What's on your bench now?
Discussion in 'Chainsaws and Power Equipment' started by Czed, Jun 29, 2020.
  1. Backwoods Fellin'
    Backwoods Fellin'
    Nashville TN
    Hope I never have to tear mine down:picard:
    Eggshooterist likes this.
  2. Eggshooterist
    Eggshooterist
    Erff
    It's not as bad as it looks / sounds but it wasn't fun either. Lol.
    Backwoods Fellin' likes this.
  3. Eggshooterist
    Eggshooterist
    Erff
    Next saw ripping n ready to sell from that pile of 15 poulan / craftsman saws.
  4. ammoaddict
    ammoaddict
    Granite Falls, NC
  5. Eggshooterist
    Eggshooterist
    Erff
    As we've learned, loose chains equal more horsepowers.
  6. ammoaddict
    ammoaddict
    Granite Falls, NC
    Yep, right up until they fly off.
    John D, J. Dirt, John041 and 2 others like this.
  7. Eggshooterist
    Eggshooterist
    Erff
    That picture was staged just for you. :handshake::rofl: :lol:
    John D, J. Dirt, John041 and 3 others like this.
  8. ammoaddict
    ammoaddict
    Granite Falls, NC
    Thanks. I needed that.
    John D, J. Dirt and Eggshooterist like this.
  9. MAF143
    MAF143
    North Central OH
    I'm working on a few saws for some of the guys around here. I run into all kinds of issues as most of these saws are rode hard and put away wet...
    Jonsered 2065 turbo with broken chain tensioner is getting a MM and base gasket delete if squish can handle it.
    MS291 with trashed piston, bad carb, broken off oiler bolt due to a bearing failure, oiler is trashed too.
    MS391 with a bunch stuff, but the cylinder was losing plating. I can't locate an aftermarket cylinder with the same intake configuration to it's just getting put back together and is pretty much just a parts saw now but he'll probably run it till it destroys itself.
    Easy out to the rescue...
    bearings off...
    bearings on...
    I picked up a couple more big duffle bag style luggage pieces at a local thrift store I can use for rope bags... 5 bucks for both of them. Zippers all work. I have a couple of 200' bull ropes that I didn't have bags for. I like keeping all the ropes in bags so I'm not always un-tangling them.
  10. Eggshooterist
    Eggshooterist
    Erff
    Did you sawzilla for the 391?
    John D likes this.
  11. Eggshooterist
    Eggshooterist
    Erff
  12. MAF143
    MAF143
    North Central OH
    Unfortunately that is not the one I need for this saw.
    John D and Eggshooterist like this.
  13. Eggshooterist
    Eggshooterist
    Erff
    Bummer.
    John D likes this.
  14. Eggshooterist
    Eggshooterist
    Erff
  15. Eggshooterist
    Eggshooterist
    Erff
    Now look at what its inside looks like. These were taken an hour after the video. This thing starts in 1-3 pulls and I've ran 1/2 gallon or more of mix through it like this.
    20250103_151033.jpg 20250103_151403.jpg 20250103_151254.jpg 20250103_143914.jpg 20250103_143926.jpg 20250103_143839.jpg 20250103_143859.jpg 20250103_145636.jpg 20250103_145649.jpg
  16. Deererainman
    Deererainman
    Union City Ky
    Supprised it ran that well. You gonna try to clean up the cylinder or is it far gone?
  17. Eggshooterist
    Eggshooterist
    Erff
    I used some acid to remove the aluminum transfer and found the plating damaged. Those white spots. I'm going to unstick the ring, smooth out the pits, clean the exhaust port out and run it. I only use it for sweeping the garage and light stuff. I have almost nothing into it. I got it, another blower and a trimmer for $3.50. This blower and the trimmer run.
  18. Deererainman
    Deererainman
    Union City Ky
    I've never used acid to remove the aluminum transfer, but noticed a lot of folks use that method. I've always used a flap disc on drill to clean the cylinder up. Took a 1/4 piece of round stock, cut a slit and added a strip of sandpaper and went to town.
  19. Eggshooterist
    Eggshooterist
    Erff
    I usually finish up with your method.
    Deererainman and John D like this.
  20. Deererainman
    Deererainman
    Union City Ky
    :cheers: I saw a YT video of that Monkey feller down in Tennessee (Mastermind) and it's worked for me. I wound up making a fixture?, Tool for use with the Foredom. Looking forward to seeing it back up and running.
