What's on your bench now?
Discussion in 'Chainsaws and Power Equipment' started by Czed, Jun 29, 2020.
  1. Ron T
    Ron T
    Northeast Ohio....Bowdil
    Not yet...
  2. Lehman
    Lehman
    Minnesota
    You’ll like it they’re nice saws
  3. Eggshooterist
    Eggshooterist
    Erff
    So is the Ace Hardware sticker on top what indicates its a rental?
    metalcuttr, Ron T and ammoaddict like this.
  4. Ron T
    Ron T
    s-l960.jpg I presume it's a rental....could be wrong?
    Eggshooterist and Eric Wanderweg like this.
  5. Eggshooterist
    Eggshooterist
    Erff
    No clue. I don't think any ace hardware stores in our area rent equipment.
    metalcuttr likes this.
  6. ammoaddict
    ammoaddict
    Granite Falls, NC
    I don't think so, some dealers put stickers on the saws they sell. The dealer put a sticker on my polesaw when I bought it.
    metalcuttr and Eggshooterist like this.
  7. Ron T
    Ron T
    Yeah....I took a trip to their website. I am doubtful now that it was a rental.
  8. Ron T
    Ron T
    Now I'm eyeballing it again.
  9. Czed
    Czed
    Wv
    Got in a g395 and a g288 from the flash sale it took 35 day's IMG_20240124_144247.jpg IMG_20240124_144158.jpg
    Full of fuel and oil with a 24" bar and chain.
    Buttermilk and MAF143 like this.
  10. Czed
    Czed
    Wv
    Fuel/oil and another 24" versacut bar
  11. Czed
    Czed
    Wv
    I took the clutches off both to grease the bearings IMG_20240124_132828.jpg IMG_20240124_124635.jpg
    Both clutches had some kind of loctite on them
    Both saws started and tuned easily
    The g288 has a far too short pull rope I'll swap it out.
    Buttermilk, MAF143 and Sandhillbilly like this.
  12. Scotty Overkill
    I've just about finished up another 044 red lever, swapped out a 12mm crank and piston into the 10mm case, slant fin KS cylinder, trying out a Duke's pop-up piston in it and see what happens. Took the squish down to .019, still gotta build the muffler and make a set of spikes for it.
    Also got another 200T tore down for seals, rings, and some minor stuff.....
  13. Eggshooterist
    Eggshooterist
    Erff
  14. Ohio
    Not Ohio
    I messaged him telling him I was interested. It’s not in the best shape but for 325 shipped that’s about inline. It also takes the same bar mount as the ms251 and I have a ton of chains already.
  15. Czed
    Czed
    Wv
    I've bought a couple of saws from him
    No issues at all
    I got more than i expected
    He really takes care of his stuff.
  16. Ohio
    Not Ohio
    Thanks! I’m not on OPE much and don’t really know many names so that helps.
    MAF143, Eggshooterist and metalcuttr like this.
  17. Eggshooterist
    Eggshooterist
    Erff
    Is the 251 3/8 picco or 325?
    Ohio and MAF143 like this.
  18. Ohio
    Not Ohio
    .325 is what I run. 68 dl on an 18” bar on the 241 from what I can find on the inter web. It’s an oddball most other .325 are 72 dl. Both the 251 and 241 have the one bar nut and the round air filter.
    Eggshooterist and MAF143 like this.
  19. Eggshooterist
    Eggshooterist
    Erff
    Stock 241 runs 3/8 Picco chain on a 3005 mount bar. You will need to run and ms250 .325 drum on the 241 to use your bars and chains from the 251. The 251 drum might fit as well but I'm not sure.
    MAF143 and Ohio like this.
  20. Ohio
    Not Ohio
    I will rob the drum and rim off the 251 and switch the 251 back to the spur. I looked at the order for the drum and rim I ordered for the 251 and it also says it’ll fit the 241.
    MAF143 and Eggshooterist like this.
