What's on your bench now?
Discussion in 'Chainsaws and Power Equipment' started by Czed, Jun 29, 2020.
  1. Czed
    Czed
    Wv
    I tried out the hipa full chisel chain
    After a couple of tanks it stretched a little
    Like Oregon does then did good
    Actually cuts very good for out of the box
    5.67 24" chain
    Eggshooterist and Ron T like this.
  2. Eggshooterist
    Eggshooterist
    Erff
    My brother in law has one. My 201 out cut it sude by side in the same 10-12" beech. After I muff modded it, pulled the limiters and tuned it its much better but still a 311. He prefers his 15 year old 310
    Czed likes this.
  3. Eggshooterist
    Eggshooterist
    Erff
    If I wear any out I guess I'll find out lol. I can't stand ANY screw in caps because they seem to tighten themselves in harder during use.
  4. Czed
    Czed
    Wv
    A secret squirrel sent me all the parts to finish it
    Nos 262 intake manifold,gaskets,air dam and a sticker IMG_20230502_144251.jpg
    I heat cycled it and tuned it in wood
    It's about a pound lighter than a 266xp
  5. Czed
    Czed
    Wv
    For this series you can get am carb,lines,fuel filter,gaskets,air filter and even a coil for 18.00 IMG_20230503_151028.jpg
    Buttermilk, Skier76, Ron T and 2 others like this.
  6. Eggshooterist
    Eggshooterist
    Erff
    Imma port one of them one day. Just because lol
    Czed likes this.
  7. Backwoods Fellin'
    Backwoods Fellin'
    Nashville TN
    Czed and Eggshooterist like this.
  8. Czed
    Czed
    Wv
    Fixed three pieces of junk today IMG_20230504_104651.jpg IMG_20230504_120644.jpg IMG_20230504_115926.jpg
    These Eklind Ball end driver's are handy I don't have to take the bar's and chains off to remove the muffler's IMG_20230504_122425.jpg
    What absolute garbage these homeowner Husqvarna's are
    The freebie 257/262 walked all over them
    The only good thing about these saws is the pull start handles.
    Smokinpiney, Sandhillbilly and Ron T like this.
  9. Czed
    Czed
    Wv
    Finally got this 272 finished new seals,carb kit,fuel line,piston kit
    Then the original carb wouldn't stay tuned
    So I bought a am carb and it tuned in great and held it's tune IMG_20230505_095022.jpg
    He painted that topcover for some reason.
  10. Eggshooterist
    Eggshooterist
    Erff
    I've ran a buddy's 445 before quite a bit. It seemed fine. I assume its the same caliber as the above saws. Had I not been exposed to pro saws I wouldn't have known it was junk.
    Haftacut and Czed like this.
  11. Czed
    Czed
    Wv
    What makes them junk to me personally
    And I have worked on dozens and dozens of them over the year's the smaller homeowner huskys also
    Is they are not saws you can leave setting around
    They are plagued by carb,intake leaks,primer bulb and fuel line issues
    And underpowered the 445 felt the strongest
    I'm running 1980s 2 series that occasionally might need a carb kit
    These modern Husqvarna's can't make it a couple year's
    My neighbor bought a new 440 last year he's had it to me 4 time's for clutch,chain brake and carb issues
    And he only runs canned fuel and takes care of his equipment he's not happy.
    Eggshooterist likes this.
  12. Czed
    Czed
    Wv
    I fixed the carb
    That was biggest pain to put those tubes in
    I had to have a friend help seat the tires IMG_20230507_141751.jpg IMG_20230507_142442.jpg
    The owner was happy with it.
    Smokinpiney, JD Guy, Skier76 and 2 others like this.
  13. Czed
    Czed
    Wv
    Out of a dozen saws I've been working on for a friend 5 were fried IMG_20230508_095738.jpg IMG_20230508_100119.jpg
    I'm rebuilding 2 ms290s I'll put a new piston in one and a aftermarket 390 kit in the other
    He gave me the 455 rancher I ordered a duke's popup piston for it I'll fix it and sell it
    I've already rebuilt and returned his 372 and 394
    Apparently he or his worker's don't like to mix fuel and oil.
  14. brenndatomu
    buZZsaw BRAD has a 4 stroke saw he'd sell...:whistle:
  15. Eggshooterist
    Eggshooterist
    Erff
    I thought saws were oil injected? Isn't that what the oil tank is for?
    :D
  16. buZZsaw BRAD
    Two of them NIB. :saw: :makeitrain"
    Ron T and brenndatomu like this.
  17. Eggshooterist
    Eggshooterist
    Erff
    $50 shipped
    buZZsaw BRAD and Ron T like this.
  18. Czed
    Czed
    Wv
    New fuel lines,filter and a new Killswitch
    The guy had a wire wrapped around the spark plug boot
    Whoever ran it got the pizz shocked out of them shutting it off.
    Ron T likes this.
  19. Czed
    Czed
    Wv
    Rebuilding a fried 290 into a 390
    Had to use a pipe wrench to get the rear bar stud out
    Usually two bar nuts tightened on it would remove it but not on this one IMG_20230602_104328.jpg
    Ron T and Eggshooterist like this.
  20. FarmerJ
    FarmerJ
    Minnesota
    Basically inherited dads old line trimmer. A Stihl FS45. Been around a day or four. The FS40 replaces it. Basically a different muffler is what I’m seeing different for a spark arrestor.
    Been sitting with gas in it since last time dad took it to the shop and said, “give it a once over and make it run.” Shop said, “we haven’t used those tickets in like 5-6 years.”
    Took the old carb apart and had to replace the primer bulb as it was broken. Cost me $4.30 just for the primer bulb. Still wouldn’t prime correctly much less run.
    replaced the carb and went all Veruca and went to the dealer for a new carburetor. New STIHL fuel line and carb were $55.
    Genuine Stihl Chinese parts here guys.
    Had I the patience to order from Amazon…. I’d rather support my local dealer though. He’s been very patient with me and gotten me things that’s taken some research on his part though.
    easy peasy to change the carb out.
    Best tool I’ve found for taking off the filter box on my trimmer and saws. The large side is the perfect fit and thickness for the nuts and the filter box clearance.
    thing runs like a dream and starts easily now.
    time to go to finish the yard work now.
