What's on your bench now?
Discussion in 'Chainsaws and Power Equipment' started by Czed, Jun 29, 2020.
  1. Eggshooterist
    Eggshooterist
    Erff
    Nice! That should throw some chips.
    John D likes this.
  2. John D
    John D
    Syracuse ny
    This is how I restart my 562xp
  3. Eric Wanderweg
    Last May I picked up this 372XP. After a few test cuts I realized that it needed crank seals. It sat under my bench, untouched until last month when I got motivated. Upon seeing the intake side of the piston, I decided to pull the cylinder off and ordered a new piston and ring while I had it apart. I’m trying to get everything cleaned up but this is hands down the dirtiest saw I’ve ever dealt with. I sprayed super clean on all the grime several times and it won’t touch it. Out of desperation today I brought it down to the car wash and blasted it with the high pressure power washer with warm soapy water. Most of the grime is still there! It’s like hard carbon buildup, and has to be chipped off with small screwdrivers. I wonder if this saw cut a lot of pine and the grime is a mix of pitch, sawdust and oil, cured onto the cases after many hours of heat cycling? At this point I’m tempted to split the cases, order new bearings and start from the bottom up… Or just get whatever I can easily get off and call it good enough. I dunno. Hard to put a saw back together with junk in all the crevices.
    RCBS, Dok440, Eggshooterist and 4 others like this.
  4. farminkarman
    farminkarman
    Neenah, WI
    Doing another Husky 365 Special. Will post more pics when I’m done with it. IMG_8887.jpeg IMG_8888.jpeg IMG_8889.jpeg IMG_8892.jpeg IMG_8893.jpeg
    MNWood, RCBS, Dok440 and 9 others like this.
  5. Eggshooterist
    Eggshooterist
    Erff
    John D and farminkarman like this.
  6. farminkarman
    farminkarman
    Neenah, WI
    Thanks! These things run pretty darn good after the treatment. The vibration of a 372xp never bothers me, but I can definitely tell that the 365 has less which makes them a very nice firewood rig.
  7. Eggshooterist
    Eggshooterist
    Erff
    Less vibration the better.
  8. Eric Wanderweg
  9. Dok440
    Dok440
    NorCal
    Definitely sawing pine when the sap is running. It's like concrete. Once the sap is on the saw it just starts collecting anything and everything the saw comes in contact with. It will take gasoline and penetrants like WD40 and mechanical scraping to get it all off. Acetone will work but it will also hurt the paint. Good luck!
  10. Dok440
    Dok440
    NorCal
  11. farminkarman
    farminkarman
    Neenah, WI
    I’m still learning, and I don’t do a lot of saws, but they are fun to transform into wood eating machines.
  12. farminkarman
    farminkarman
    Neenah, WI
    Thanks, I will try to remember to post some more on it.
    Dok440, John D and Eggshooterist like this.
  13. Dok440
    Dok440
    NorCal
    Fixing it, genuine Husky. All better now :D
    Eggshooterist, Skier76, RCBS and 5 others like this.
  14. Eric Wanderweg
    I ended up biting the bullet and splitting the cases. The connecting rod felt just a little too sloppy on the crankshaft so I ordered a crank, bearings and gasket kit. Also a new West ignition coil since I’m spending money :makeitrain" So now it’s going to be my first bottom up rebuild.
    Eggshooterist, Dok440, John D and 3 others like this.
  15. farminkarman
    farminkarman
    Neenah, WI
    365 special cylinder finished
  16. Dok440
    Dok440
    NorCal
    Excellent choice! 372's are great saws and yours will be like new.
  17. farminkarman
    farminkarman
    Neenah, WI
    Eggshooterist, Dok440, John D and 4 others like this.
  18. farminkarman
    farminkarman
    Neenah, WI
  19. Dok440
    Dok440
    NorCal
    I'd be interested to know how you like the 550. Is it a worthy successor to the 346?
    farminkarman and Eggshooterist like this.
  20. Dok440
    Dok440
    NorCal
    This 026 was bought for the dad by my mom back in the early 80's. He only used to for a few years. Fast forward to 2000 and my wife and I moved into our first house. We were in the mountains and needed to burn wood due to not being able to afford the propane bill. Dad gave me this 026 that had been sitting for 20 years. Me being an idiot threw fuel and oil in it and proceeded to seize it in just a few minutes. Big air leak from the cracked fuel hoses and intake. At least I learned what a lean condition sounds like :D At the time a Stihl piston and cylinder cost more than a new saw so rather than fix it I bought a Husky 350. I kept the saw hoping some day to fix it. It turns out the aftermarket makes piston/cylinder kids for older 024's now. The time has come!
    What do you think- go ahead and replace the crank seals? They are 40 years old. I have a carb rebuild kit, new fuel lines, intake boot, piston and cylinder and gasket and seal rebuild kit. Anything else I should do while I have it apart?
