What's on your bench now?
Discussion in 'Chainsaws and Power Equipment' started by Czed, Jun 29, 2020.
  1. M2theB
    M2theB
    Central Massachusetts
  2. happysawer4741
    happysawer4741 Banned
    Houston Texas
    Well if i get the $2,000 i have made room for a niec new Stihl 462, if just the $600 a new bar and some chains for my smaller Stihl saws.
  3. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    Is that a newly acquired one? or one of your high privates?
    M2theB and The Wood Wolverine like this.
  4. The Wood Wolverine
    I’m working on the Jonsered 2245 I was given. Put a 2250 oem top end kit on it. Missing the worm gear and the flywheel nut.
    Nice plating on it.
    And a roached 55 my cousin gave me. It too got a new oem top end kit. Looks like it’ll be pretty clean when finished. Missing an ex gasket and a couple smalls.
    Probably sell this one when done.
  5. J. Dirt
    J. Dirt
    Love me a 55!!!!
    How much? :binoculars:
  6. J. Dirt
    J. Dirt
    After a year finally had time to put this 266xp together. Full case split rebuild. New OEM two piece coil, oe seals and bearings, oe cylinder with a little massage, no base gasket, meteor piston, caber rings, custom felling dogs, custom full wrap handle, oe tillotson carb kitted, oe fuel and oil lines. Hope to get it in some wood soon!
    B3A3D377-333D-4351-B188-FBA12C35EA9B.jpeg 3041A6C4-13BF-4645-B592-C93D807FA339.jpeg
    Eric Wanderweg, Markds2, Czed and 5 others like this.
  7. The Wood Wolverine
    Probably ask $200ish. In my area I've seen 'em at $200-$250. I have a case with it too.
    M2theB, Sandhillbilly and J. Dirt like this.
  8. Sandhillbilly
    Sandhillbilly
    Does someone need to update the title of this thread to ...on your bench 2021?
    Or do we just start a new one for 2021? I’ll let the older members sort that out.
    Anyways.... here is a picture of my new chainsaw repair station at work. It’s not much of a bench in size, but it is better than what I’ve been using. It’ll let me keep all my tools that I use on saws and some smaller parts all in one place. I’ll need to get a FHC sticker on it when the swag shop opens. Probably a Husqvarna sticker too. The 357 on top is just a prop for the picture. E79C7385-A550-4C26-BAA3-28C4921AD6AF.jpeg FAB5AF92-9D3E-4797-97BC-239B837FE2FF.jpeg
    what do you think about the color?
    Czed, Chud, J. Dirt and 3 others like this.
  9. M2theB
    M2theB
    love the color
    Where’s the saw?
  10. J. Dirt
    J. Dirt
    I’ve got the same cart!
    It’s really a nice box for the price and seems well built.
    M2theB and Sandhillbilly like this.
  11. Warner
    Warner
    Until the lid pistons get weak and it slams down on your knuckles! Ask me how I know.... the pistons are easily replaceable with better stuff!
  12. M2theB
    M2theB
    Picked up a couple signs today. For the garage bench. It was cheaper per each to get the two. Let me know if anyone is interested in one. I’m only keeping one for the garage bench.
    Going back together with the 357. Gasket delete netted an 023 squish. I’m good with that. Only replacing the fuel and impulse lines and the partition wall to get the metal clamp instead of the plastic clip, although it was still pretty tight.
    Deererainman, Czed, J. Dirt and 4 others like this.
  13. Sandhillbilly
    Sandhillbilly
    Had my 357 apart last week trying to get rid of the bog coming off idle. I gained some but don’t think it is perfect yet, need to get it into some wood & see for sure. First time I’ve ever had a cylinder off of a saw. Thought about a gasket delete but don’t have any sealer for that, yet.
  14. The Wood Wolverine
    Might be interested in one. I’ll send a pm.
    The 2245 that I was given sheared the nub/key on the flywheel. Couldn’t source a used one and new was too expensive. So I cut a piece of copper wire and ground a little channel for it to catch. Then used some retaining compound and tightened it up. That was yesterday so I’m hoping to fire it up today.
    DD5B61E6-5D5F-46CD-812A-58FDA082005F.jpeg 807E63D0-0A8E-4E08-AB98-969D6BF9CEEE.jpeg 282FC01B-E9BD-43D5-B1AD-94FE54B93F0E.jpeg
    J. Dirt, Sandhillbilly and M2theB like this.
  15. M2theB
    M2theB
    standing by...
    I’ve found some of the hardware stores around me have lots of woodruff keys in the section with the stocked / managed hardware. Finding the right size is the hunt. But they’re in the $.67 range.
  16. The Wood Wolverine
    Forget if I asked, did you eliminate the auto decomp on that? I know that killed a few of 'em.
    J. Dirt and M2theB like this.
  17. M2theB
    M2theB
    I haven’t yet. I’ve got a few plugs hanging around and will be going that way. I don’t think the 357 will need one.
    J. Dirt likes this.
  18. M2theB
    M2theB
    9F76BDC6-EC8E-4A03-8E28-58DACBDB5034.jpeg 84BEBCEC-2E71-460E-BB03-70DE64A2D0CC.jpeg FA9D8FAD-C07B-4B14-80D5-A157EAB61376.jpeg
    Back together.
    I got stitched up last week so I won’t be attempting to start it another week and a half. It’ll give the Yamabond a good long stretch to set up
  19. Sandhillbilly
    Sandhillbilly
  20. M2theB
    M2theB
    0CEC0447-640B-4EC9-AB40-AD095EE11494.jpeg F0B3D636-4882-41E2-826E-8D4346497818.jpeg E1AB5FD8-6C8B-4DE4-834C-8F95DFC1E947.jpeg 52D7D703-48BF-43A9-BB85-D5638F914298.jpeg
    CL score. Advertised as needing a new carb, “according to the shop.”
    It will run if started like a flooded saw, trigger squeezed. Won’t idle though. Not on the bench yet, but maybe on deck. Awfully clean.
