What's on your bench now?
Discussion in 'Chainsaws and Power Equipment' started by Czed, Jun 29, 2020.
  1. Ohio
    Not Ohio
    The final drives on my deere 4100 tractor have been leaking fluid and I can no longer ignore it. I tore it all apart and went to the deere stealership for the parts. When all is said and done all of the seals and bearings for both only cost $167. They gave me a exploded diagram.
    I completed the first one today, it took me most of the afternoon. My pinion gear bearing was giving me a heck of a time. I was not going to go to the parts store for a puller or any other tools. I heated the whole assembly up with the propane weed torch after the map gas didn't cut it. Heat it and beat it. Pretty red neck but it worked.
    I just need to do the other side tomorrow and pick up some gear oil.
    0801201508_Film2.jpg 0801201426_Film2.jpg 0801201226b_Film2.jpg 0801201226a_Film2-1.jpg 0801201226_Film2.jpg
    M2theB and Czed like this.
  2. Czed
    Czed
    Wv
    I've got a freebie 18hp craftsman riding mower
    It's 20 year's old
    I've had it 4 year's 20200803_182111.jpg first failure
    Uses a bit of oil but the often hated champion plug held up for many year's.
  3. Czed
    Czed
    Wv
    That a job and in this heat lately it had to be miserable.
    M2theB and Ohio like this.
  4. Czed
    Czed
    Wv
    I bought this bench for mom in the early 90s
  5. Ohio
    Not Ohio
    I'd rather do it in the heat than the cold. Hopefully i won't have to to it again for another 20 years. I can only imagine what it would have cost at the dealership.
    Screwloose, M2theB and Czed like this.
  6. Czed
    Czed
    Wv
    20200804_180618.jpg Turned out good
    Doing another one tommorow
  7. Ron T
    Ron T
    Northeast Ohio....Bowdil
    Looks great. I have one in similar shape. This might just be my motivator.
  8. Nixon
    Nixon
    West Sunbury,Pa .
    714951B3-B6D8-48C1-AF77-8ED6842ADD17.jpeg F1410C45-FE1F-4DEC-9C57-C1A35B96DAE0.jpeg 52BE8D93-D687-43CE-B7F8-BD3E707C4DD5.jpeg 14C9C49B-BE42-4C4E-A248-32EBC0ECA251.jpeg A McCulloch 10-10S is currently what I’m working on . It doesn’t look to have a ton of hours . But it looks like it wasn’t maintained judging by how some of the parts look . It’s got a roached piston . The cylinder cleaned up completely. The crank seal on the PTO side is basically gone ,and The carb needles ( H&L) were set at less than 3/4 turns out ,which seems a bit lean to me . So, that’s the likely cause of death . I’ll P&V test it on assembly . Any how , I had to order a wrist pin removal tool as the piston doesn’t use circlips . So, I’m kinda on hold pending parts . Hopefully I can find OEM rings ,and piston for it . Time will tell .
  9. Czed
    Czed
    Wv
    My nephew gave me his big jobsite security box
    I'm going to paint it
    And hopefully get 12 husky 70cc and 88cc saws in it
    That's all the saws I'll ever need. 20200811_193320_HDR.jpg had my first 2 series failure a recoil
    Messed up on a 266
  10. Nixon
    Nixon
    West Sunbury,Pa .
    What do you think let loose in there ? Love the pics of your helper ...
    Stephiedoll, Screwloose and Czed like this.
  11. Czed
    Czed
    Wv
    Nothing was broken a coil of the spring popped over the recoil assembly
    I rewound it tight it's fixed.
    Probably the high compression caused an issue it's over 200+
    no base gasket 268 hyway popup
    Several guy's couldn't start it
    You have to really want it. 20200812_174923.jpg Putting a farmertec 038 magnum tank on today
    Seems well made
    Haven't had a 365/372 china tank leak yet
    The guy said you won't want to give the saw back when your finished
    He's dead wrong the 038 is my least favorite stihl ever.
  12. M2theB
    M2theB
    Central Massachusetts
    Holy Moley
    237E6273-F5D9-44E3-AF5C-3A6EA0E91832.jpeg 978E68FF-1931-4300-91F1-1954A887B206.jpeg AF4C2882-DB22-4B6B-AA44-EBF708CB604E.jpeg
    Banging together this 345, left and looks to be straight gassed, with this 340 that somehow had this oil tank burn thru.
    I’ve come across bubbled and blackened oil tank decks, but never burn through.
  13. Ron T
    Ron T
    Screwloose and M2theB like this.
  14. Czed
    Czed
    Wv
    Seen several burned through or nearly
    Tree service saws
    No maintenance loose mufflers on a couple of them.
  15. Czed
    Czed
    Wv
    Putting a zoo city saws ported 268 closed port
    on this 97 268 20200819_103949.jpg and got my kodiak 400 7.00 carb kit in from Taiwan 20200819_114639.jpg
  16. Czed
    Czed
    Wv
    Finished a 272 with a hyway popup
    Runs strong with a 24" in hardwood
    Need to muff mod it. 20200820_184901.jpg 20200820_182302.jpg 20200820_181738.jpg 20200820_155450_HDR.jpg I capture the recoil with a hemostat and swap ropes
    Fast and easy.
  17. M2theB
    M2theB
    First saw build for one of my boys.
    Ran pretty ok out of the gate.
    Realized the tensioner was bungled only as we were mounting the bar
    Lipstick and rouge...we’ll get to it.
    I wanted to see him start it.
    Screwloose and Sandhillbilly like this.
  18. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    289173F0-7B04-48BD-B9DA-403E59A7FE3D.jpeg This is the farthest I’ve ever torn down a saw. Also the dirtiest saw I have ever touched. Basically paid $1 for it at an auction. Piston looks good and has some compression (didn’t check it before I tore it apart) and has spark. I hope it’ll run.
    Planning on this being the saw my 12 year old granddaughter learns with this season
    Nixon, Czed, Screwloose and 2 others like this.
  19. M2theB
    M2theB
    wish I could find the thread on that 346
    That was a DIRTY saw!
    Screwloose likes this.
  20. M2theB
    M2theB
    Where are these auctions you are going to Sandhillbilly ? Are these local part swaps or something on line?
    I grabbed this 435 this morning at a yard sale. Kinda seized. Offered $10 and with a handful of hand tools, was out the door for $20 all in.
    piston looks good but the cylinder is dry. Spark plug dry as a bone.
    Sprayed in some blaster where ever I could and was able get it to turn with a spanner on the clutch. But it won’t go through TDC. Like it his a negative squish. We’ll pull apart to see what’s happening. Doesn’t sound good.
    0D62B753-DA96-426D-A557-B19C5AE6BFF1.jpeg EF8CCC47-CACF-4FE8-94AE-5E81086DF5F3.jpeg
    Nixon, Screwloose and Sandhillbilly like this.
