What's on your bench now?
Discussion in 'Chainsaws and Power Equipment' started by Czed, Jun 29, 2020.
  1. Chud
    Chud
    NC
    M2theB and SKEETER McCLUSKEY like this.
  2. Eggshooterist
    Eggshooterist
    Erff
    I think it might be a limiting strap to protect the antivibe from over travel.
    Chud, M2theB and Mag Craft like this.
  3. buzz-saw
    buzz-saw
    Ct.
    Being a Husky they put that there in order to keep the pieces from falling on the ground when it breaks.:rofl: :lol:
    Sorry ; couldn't help myself.
    J. Dirt, M2theB and Eggshooterist like this.
  4. Czed
    Czed
    Wv
    Neighbor dropped off this nice 288
    He'd had it at a couple of shops
    And they couldn't fix it
    He also brought me this 272 IMG_20230318_153248544_HDR.jpg IMG_20230318_153201550.jpg
    It just needs a piston kit and carb kit,fuel line etc.
    He gave me this 257 it's in good shape with great compression I'll fix it after the other 2 are done.
    M2theB, Deererainman, J. Dirt and 4 others like this.
  5. Czed
    Czed
    Wv
    The Husqvarna dealer or the other shop he had it at left the carb and ignition module loose and stole or lost his air filter IMG_20230320_131638827_HDR.jpg IMG_20230320_144230991_HDR.jpg IMG_20230320_150302836_HDR.jpg
    I replaced the crank seals and oil pump
    O ring
    It runs strong returned it today
    He was very surprised
    I don't think he ever got to run it
    He bought it non running.
  6. Czed
    Czed
    Wv
    I took a look at the 257 what felt like good compression was a mud daubers nest
    IMG_20230320_123532821_HDR.jpg IMG_20230320_125516794_HDR.jpg IMG_20230320_125505867_HDR (1).jpg
    Going to convert it to a 262
    M2theB, Jeffrey Svoboda, RCBS and 4 others like this.
  7. Czed
    Czed
    Wv
    The air horn and air dam were so brittle they crumble I had to file the side of the cylinder so the flywheel would clear
    It runs strong with great compression I was tuning it in wood it needs seals
    I'll change them tomorrow.
  8. Czed
    Czed
    Wv
    I did the seals today but still need a 262 intake manifold
    I thought I had one but I don't IMG_20230323_112623173_HDR.jpg IMG_20230323_120312903_HDR.jpg IMG_20230323_120119140_HDR.jpg
    If anyone does seals on these
    Put a little gasket maker on the oring and fasteners
    I use motoseal but whatever your flavor.
  9. Czed
    Czed
    Wv
    Put rings and seals and a carb kit in a nice 260 IMG_20230323_153725111_HDR.jpg IMG_20230323_152438966_HDR.jpg IMG_20230323_184729512.jpg
  10. M2theB
    M2theB
    Central Massachusetts
    you do nice job on the body clean up
    What is that you used to get over shoulder so the seal didn’t roll?
    I like the window on pasta boxes. Real thin.
    Bin putzin with this one for almost 3 months.
  11. Czed
    Czed
    Wv
    I have a 3600 psi pressure washer
    It takes everything off and I don't care about sticker's
    1.00 foaming shower cleaner loosens most stuff before I pressure wash it.
    I usually use a pop can so slide the seals over the shoulder
    This was a motoseal package window.
  12. Czed
    Czed
    Wv
    Stopped at my niece's and got her saws ready
    Heavy rains yesterday brought a lot of tree's down and very high winds today
    I carry this saw box in the truck usually when I visit there's something to work on IMG_20230325_121956037_HDR.jpg
    I had too many saws setting around year's ago and I gave her and her husband a 028 wood boss and 028 super
    A jonsereds 920 her husband actually used to run logging for a friend that passed away
    And a chusky 372 I built
    He likes the 372 the best.
  13. Czed
    Czed
    Wv
    Rebuilt my neighbors 272 he wanted a budget build so I threw a 11.00
    Raisman piston kit on it
    I rebuilt the carb and new fuel line IMG_20230326_193703520.jpg IMG_20230326_192522931.jpg
    I heat cycled today
    tomorrow I'll tune it in wood
    That's the original oem top cover it faded weird.
  14. Czed
    Czed
    Wv
    Stopped at my friends he loaded 11 saws for me to fix IMG_20230326_112911211_HDR.jpg IMG_20230326_164007703_HDR.jpg
    He needs this 395 for a tree job
    After I pressure washed it I've got a new piston kit,seals and carb kit on order.
    savemoney, JD Guy, M2theB and 3 others like this.
  15. Jeffrey Svoboda
    Jeffrey Svoboda
    savemoney and Czed like this.
  16. buzz-saw
    buzz-saw
    Ct.
    BRAD's little 201 sits on my bench now. Slight damage from a tree. Needs a new top handle and some air filter assembly parts.
    Got to repay some of the favors he has done for me.
  17. The Wood Wolverine
    395's don't have that solid resin intake block. Maybe he just replaced the recoil cover?
  18. Czed
    Czed
    Wv
    Yep it's a 394 I typed wrong
    savemoney likes this.
  19. Czed
    Czed
    Wv
    Only 2 pro saws 394 and 372 the rest are homeowner crap.
    savemoney and Jeffrey Svoboda like this.
  20. Czed
    Czed
    Wv
