What's on your bench now?
Discussion in 'Chainsaws and Power Equipment' started by Czed, Jun 29, 2020.
  1. Deererainman
    Deererainman
    Union City Ky
    I need to take my heat gun out in the woods next time. I'm curious what the exhaust temps are. I'm thinking a leaner tune would result in higher exhaust temps. Am I correct in that assumption?
    Eggshooterist likes this.
  2. Eric Wanderweg
    That's why I say *according to Google* :)
    900 sounded a bit high
    I’ve got a deflector concept in the works but it might interfere with the bar or plastic on the saw. Have to mock it up tomorrow before committing to welding anything.
  3. Eggshooterist
    Eggshooterist
    Erff
    Yes. I use a heat gun when doing my oil testing. Just a smidge of adjustment can effect the cyclinder temp 20° under the loads my test units are under.
    Deererainman likes this.
  4. Eggshooterist
    Eggshooterist
    Erff
    Im not doubting the gas coming out the cylinder is 900 but I've never seen a saw muffler even near that hot with my temp gun.
    That's a nice looking deflector. Do you have thinner stock to make it from?
    Eric Wanderweg likes this.
  5. Eric Wanderweg
    Deererainman and Eggshooterist like this.
  6. Eric Wanderweg
    No, I don't have much extruded structural type steel at my disposal but I can mill it thinner to be more like the stamped sheet metal on the muffler. I imagine leaving it thick like that will retain a lot of heat.
  7. Eric Wanderweg
    More betterer? If it doesn’t work well I’m making a custom one anyway ;)
    430A87B9-7B38-4F95-B9E9-874C037A6669.jpeg E9AA2640-6EE9-435C-865C-A8ECF822EE6A.jpeg
    buZZsaw BRAD, Ron T and Eggshooterist like this.
  8. Eggshooterist
    Eggshooterist
    Erff
  9. Czed
    Czed
    Wv
    Got a g288 in IMG_20240102_150839.jpg IMG_20240102_150800.jpg IMG_20240102_151146.jpg
    I tore it down and checked everything no issues
    I greased the clutch bearing and swapped out the entirety too short pull rope.
    Starts,runs,oils great
    Solid saw every bit as strong as my oem 288s i have a few.
  10. Eric Wanderweg
    Yesterday my-new used OEM cylinder came in, and today my piston and rings arrived. It’s kind of hard to tell because somehow I was able to mimic the roughness of the original casting pretty closely using my oval shaped carbide burr, but I actually did widen the lower transfers quite a bit. Probably could’ve gone more but didn’t want to risk it, being my first time trying this. Unfortunately I don’t have a small angled rotary tool to get in there and widen the intake and exhaust ports where they meet the cylinder, so they’ll stay as they are. I’d rather not attempt it with the wrong tool and have my burr skip across the cylinder wall :hair: It’ll do for now. Between this and the muffler mod I’m hoping to get some modest gains over stock.
    1C4208AD-858D-499E-9736-DD0AACFEB4FB.jpeg 4C34623D-E3A0-4D63-A673-386A84135A35.jpeg
    buZZsaw BRAD, Chud and Eggshooterist like this.
  11. Eggshooterist
    Eggshooterist
    Erff
    Not sure how fat the grinder is you are working with but I grind from the outside in on the exhaust and intake port. With the right shaped diamond bit I can debur that way too.
  12. Eric Wanderweg
    I might be able to get away with that… but I’m not feeling especially brave today :) Kind of just want to see this thing up and running later this week.
  13. Eggshooterist
    Eggshooterist
    Erff
    That should reach but I get the baby steps. You can't put the metal back in.
  14. Eric Wanderweg
    I’m waiting on my wrist pin bearing to come in before I can start putting the 028 back together. In the meantime I needed a side cover for the saw so I reverse engineered the one off my 029 super. This is milled from 7075 aluminum so it’ll be pretty indestructible.
    F0F4836E-99B8-4186-BD32-B6BA9BFBABD8.jpeg 818B247F-9669-44DC-9B68-0FE39B010F4E.jpeg 0EAE80AF-D08D-4AB2-871D-9E842E0AF01D.jpeg
    Chvymn99, Czed, Skier76 and 10 others like this.
  15. Eggshooterist
    Eggshooterist
    Erff
    WOW. That looks outstanding. You are one heck of a machinest bud.
    Chvymn99, ammoaddict, Chud and 2 others like this.
  16. Eric Wanderweg
    Thanks but don’t look too closely. ;) I missed a retract, shattering a carbide end mill and one internal corner is pretty boogered up but I’m leaving it because it won’t effect the function. Still have to make the plastic insert the chain rides along.
    Chvymn99, buZZsaw BRAD, Chud and 2 others like this.
  17. Eric Wanderweg
    Did the test fit on my (dirty) extra sausage 029 super just now. Fits like a glove :thumbs: This is going to look sweet on the 028 when I get that back together.
    5F282CB4-3115-4B46-BB19-B6E200E1BE43.jpeg E3FFD6A3-32EE-4DAB-B9E2-71EDF8C322B1.jpeg
  18. buzz-saw
    buzz-saw
    Ct.
    Holy crap!!!!!!!!!!!:thumbs:
    That is beautiful.
  19. Eric Wanderweg
    Thanks Craig :handshake: The worst part was just getting it all modeled out in the CAM software. To get the dimensions I set it up in the Bridgeport and zeroed out on one of the bar stud holes. Then I put a 1/4” dowel pin in the spindle and went around “probing” a bunch of edges and recording the positions. At least now if I want to make another one, I have the solid model.
  20. buzz-saw
    buzz-saw
    Ct.
    I can relate as to what is involved. No doubt this was not your first rodeo.
    You should be making aftermarket parts and selling them. A part like that will sell itself.
    Heck I would buy one just to hang on the wall.
    Even a Husky guy would buy one.
