What's on your bench now?
Discussion in 'Chainsaws and Power Equipment' started by Czed, Jun 29, 2020.
  1. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    Just regular old fashioned auctions with a live auctioneer and a crowd of people raising their hand. They’re fun and mostly cheap entertainment.
    Screwloose, Czed, Ron T and 1 other person like this.
  2. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    Wrenched on a few today-
    Went through an 034super that’s been used a ton. Cleaned up the air filter and dialed it back in to 13000 after.
    Had an 029 in that stopped in wood. Piston was great so onto spark... plug connector (old aftermarket) was shot (cracked) and the spring connector didn’t stick to the plug. Unfortunately this series requires some tear down to replace. All is good now.
    Nixon, Screwloose and M2theB like this.
  3. M2theB
    M2theB
    Central Massachusetts
    it looks like someone was messing with someone!
    The reason it wouldn’t go through top dead center is the saw was sabotaged!
    Son lifted the cylinder and this is what we saw.
    someone had stuck a piece of gum through the spark plug hole!
    Stephiedoll, Mag Craft, Nixon and 3 others like this.
  4. Czed
    Czed
    Wv
    A guy i know wouldn't pick up his 455 rancher i had it for three year's
    So i pulled the plug and at bdc
    I filled it with grease from a grease gun.
    I put it in the back of his truck
    Recently
    He hasn't called yet.
    Nixon and M2theB like this.
  5. M2theB
    M2theB
    7ADDF285-27E7-4B4F-825A-4D9AC4B9C097.jpeg 5A620CEB-5315-4CE0-8274-FFC70C9F0333.jpeg
    Have this really nice Stihl 020AVP on the bench, except it has no spark. Looking at putting in an ignition module. Would be my first.
    Sandhillbilly and Czed like this.
  6. Czed
    Czed
    Wv
    I just gave one to a guy in Texas for his kids to learn on
    Still a lot of those saws around there.
    Good atv trail cleaning saws.
    M2theB likes this.
  7. Czed
    Czed
    Wv
    Tried the 94 272 with a hyway 272 popup out on storm damage IMG_20200828_192237.jpg Just on it's second tank but it's a strong running saw
    M2theB and Sandhillbilly like this.
  8. huskihl
    huskihl
    I’m willing to bet that over 50% of those saws ever made suffered the same fate
    M2theB likes this.
  9. Sandhillbilly
    Sandhillbilly
    A 345 is the first saw I ever bought. That thing has been ultra reliable and has cut more wood than it was probably ever designed to
    huskihl likes this.
  10. Sandhillbilly
    Sandhillbilly
    M2theB likes this.
  11. Czed
    Czed
    Wv
    Got a freebie 125l Husqvarna
    I ordered a 15.00 rebuild kit off Amazon
    And shoe stretches for my 13eeee
    Shoes that don't fit. IMG_20200918_143002.jpg IMG_20200918_142925.jpg The kit seems well made
    And stamped with the Husqvarna logo
    In several locations.
  12. M2theB
    M2theB
    stihl poking at the 020.
    Found the right electronic coil. Ditch the trigger and no need for a universal module mounted else where.
    Having trouble tuning it. Idles fine and transfers nice from idle through low but can’t get power at WOT.
    I did rebuild the carb as part of the rebuild. So I pulled it a part tonight.
    06E32875-C2EB-4CAE-8057-5D16C4B136F1.jpeg 8C7429D3-2360-42C6-899F-224D22801D49.jpeg
    Should have cleaned the tank and replaced the fuel filter and line as part of the build. There now.
  13. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    Yep haha. I clean/flush both the gas and oil tanks on all rebuilds and most saws that I work on. I usually see some junk in both that could’ve caused issues.
    I never trust a fuel filter and usually replace lines if they’re stiff or mushy.
    SKEETER McCLUSKEY and M2theB like this.
  14. M2theB
    M2theB
    That crud didn’t help, but I found what the real problem was.
    neither the aftermarket or the oem carb kit has the right under plate gasket.
    Below is the OEM gasket. Kit comes with two of these, but neither are right for this WA 1 G carb.
    Below is the old under plate gasket. Notice the hole at 5 o’clock, calling the needle valve noon
    Below is the OEM K10 gasket, no hole.
    Once I noticed that, I built it again, for the 12th time, with the old gasket with the hole.
    It’s a nice little saw!
    Rush Battle, BuckthornBonnie and Czed like this.
  15. Czed
    Czed
    Wv
    I built this 288 6 or 7 years ago it's
    Been used constantly to maintain
    40 acre's of timber.
    Just in for carb and fuel system work.
  16. Fifelaker
    Fifelaker
    Fife Lake Mi.
    I thot I saw a puddy tat, I did, I did saw a puddy tat.
    Stephiedoll likes this.
  17. M2theB
    M2theB
    F5092470-0D90-483F-AFB3-28D1F0BE01C3.jpeg Back to the 435
    Picked up a parts saw for a little more than the subject saw, so now it’s the subject. Runs and won’t idle. Except for some denting on the seals, everything looks almost new. Piston still has factory hatch marks
    Muffler modded now. Carb kit and seals ordered. Fuel line and primer test good.
    Sandhillbilly likes this.
  18. campinspecter
    campinspecter
    The 439 has been a bust. It has spent most of its time in the shop so far. We are now waiting for a new oiler pump.
    The two in one file holders that I really like!
    Woodwidow likes this.
  19. campinspecter
    campinspecter
    A few more toy's .
  20. J. Dirt
    J. Dirt
    I’m late to the party!!
    September.... 034super full on case split rebuild to 036 65C74950-DCC0-4BD2-96F9-CAFFB8210DF7.jpeg Currently....
    And 266xp case split ground up rebuild.
