What's on your bench now?
Discussion in 'Chainsaws and Power Equipment' started by Czed, Jun 29, 2020.
  1. Czed
    Czed
    Wv
    Help my nephew rebuild this freebie 400 honda foreman IMG_20231104_143332.jpg
    He didn't clean the oil pump or reservoir
    And oil line's
    He did change the oil and filter
    Lasted 2 hour's on this new pro x piston.
    Deererainman likes this.
  2. Eggshooterist
    Eggshooterist
    Erff
    Put new crank seals, crankcase O-ring, gaskets and carb kit in this old girl. Shes a snotty one.
    Deererainman and Eric Wanderweg like this.
  3. Eggshooterist
    Eggshooterist
    Erff
    This is the latest batch of garbage on my benches.
    Never heard of this OEM carb before.
  4. Eggshooterist
    Eggshooterist
    Erff
  5. Eggshooterist
    Eggshooterist
    Erff
    And the poulan pro 335 Predator limited edition. This one I like and it will be enhanced beyond the rebuild.
    Timbersport and RGrant like this.
  6. Mag Craft
    Mag Craft
    South East Wyoming
    Yep I have one of those that I dropped the cylinder on and bumped the compression up to about 180 psi. I also did some porting on the saw and advanced the timing.
    I use it for firewood cutting up in the mountains all the time. That was about 10 years ago. Still running good. 32-1 mix.
  7. Mag Craft
    Mag Craft
    South East Wyoming
    Here is the pic.
    M2theB, Timbersport, Ohio and 4 others like this.
  8. Eggshooterist
    Eggshooterist
    Erff
    I think I'll give it to my nephew as a surprise after I'm finished fixing / modding it. He only has an Echo cs-310 and an Efco mt3500.
    Mag Craft likes this.
  9. Eggshooterist
    Eggshooterist
    Erff
    Nice. They seem well built. I like the jeweling you put on the bar.
  10. Mag Craft
    Mag Craft
    South East Wyoming
    Wire brush and a drill press.
  11. Eggshooterist
    Eggshooterist
    Erff
    Clever. Looks pretty cool.
  12. Eggshooterist
    Eggshooterist
    Erff
    That will buff out....
    IMG_20231128_142832525~2.jpg IMG_20231128_142836717~2.jpg IMG_20231128_142825953~2.jpg IMG_20231128_142829001~2.jpg IMG_20231128_142904336~2.jpg
    Eric Wanderweg, Deererainman and Chud like this.
  13. Skier76
    Skier76
    CT and SoVT
    Yikes! What got in there? Any damage to the rings?
    Eggshooterist likes this.
  14. Eggshooterist
    Eggshooterist
    Erff
    Best I can tell it was overheated from dull chain or theres a really bad air leak somewhere I haven't found yet. Look at the fines packed in this thing...
    IMG_20231128_143202699~2.jpg IMG_20231128_143217885~2.jpg IMG_20231128_143228468~2.jpg
    Chud likes this.
  15. Eggshooterist
    Eggshooterist
    Erff
    Somehow, the cylinder survived without scoring. I have no idea how. I had to use acid to remove the aluminum transfer and an 80 grit strip in a split mandrill with oil to put some "texture" back in there for the new piston and ring. Those lines are just polished lines. No scoring that I can see or feel.
    IMG_20231128_143258758~2.jpg IMG_20231128_143304293~2.jpg IMG_20231128_143308993~2.jpg IMG_20231128_143314058~2.jpg
    Chud likes this.
  16. Deererainman
    Deererainman
    Union City Ky
    805 McCulloch. I think the cylinder will clean up. Need a 52 mm piston though.
  17. Eric Wanderweg
    I picked up this old 028 wood boss from a coworker who found it on the side of the road. It’s a bit of a basket case and needs an air filter, chain brake, side cover, bar and chain. The good news is it has decent compression and it does have spark. The carburetor looks brand new and it is stamped Stihl. I can work with this. I’ll pull the muffler to get a look at the piston before I get too far into it. With any luck I’ll be able to put a fresh ring in it and run it. Of course if I already have the cylinder off, what’s to stop me from cleaning up the ports a bit :whistle:
    734C16B5-6F52-410A-8D8B-8095D0DCB88B.jpeg 71608A95-DD94-418C-8A07-908D7C300E5F.jpeg
  18. Jeffrey Svoboda
    Jeffrey Svoboda
    Yeah.... might as well just clean up the casting imperfections. :rofl: :lol:
    Eggshooterist and Eric Wanderweg like this.
  19. Mag Craft
    Mag Craft
    South East Wyoming
    Looks like a fun project.
    Eric Wanderweg likes this.
  20. Eric Wanderweg
    Just a little routine maintenance on the “post apocalyptic” custom rear handle Echo CS370. It sat for 2-3 years and had a bit of a stumble coming off idle before revving up. I pulled the carb off for a good cleaning, and I'm going to get a new air filter and spark plug before getting it back together. For what it is this is a decent saw that has cut an untold mountain of wood since 2011 when I bought it.
