What's on your bench now?
Discussion in 'Chainsaws and Power Equipment' started by Czed, Jun 29, 2020.
  1. Czed
    Czed
    Wv
    They feel much lighter in hand the skirts are noticabley thinner than the 288 piston
  2. The Wood Wolverine
    Prepping for tomorrow’s black locust. Flipped the bar, cleaned the groove, greased the tip, fresh chain, cleaned the air filter and greased the clutch drum bearing.
    She’s ready to rip.
  3. Eric Wanderweg
    I picked up this 372XP a couple weeks ago for $450. It came with four 24” bars and chains. The muffler was dented and it ran a little off, but it seemed like it was worth a gamble. After getting the muffler off, the piston looked fantastic and still had the machining marks on most of it. I put an aftermarket replacement muffler on it from Bailey’s. I’m just now getting into it further, cleaning it up (pine sap residue and fine dust everywhere) Going to clean up the carburetor and replace the spark plug. I’ve never seen a plug so bad!!! :hair: :picard: I wonder if he was running cheap super tech 2 cycle oil? No doubt the plug has a lot to do with it not running perfect. Either way, I’m excited to finally have a 70+ cc saw and am looking forward to putting it to work this fall when hoarding starts up again.
    D9A8546C-7657-4C4C-822B-410C2703598C.jpeg FEB99444-FE9C-462A-A326-B9557B60776D.jpeg 91554F8A-52B9-4434-93DB-72188C4C4B10.jpeg ACE0CB9F-BEB0-4822-AA8A-C5B8E6F2817B.jpeg
  4. The Wood Wolverine
    Wonder what the intake side of the piston looks like after seeing that plug. :jaw:
    Horkn, brenndatomu, Mrxlh and 2 others like this.
  5. Eric Wanderweg
    I’ll find out soon enough o_O
  6. Mrxlh
    Mrxlh
    Dat Boot
    Throw an unlimited coil on it and you’ll be good to go, id say that is a pretty decent score for the price.
  7. Timbersport
    Timbersport
    Just about ready to be taken off the bench, early model Echo 601..... 20240526_082327.jpg 20240526_082343.jpg
  8. Czed
    Czed
    Wv
    Supertech is much preferable to stihl ultra by me and my logger friends.
    MAF143, Horkn and Eric Wanderweg like this.
  9. Czed
    Czed
    Wv
    I finally found a oem 372 cylinder for it
    And had randy port it
    This chassis is my favorite of the 3 series I'm left handed and the straight across bar is more comfortable to me.
  10. Lehman
    Lehman
    Minnesota
    Serious question, is it really that hard for a left handed person to run the saw right handed like it’s designed? That slope of the top handle is designed to keep the bar from hitting you dead center if you have a kickback event and loose grip on rear handle. They say the only safe way to run the saw is right handed no matter how you do everything else. But I see lots of lefties doing it the other.
    Horkn, Eggshooterist and ammoaddict like this.
  11. Eggshooterist
    Eggshooterist
    Erff
    Driving a stick shift must be impossible too...:rofl: :lol::rofl: :lol:
    Ron T and Backwoods Fellin' like this.
  12. Horkn
    Yeah, I forget who actually makes super tech, but it's actually good oil.
  13. Horkn
    I have a buddy that's a lefty. He runs his saws righty though
    ammoaddict likes this.
  14. Lehman
    Lehman
    Minnesota
    It used to be bottled by warren
    Horkn likes this.
  15. Scotty Overkill
    I have two saws going into the basement shop for emergency surgery this week, one of my 044 slant fins needs the oiler worm drive replaced and and one of my MS440's that needs major muffler repair (the entire muffler broke off around the cylinder mounting bolts) never seen that before. I'll take some pics when I pull it apart. I normally don't work on saws this time of year but these are two of my workhorses so I need them fixed......
  16. Czed
    Czed
    Wv
    Fixed this redmax/Husqvarna 353
    The sawdust built up and kept the diaphragm from working IMG_20240622_092618.jpg IMG_20240622_083951.jpg
    I bought this to clean saws it does a good job
    He has 4 more of these for me to fix he bought them new about 20 year's ago.
    brenndatomu and Eric Wanderweg like this.
  17. Czed
    Czed
    Wv
    IMG_20240616_105224.jpg I was on the Facebook neotec page and they were offering customer returned saws no warranty for 137.00 shipped IMG_20240613_020606.jpg
    I ordered a nh395 clone but they sent me this nh365 by mistake
    I didn't want it but it was so much hassle to return it they offered me a return 895 for 122.00 shipped so i ordered one IMG_20240627_112137.jpg
    The chain brake was engaged and you couldn't put it on the saw
    That was the only issue
    I reset the brake fueled and oiled it and put a new 28" bar and chain on it
    Started right up and oils good
    I'll try it tomorrow.
  18. Eric Wanderweg
    You made out like a bandit on that deal!
    ammoaddict, Czed and brenndatomu like this.
  19. Czed
    Czed
    Wv
    I got lucky
    It's a gamble what you get
    Also in the box is a new 114dl .63 gauge full chisel chain.
  20. Czed
    Czed
    Wv
    I had dj /beaglebriar/ cut down 066 pistons for my holzfforma 288s IMG_20240707_114209.jpg
    I had to mark and trim the piston pin bosses to allow the 288 rod to fit
    Running a 066 wrist pin and bearing
    I shaped it with a Dremel then put the disc on the mandrel while in the piston and trued up each side. IMG_20240707_125019.jpg IMG_20240707_131914.jpg IMG_20240707_182854.jpg
    Very high compression you really have to want it to start it
    It feels locked up nobody will borrow this saw
    DJ ported this non decomp 288 cylinder
    It's a strong runner i heat cycled it today.
