What's on your bench now?
Discussion in 'Chainsaws and Power Equipment' started by Czed, Jun 29, 2020.
  1. Czed
    Czed
    Wv
    Neat little kit I got off amazon
    M2theB, Ron T and Haftacut like this.
  2. Czed
    Czed
    Wv
    Rebuilt a 394 today I used a 395 hyway popup piston kit IMG_20230330_100527080_HDR.jpg IMG_20230330_104312711_HDR.jpg
    I used a red97 deflector and was tuning it in wood when the coil died
    I sold my last 394 last month so I had to order a coil.
    RCBS, Mrxlh, M2theB and 2 others like this.
  3. Eggshooterist
    Eggshooterist
    Erff
    Isn't that how it always goes.
    M2theB and Czed like this.
  4. Czed
    Czed
    Wv
    These are tough saws it surprised me
    It was running so strong then nothing.
    Eggshooterist likes this.
  5. Eggshooterist
    Eggshooterist
    Erff
    Have you had good luck with aftermarket coils? So far the only one I've purchased has worked flawlessly. There was no alternative to revive my freshly XS ported saw. Aftermarket it was.
    Sandhillbilly and Czed like this.
  6. Smokinpiney
    Smokinpiney
    "South" Jersey
    Replaced the fuel line and rebuilt the carb on this 330t. Man, changing that line that attaches to the carb through the handle is a Pita!
    RCBS, Mrxlh and Czed like this.
  7. The Wood Wolverine
    I tried a cheap chinese coil on mine when I was diagnosing a hot start issue. Took a lot of performance out of the saw and it only lasted a couple months. When I put an OEM one back in it felt like someone lightly ported it. I didn't realize just how bad it was until that moment.
    It was at that point that I vowed off cheap crap on my saws.
    Sandhillbilly, Chud and M2theB like this.
  8. Ron T
    Ron T
    Northeast Ohio....Bowdil
    Buddies dirty little saw. Have to fix the brake and give it the once over.
    Sandhillbilly, RCBS, Czed and 3 others like this.
  9. Czed
    Czed
    Wv
    About the china stuff
    In the 7 years since I bought 7 of those china 365/372 clones
    Nobody I'd talked too had tried them and I had a bunch of bars and parts laying around.
    Now keep in mind I went through them some with oem cylinders some with hyway popup kits some with 268 or 272 pistons in china cylinders
    most of them I ran a few years and gave out to my family
    There's no value in used china saws.
    Some of them are still their main firewood or storm cleanup saws
    In that time 1 coil has failed a couple of stop switches and oddly most of the chainbrake springs were too light.
    After a few impulse and fuel lines failed
    I replaced with echo line.
    I rebuilt the oem 372 on the left this morning and ran it in cutting trees
    Impressed with the plated duke's piston
    As far as power they were so close i couldn't say especially running a 20" on one and a 24" on the other.
    maybe when the rings seat the oem will pull ahead.
    Since I got that little tool set I've rebuilt a 288,372,394,272 and working on a 345
    The only thing lacking was a 3/16
    t handle for the 2 series a hemostat for lines and needle nose pliers for circlips.
    Sandhillbilly, Mrxlh, RCBS and 2 others like this.
  10. Czed
    Czed
    Wv
    I've never tried a china coil on the 394/395s
    But have used many on 346/350/365/371/372s they didn't seem to have any problem's keeping up with oem coils I have many with oem coils as well.
    Sandhillbilly and Eggshooterist like this.
  11. Eggshooterist
    Eggshooterist
    Erff
    The coil I bought was for my Dolmar built Makita DCS 401. They had problematic OEM coils and the upgraded coils are no longer available and used up replacing the originals. I found one coil that was supposed to be for it and it does fit perfectly and it runs stronger than with the problematic factory coil. It almost feels more advanced as it seems to kick a bit when starting now. Not bad but enough to notice. So far it has been good to go.
    Sandhillbilly likes this.
  12. Czed
    Czed
    Wv
    Many years ago I was given a new 5100
    Because the coils back then were
    Around 200.00 and there was a variety of coils for that series
    It probably just had one tank on it and the guy was mad it quit and the repair costs was in the hundreds.
    Dolmar was terrible about warranty work.
  13. Czed
    Czed
    Wv
    I was given this 288 yesterday
    Actually a low hour saw has fire good bottom end and the cylinder is pristine
    It's strange it was stripped down
    I think I have everything to rebuild it.
  14. Eggshooterist
    Eggshooterist
    Erff
    I paid $70 for a Partsrun brand coil. I do have a nice Dolmar 100, that I ported, with the same style OEM coil that I've thought about swapping to the XS saw as they supposedly didn't have issues. Changing coils on a Dolmar isn't as simple affair as other saws. The wires are buried under the flywheel and the pullstart is behind the flywheel.
    Czed likes this.
  15. M2theB
    M2theB
    Central Massachusetts
    From the second slowest build ever, 357XP got a new piston this afternoon.
  16. Czed
    Czed
    Wv
    It's a strong saw I dug out my brother's 288 lite he gave me 20 year's ago when he retired from logging
    I did some work to it it's a very strong 288 but not as strong as a 394/395
  17. Czed
    Czed
    Wv
    Started on a 345 put a carb kit and primer bulb in fuel lines tomorrow IMG_20230403_150704902_HDR.jpg
    Still has a great bore and compression
    But I need to swap out the spring clip on the intake
    I think a 372 or 390 clip will fit these
    The spring clips are known to leak.
  18. The Wood Wolverine
    Yep they do. I have 2 in my spares box. :yes:
  19. Eggshooterist
    Eggshooterist
    Erff
    This is the future 25:1 peanut oil mix test unit to be ran at Denny's GTG. I know errbody is jelly but you can't have it.
    IMG_20230404_102230356~2.jpg IMG_20230404_100935794~2.jpg IMG_20230404_100813776~2.jpg IMG_20230404_100919528~2.jpg
    Czed, FarmerJ, M2theB and 1 other person like this.
  20. Czed
    Czed
    Wv
    Finished the 345 today IMG_20230404_134827941_HDR.jpg IMG_20230404_135403673_HDR.jpg
    Somebody set my test wood on fire at my neighbors place.
    Ron T, Nixon, M2theB and 2 others like this.
