What's on your bench now?
Discussion in 'Chainsaws and Power Equipment' started by Czed, Jun 29, 2020.
  1. Eric Wanderweg
    I was checking out the ones that West Coast Saws sells and although they’re nice, I wasn’t too impressed with the machine work. I figured I could make something a little better. If I was to make a bunch of them I’d have to really sit down and refine the process, optimize my programs and get the cutting time down. It could be done though.
    Chvymn99, Sandhillbilly and buzz-saw like this.
  2. Chud
    Chud
    NC
    Agreed that looks a lot nicer than the WC cover.
    Chvymn99 and Eric Wanderweg like this.
  3. buzz-saw
    buzz-saw
    Ct.
    OK , I'll go first.
    Put me on the waiting list for preorders.
  4. buZZsaw BRAD
    Nice piece of work there. How does it compare weight wise with OEM?
    Eric Wanderweg likes this.
  5. Eric Wanderweg
    OEM cover is 0.32 pounds, my custom cover is at 0.8 pounds right now. I'm going to change a couple things in the design to lighten it up some more.
  6. Czed
    Czed
    Wv
    I got my order of 6 oem Husqvarna momentary stop switches
    I bought a couple of d009 .50 20" bar's
    They were only 14.00 each shipped
    Nice bar's they are laminate bar's but seem well made.
    That's a neat speed square for marking around boards or posts
    It's in metric but i like it.
  7. Czed
    Czed
    Wv
    One thing that has failed often on my china 372 saws are the start/stop switches
    That's one thing they cannot get right
    They have been reliable otherwise
    No real issues.
    Just a occasional fuel or pulse line needed replaced.
  8. Eric Wanderweg
    buZZsaw BRAD, Ron T and Eggshooterist like this.
  9. Eggshooterist
    Eggshooterist
    Erff
    Ron T and Eric Wanderweg like this.
  10. Eric Wanderweg
    It’s pig rich right now, with basically open exhaust. I just have the part of the muffler on that bolts to the cylinder. Have to finish getting a diverter on the other half of the muffler, then get the bar/chain on, air filter etc then I can attempt tuning it. I really hope the crank seals are still good. Oiler is pumping plenty of bar oil.
    buZZsaw BRAD and Eggshooterist like this.
  11. Eric Wanderweg
    I traded labor with a coworker who boogered this deflector onto the muffler for me. My original deflector concept wasn’t going to work, as the plastic for the saw was right up close to the muffler. This’ll send the exhaust forward, similar to the factory setup (which the holes for it are still going to be utilized). It’ll do for now. In hindsight I think this will be better than a gaping hole anyway.
    E55C295A-586E-4190-BA80-D8A2B58B6355.jpeg 2FC86AF3-6D45-48E6-9A88-641FC016E50B.jpeg
  12. Skier76
    Skier76
    CT and SoVT
    Nice work on that cover Eric!
  13. Eric Wanderweg
    She’s a beaut, Clark
    buZZsaw BRAD, Chud, Skier76 and 2 others like this.
  14. Eric Wanderweg
    The basket case 028 I got last month is finally together and runs well. What a difference in having the muffler on it versus yesterday with it wide open. I did a rough tuning in the dark just now but I want to tweak it in closer, cutting some actual wood later this week. It idles great and revs right up. Since I wasn’t really chasing my tail trying to tune it, I’m cautiously optimistic that the crank seals are good. My custom aluminum cover needs a little tweaking in a couple spots to fit this particular saw. For now that’s on my XS 029 super. No biggie. Looking forward to putting this saw in wood soon!
    What I did:
    New used OEM cylinder, lightly honed and mildly ported
    New piston, rings, wrist pin and bearing
    Modded muffler
    New bar/chain
    New chain brake lever
    New fuel line/filter
    B875836F-5FB8-4603-B4ED-D51E5E85894B.jpeg 1C179DAE-E91B-435D-A96B-4A20DCDC0827.jpeg 13A2C018-1294-4A8E-98DE-763238B460FA.jpeg 462901AC-4D74-4C87-B390-C5825E04C07B.jpeg 8B1B76FF-5EC5-44E8-AFAF-62E1DAFE9F6A.jpeg
    Chvymn99, Skier76, MNWood and 4 others like this.
  15. Eggshooterist
    Eggshooterist
    Erff
    Nice job bud.
  16. Eric Wanderweg
    Thanks :handshake:
    I forgot how much fun this can be. Every blip of the throttle is just… satisfaction :D
    Chvymn99 and Eggshooterist like this.
  17. buZZsaw BRAD
    Nice work Eric! :yes: We'll have to GTG with 028's and cut somewhere. Cant recall the last time mine cut wood. Its been a while.
    Dumb question: Could you have easily put an 028s top end in there? I assume its the same "chassis"?
    Eggshooterist and Eric Wanderweg like this.
  18. Eric Wanderweg
    Excellent question and you’re absolutely right. I could have gone that route and had an 028 super which is a 46mm bore compared to the 44mm I have now. Hindsight I probably should have, but I just didn’t for whatever reason. At the time I was kinda tunnel visioned on getting it going, not really thinking bigger scope. I plan on going bigger with that Husqvarna 61 I have when it comes time to freshen the top end. A newer 272 cylinder is a direct bolt on for those saws.
  19. buZZsaw BRAD
    Does you 029 have the 039 top end or just ported ?
    Eggshooterist likes this.
  20. Eric Wanderweg
    That’s got the full treatment: 039 top end, ported, with a muffler mod.
    Eggshooterist and buZZsaw BRAD like this.
