What's on your bench now?
Discussion in 'Chainsaws and Power Equipment' started by Czed, Jun 29, 2020.
  1. Eggshooterist
    Eggshooterist
    Erff
    Nice. Good to know.
    Ohio and MAF143 like this.
  2. Czed
    Czed
    Wv
    IMG_20240205_104436.jpg I rebuilt this 346xp about 10 year's ago
    Parts on order to rebuild it again.
    John D, Buttermilk, MAF143 and 2 others like this.
  3. Czed
    Czed
    Wv
    IMG_20240205_104537.jpg He bought the saw new after his stihl ms290 was stolen
    He's engraved every part of this saw
    It makes it look like a stolen saw now.
  4. ammoaddict
    ammoaddict
    Granite Falls, NC
    Well, I can't say he's wrong except for the way he treated such a nice saw.
    Buttermilk likes this.
  5. Eggshooterist
    Eggshooterist
    Erff
    Nephew had this dropped off at his shop today. Customer says..."It has a new chain but its still making noise and sparking. I think the clutch is slipping."
  6. Ohio
    Not Ohio
    That’s a good way to Jack up a new chain. Lolz
    Eggshooterist likes this.
  7. ammoaddict
    ammoaddict
    Granite Falls, NC
    Dang.
  8. Eggshooterist
    Eggshooterist
    Erff
    Some people have no clue
    John D likes this.
  9. ammoaddict
    ammoaddict
    Granite Falls, NC
    Exactly, how could you put a new chain on and not see that.
    Eric Wanderweg and Eggshooterist like this.
  10. Eggshooterist
    Eggshooterist
    Erff
    How can I put this.....
    Some people shouldn't own motorized equipment.
    John D and ammoaddict like this.
  11. Eggshooterist
    Eggshooterist
    Erff
    Turning two into one.
    IMG_20240221_150026060~2.jpg IMG_20240221_150029592~2.jpg IMG_20240221_150105965~2.jpg IMG_20240221_150117502~2.jpg
    John D, MAF143, Ron T and 1 other person like this.
  12. Eggshooterist
    Eggshooterist
    Erff
    FYI, Homelite 150's have a left hand thread, one way bearing on the flywheel side that the starter uses to spin the engine over. I know its left handed after snapping the crankshaft off with my 1400 ft pound Milwaukee impact trying to get it off. Lol. At least its the sloppy crank, not the good one.
  13. Eggshooterist
    Eggshooterist
    Erff
    I converted an old Firestone shingle / carpenter hatchet into a little Bushcraft hatchet. 13" overall length. I have another I'm doing with a different shape. IMG_20240221_145805662~2.jpg
    JD Guy, Eric Wanderweg, Ron T and 6 others like this.
  14. Czed
    Czed
    Wv
    Screenshot_2024-03-08-11-38-38-253.jpg Any of you stihl boy's need a 28" bar
    33.91 shipped after discounts
  15. Czed
    Czed
    Wv
    31.79 shipped for a 24" .58 bar and chain
  16. Czed
    Czed
    Wv
    IMG_20240320_164034.jpg I rebuilt my friends 346xp for the 3rd time IMG_20240320_162028.jpg
    New cylinder kit
    He wanted a big bore this time i cleaned the ports up on it and it runs strong.
    Seals,lines,carb kit etc.
    I cleaned up the original cylinder for next time.
    John D and Deererainman like this.
  17. Czed
    Czed
    Wv
    He's running a 260 i rebuilt last summer.
    John D, MAF143 and ammoaddict like this.
  18. Eggshooterist
    Eggshooterist
    Erff
    Has anyone used one of those chips, that eliminate points on a saw, only to have it not run correctly after? This is the second time on two different saws. The first was an old Remington and it would barely run at all. I reinstalled the points and it ran fine. Recently I put a new Oregon chip in my Homelite super EZ, when going through it, and now it pops like the timing is to far advanced. I filed the flywheel key to re-tard the timing some but it still does it unless under heavy load. I'll file some more to see if it improves. If not, I'm going to put the points back in and set the flywheel back to factory with another key to see if it goes away. Carb is rebuilt. New gaskets and seals in the saw. Tuning doesn't get rid of it. It even pops out the exhaust on deacceleration.
  19. Eggshooterist
    Eggshooterist
    Erff
    I have an update. I removed the flywheel and key. I re-tarded the timing the full with of the key. The popping is gone but its sluggish to spool up and falls on its face in the cut. So my initial hypothesis is correct, I just need to find its sweet spot. More later. IMG_20240325_131437314~2.jpg
    MAF143 likes this.
  20. Eggshooterist
    Eggshooterist
    Erff
    Another update on this pita...
    So, firstly, my assumption that it was to far advanced was from previous saws that I had advanced the timing on and it made them act exactly like this saw was, hence me re-tarding the timing to adress this. Well, I thought I
    re-tarded it but, unbeknownst to me as of the last update, the crankshaft spun inside when tightening and it actually advanced the timing considerably. So I took the key, filed about 40% of it away and assembled it advanced. Bingo. Pulls well and no more breaking up. Good throttle response.
    MAF143, ammoaddict and MNWood like this.
