What's on your bench now?
Discussion in 'Chainsaws and Power Equipment' started by Czed, Jun 29, 2020.
  1. Smokinpiney
    Smokinpiney
    "South" Jersey
    I fiiiiinally got around to assembling the 365/72 today. The oem p&c showed up a while back with a broken ring and after arguing with the seller they issued me a refund and told me to keep it. I ordered a set of caber rings and slapped it together this morning.
  2. Czed
    Czed
    Wv
    My old Makita XDT13s just had the variable speed trigger great impacts but not really suited for engine work IMG_20230615_095633.jpg
    So I bought a couple of the XWT12s 3/8 impacts with adjustable tightening and loosening modes.
    They are only 50.00 on amazon for some reason
    I bought a 3/8 square to 1/4 hex adapter works perfectly for using bits IMG_20230617_093452.jpg IMG_20230617_103116.jpg
    I've been fixing a lot of lawnmowers lately
    RCBS, metalcuttr, Buttermilk and 4 others like this.
  3. Czed
    Czed
    Wv
    My 8 year old 99.00 harbor freight pump finally stopped working
    I actually bought two of these because I didn't know they would last
    Bit I used it as my only water source all these years
    Cost me .99 cents to fix it and I went ahead and put a new pressure switch on it.
  4. Smokinpiney
    Smokinpiney
    "South" Jersey
    The squish was really high on the 365/72 so I pulled the base gasket and gave it a thin coat of motoseal. Squish is .026 now and she's blowing 150psi. Also slapped on the ported muffler and she sounds much better now :dex::saw:.
  5. Eggshooterist
    Eggshooterist
    Erff
    Taking this old girl down to its last fastener and replacing all gaskets, O-rings and seals. Might get some internal performance work while I'm in there as well as an electronic ignition chip. These are my favorite old Homelite saws.
  6. buZZsaw BRAD
    Nice work. You should sell the 241 to me to make room in your fleet for it. :whistle: Havent BYB about it in a while. :rofl: :lol:
    Hows the arm recovering?
  7. Eggshooterist
    Eggshooterist
    Erff
    I sold the 241 to a neighbor. I was released by the doctor and psychical therapist a couple weeks ago.
    Chud, metalcuttr, Ron T and 2 others like this.
  8. buZZsaw BRAD
    :faint:
  9. Eggshooterist
    Eggshooterist
    Erff
    Thinning the herd.
    Mrxlh and buZZsaw BRAD like this.
  10. buZZsaw BRAD
    Thought maybe i had dibs...maybe, possibly. :tears:
    Good to hear your back to your former self. Any pain or discomfort?
    Mrxlh and Eggshooterist like this.
  11. Eggshooterist
    Eggshooterist
    Erff
    You can have dibz on a poulan fir senix trade
  12. Eggshooterist
    Eggshooterist
    Erff
    RCBS likes this.
  13. Eggshooterist
    Eggshooterist
    Erff
  14. Czed
    Czed
    Wv
    My local fire department was throwing this away IMG_20230924_170521.jpg IMG_20230924_170536.jpg
    The fuel line melted after setting 20+ year's and I don't have any McCullough engine parts
    So i modified a Husqvarna 288 carb diaphragm and a stihl ms290 fuel line to get it running I have new parts on order.
    I do have 3 McCullough 20" bar's and 5 new chains I was given.
    I haven't run one of these since 1984 or 1985 my neighbor had one.
  15. Czed
    Czed
    Wv
    My new fuel line and carb kit came in IMG_20231006_171943.jpg IMG_20231006_172745.jpg
    I put a new 20" bar and chain on it and tuned it in wood IMG_20231007_103011.jpg IMG_20231007_103128.jpg
  16. Czed
    Czed
    Wv
    Not liking this series at all almost new 600.00 saw with a fried clutch IMG_20231009_144945.jpg
    I replaced the clutch and tried it out
    That's a lot of weight for 3 1/2 or so pounds IMG_20231009_142929.jpg
    I weighed a few saws all full of fuel and oil the 460 and Mac have 20" laminate bar's the 266 a 24" solid bar IMG_20231009_143240_BURST002.jpg IMG_20231009_142851.jpg
    The Mac is stronger than the 460
    The 266 stomps them both in torque and power.
    RCBS likes this.
  17. Czed
    Czed
    Wv
    Working on a Honda 400 foreman the guy had a aftermarket big bore kit on it the wrist pin wore away and sounded like rod knock the oem cylinder is fine so I'm putting a new piston in it. IMG_20231009_162647.jpg IMG_20231009_163006.jpg
    I had to put a oil sending unit in my Chevy that's the second one in three year's IMG_20231009_170156.jpg IMG_20231009_164158.jpg
    RCBS and MAF143 like this.
  18. farminkarman
    farminkarman
    Neenah, WI
    Trying to get a 562xp finished up that has been on the back burner for too long. This is a Duke’s cylinder that I cut the squish band on and ported. 48EA2B3B-71B2-4F41-B827-C289901E63D6.jpeg
  19. MNWood
    MNWood
    Coon Rapids Minnesota
    Sorry no photos but I wanted to share my repair story. A few weeks ago my Husqvarna 450 (2014 model with 18" bar) stopped working. I figured out it had no spark. I also had recent noticed one of the carb mounting screws never really got tight. I purchased a new ignition module ( I call it a coil), spark plug and a carburetor mounting flange. Took it apart, installed the new parts and it started right up. Runs good now. In the time that I have owned it I have cut a lot of wood, dropped number of trees with it and sawed them up. It has been a good saw for what I use it for. Here is a not workbench photo at our son and daughter in-law's place where I used it last fall.
    RCBS and Chud like this.
  20. Czed
    Czed
    Wv
    It only had a 1/2 inch opening into the muffler so I cut that out IMG_20231031_150855.jpg
    And opened up the intake and exhaust
    It flows good now
    It's as strong as any homeowner 60s cc
    Saw like the 455/460 290/310
    It'll make a good firewood saw
    It's quite light for it's size
    I was blocking 18-20" hardwood all day with it.
