws and Power Equipment' started by Czed, Jun 29, 2020.
  1. M2theB
    M2theB
    Central Massachusetts
    60FF06C4-7B50-4951-9348-E01242091B28.jpeg It went on the bench this morning. Figured if it starts like a flooded saw it must be. Pressure tested the carb through the fuel line in the tank and after two pumps, the bench was a puddle of gas coming out the venturi. Meter valve not holding at all.
    Pressure tested a carb from a parts saw and held. Swapped carbs and it’s a runner!
  2. J. Dirt
    J. Dirt
    Oh he got it done alright!
    Looks pretty sweet on my bench next to my trusty old 55! 4F279F27-8A67-40FA-BC77-A3CF3387D346.jpeg
  3. M2theB
    M2theB
    who’s in the middle? 288?
    Mag Craft, Sandhillbilly and J. Dirt like this.
  4. J. Dirt
    J. Dirt
    Yep. Waiting on a carb and fuel line. Hopefully be able to fire it up by the weekend. It was a full tear down rebuild 143D48DE-58C7-43F2-9D0C-D2A07D8AA416.jpeg
  5. J. Dirt
    J. Dirt
    Ps it’s not a lite. That’s just the replacement recoil cover..
    Sandhillbilly, Chud and M2theB like this.
  6. The Wood Wolverine
    I ordered a carb kit for the Jonsey and it was supposed to arrive this past Saturday the 23rd. :headbang: USPS has been absolutely horrible.
    I had the saw all together and gave it about 3-4 pulls and it started puking fuel out of the decomp valve and muffin. When I had it tore down, I only looked at the pump diaphragm. It was spotless in there so I thought I was good. Turns out the other diaphragm had what looked like a kink in it.
    And I decided to clean up the original cylinder. Looks like some serious detonation.
    I used a Mike (T4 driller) trick to clean up the squish band.
    A little mini shop vac nozzle fit in the piston, then a drill bit extension into the drill.
    Yahtzee. Wish I would have tore down the saw before I bought the full kit. I could have gotten away with just a piston replacement.
    This piston fooled me pretty good through the exhaust port. I figured the cyl. was toast.
  7. M2theB
    M2theB
    I like that trick!
  8. M2theB
    M2theB
    Metering valve screen from a Walbro WT 194 on the left. Plastered!
  9. J. Dirt
    J. Dirt
    Had a couple of those lately. Even when pulling out the tiny Welch plugs, finding that good stuff under them.
    Sandhillbilly, Horkn and M2theB like this.
  10. M2theB
    M2theB
    7BABBE40-892F-46E3-9C2A-AF675EA115FA.jpeg CECC60B6-E915-4FA9-BE6D-448E0A45194F.jpeg
    This is more like what I’ve come across. Mostly wet gunk sucked up from a tank I should’ve rinsed or rinsed better. Or Homelite fuel lines that disintegrate into shards of plastic
  11. J. Dirt
    J. Dirt
    :drool::beerbbq: Yummmm...
  12. M2theB
    M2theB
    C057B8BD-3C63-493E-80BE-F2A31387BD3D.jpeg 1A4CDF4E-2DAF-4A50-BB3A-D8FE9429390D.jpeg D0DE3112-5A84-491E-BD7F-D9E105A8D0F7.jpeg 8E1B895A-5457-47C8-BF26-AB1179E86F6D.jpeg F2833076-21C0-4013-BA9C-2843CC49E0CE.jpeg
    Picked up a bucket of 162SE today. Only thing missing, so far, was a chain tensioner and clutch cover/brake. No b/c either.
    Pulled those from a 61 parts saw and put it together just to have look.
    Piston looks ok.
    This one might be next once I get parts and finish what’s in pieces now.
  13. The Wood Wolverine
  14. M2theB
    M2theB
    ill share
    But yeah, that’s powder coat on that intake!
    J. Dirt, Sandhillbilly and Horkn like this.
  15. J. Dirt
    J. Dirt
    Ahhh air filters are over rated....
    Sandhillbilly and M2theB like this.
  16. J. Dirt
    J. Dirt
    On to an 042av that needed some freshening up for a friend. B9166338-E3A0-4076-9B68-94F3BEDC9239.jpeg
    Markds2, Czed, M2theB and 3 others like this.
  17. Czed
    Czed
    Wv
    ropes and a am 272 recoil on this 266xp with a 268xp cylinder and a 268 hyway popup
    No base gasket.
    I need to comp test it.
    I replaced the starter pawls and springs today
    And rebuilt the original 266 recoil with
    True blue
    I only have three tanks on it
    Feels very strong for a non ported saw.
    M2theB and Sandhillbilly like this.
  18. Czed
    Czed
    Wv
    My sister's 5 year old generator
    It only had 5 hour's on it
    Turns out the intake valve stem
    Snapped off at the collet
    Poor heat treatment looks like.
  19. Czed
    Czed
    Wv
    Got some of my favorites ready yesterday
    My tomcat drug in a feral kitten
    It's tamer now.
    Stephiedoll, M2theB and Chud like this.
  20. Czed
    Czed
    Wv
    Scotty Overkill and M2theB like this.
