What's on your bench now?
Discussion in 'Chainsaws and Power Equipment' started by Czed, Jun 29, 2020.
  1. Eggshooterist
    Eggshooterist
    Erff
    Its back together. I removed all carbon from piston, combustion chamber and exhaust port. Freed up the ring and cleaned the ring grove. I polished the edges of the pits where the plating is chipped. Flap sanded the bore some. Deleted base gasket. It has noticeably more power. I'll get a video today. Those pits are below the ring travel area so maybe the plating wont flake off. I really have nothing to loose but my time, which, as a hobby, I don't count.
    Dok440, Deererainman and John D like this.
  2. Eggshooterist
    Eggshooterist
    Erff
    https://photos.app.goo.gl/GcWxjYiT2QeQvJ7F8
    I wish I had thought to tach it before and after. You can hear it running higher RPM from the first video to this one. I'll run a few tanks through it. If it still acts and sounds like this, I might just buy that sawzillaparts.com proline piston kit for $25 and take a chance the plating stays put. We shall see. Its just a back-up unit as I have a nice echo handheld thats much newer that we bought new in 2016.
    Deererainman, John D and MAF143 like this.
  3. Eggshooterist
    Eggshooterist
    Erff
  4. Eggshooterist
    Eggshooterist
    Erff
  5. lukem
  6. John D
    John D
    Syracuse ny
    A little looser and that saw will rip
  7. Eggshooterist
    Eggshooterist
    Erff
    Thats the performance setting. :thumbs:
    ammoaddict, MNWood and John D like this.
  8. Dok440
    Dok440
    NorCal
    I picked up a MS361 on market place. I pulled the muffler and the piston/cylinder look perfect. The only issue was the oiler not oiling. I pulled the pump and blew a puff of air from the port at the pump that goes to the port by the bar. Out shot a goober of muck. I went ahead and changed the intake tube/filter and the sealing ring because they were starting to harden. It is oiling fine now.
    Chud, Skier76, MNWood and 10 others like this.
  9. Eggshooterist
    Eggshooterist
    Erff
    Easy fix. Nice.
    Dok440, MAF143 and John D like this.
  10. Dok440
    Dok440
    NorCal
    I got a delayed Christmas present from my wife and sons, was not expecting this at all!
    This is my first smart saw. Is there anything special I need to do on the first startup?
    M2theB, Rope, MNWood and 5 others like this.
  11. The Wood Wolverine
    :dex::dex::dex:
    Chud, John D and Dok440 like this.
  12. Dok440
    Dok440
    NorCal
    I have run 5 tanks through it so far and it is working great. I have been having trouble restarting after it cools down for 10min or so. It seems to want one pull on choke, turn choke off and four more pulls.
    Chud, John D and Eggshooterist like this.
  13. Mrxlh
    Mrxlh
    Dat Boot
    Don’t think so as far as break in goes, the new saws love extra oil though. 40:1 would be the leanest I would run in them. I prefer 32:1 myself.
  14. Dok440
    Dok440
    NorCal
  15. The Wood Wolverine
    Hot restarts on all my Husky’s are best done on fast idle, not choke. I realize you weren’t talking about the 562 but get in that habit for it.
  16. Mrxlh
    Mrxlh
    Dat Boot
    Might be time to re-kit the carb…
    Eggshooterist and Dok440 like this.
  17. Dok440
    Dok440
    NorCal
    Good to know! I generally run 40:1. I'll mix up some 32:1 for the first gallon.
    John D likes this.
  18. Dok440
    Dok440
    NorCal
    Will do! Thanks for the information!
  19. Dok440
    Dok440
    NorCal
    Yeah, I think you are right. It will make me feel better knowing what condition it is in. I also want to get a look at the fuel hoses too.
  20. Eggshooterist
    Eggshooterist
    Erff
    Thank you. Its a low use saw by the looks of it.
    John D likes this.
