What's on your bench now?
Discussion in 'Chainsaws and Power Equipment' started by Czed, Jun 29, 2020.
  1. Scotty Overkill
    This will be #6 in my 020T/MS200T collection.....lmao....
  2. Warner
    Warner
    She’s been sitting a few years. There is more snow coming… C8F9EBDF-C49E-4142-9A38-D99F361AA56E.jpeg
  3. Scotty Overkill
    Just tore into this lil' basket case in hopes of making something special, she's rough around the edges but the guts are near perfect and very hard to find nowadays.....what is she?
    M2theB, huskihl, blacksmith and 2 others like this.
  4. Lehman
    Lehman
    Minnesota
    M2theB, blacksmith, J. Dirt and 2 others like this.
  5. Scotty Overkill
    Yes sir. And the internals are near-mint. I've got some homegrown plans for this one (Hawg-modded), we built one for blacksmith out of a slant fin red-lever 10mm saw I sold him that turned into quite the little monster. So much so that I tried to talk him into selling it back to me, to no avail....lol
    So I had to look and find one to build for myself (thanks to david young and a few other great guys), now to assess exactly what parts I still need to get it back to snuff. She's not gonna be a shelf queen, this will be a user, but still "present" well. I've got a real nice OEM tank/handle assy, brake flag, clutch cover, flywheel, plastics and wrap, gotta get the other secret ingredients next.
    I'll post up some build pics and descriptions when I get everything together to build it.
    M2theB, J. Dirt, huskihl and 3 others like this.
  6. blacksmith
    blacksmith
    central Pa
    Yes it is a VERY good running saw. It even impressed huskihl.....
  7. J. Dirt
    J. Dirt
    It was on the bench I promise!!!
    4E0B24D4-5899-4E7D-9AFA-278870236179.png C4300472-A18E-47CD-9B4B-B655346490F4.jpeg B74C7769-CC42-414A-A404-EE6026D75625.jpeg
    Finished putting this old Craftsman/Poulan 3400 together today. It was in major need of some muffler work. I can’t believe these saws even run the way the muffler is built. There’s a couple tiny holes in the back of the can that blow back to a plate and then around the top of the can through a slit. Not to mention the internal baffle and screen, but we took care of that.
  8. Lehman
    Lehman
    Minnesota
    Might end up having to put a coil in it, I fixed a sky diver 562 once and the coil made it a month or so before it quit. Either that one didn’t like the shock or it was a coincidence.
    M2theB likes this.
  9. Lehman
    Lehman
    Minnesota
    CC3CDF08-B03B-42B4-94C8-310D21B867F0.jpeg BB12B161-0D14-4415-881E-A12761D774D1.jpeg 417FD9B5-CDD6-4B2C-90B2-00BADD42300C.jpeg
    passed the pressure and vac tests fixed all the bad parts with good used ones minus a new drum bearing. Also changed the brake band out because it was discolored from the heat. Opened up the factory cover plus added a 193t deflector to the can & opened the baffles up.
    Scotty Overkill, M2theB and Chud like this.
  10. Lehman
    Lehman
    Minnesota
    15963A22-2C76-41CE-96EA-43A61DEBCED8.jpeg 2981DAD8-3653-4EDE-8286-03F2FE15AAC8.jpeg B6BB3CC3-8CD4-4E91-A6E3-ED4B62A5B1E1.jpeg 99177F2D-161D-4DC7-AB1F-F7EEE5A954FB.jpeg
    got a real nice few years old 372xp xt, lost a screw and punched a hole in the case. Thought about welding it so I talked to Shaun carr and he told me it would warp and I was kinda afraid it would too. So on the fence what to do, weld it and try to skim cut the case cylinder surface flat, buy new oem case half “most likely option” or try a set of aftermarket cases with good oem bearings. I haven’t decided if I’m keeping or flipping it but I have a hard time selling something with aftermarket parts even if it’s just cases.
  11. Eggshooterist
    Eggshooterist
    Erff
    A screw fall off a Stihl into that saw because I've read the Husqvarnas don't loose screws....
    M2theB, Deererainman and Mrxlh like this.
  12. Eggshooterist
    Eggshooterist
    Erff
    And stuff.
  13. Mrxlh
    Mrxlh
    Dat Boot
    Lehman, I’d still weld it if you have access to a milling machine. Bolt a junk jug on it, preheat it and weld it. Then put it in the oven on 350 and cool it slowly. If it warps at all it will be minimal, and then just deck it like MattyO does.
  14. Lehman
    Lehman
    Minnesota
    I’ll maybe give it a go and if it doesn’t work out well I can buy a case half things a real nice saw otherwise and low hours I’d bet. The welding rod will cost almost as much as a case half I bet, used to find it on eBay and none listed now.
  15. Lehman
    Lehman
    Minnesota
    Bought this one too but haven’t looked close enough to see what’s wrong but it will be parts if nothing else
  16. Mrxlh
    Mrxlh
    Dat Boot
    Shawn did a nice video on YouTube repairing 2 different case halves, AZ92A is the rods he uses. I have a junk set (ethanol or water damage) 266 cases I want to practice on.
  17. Lehman
    Lehman
    Minnesota
    Well it’s either weld it or wait for a case set to show up because it’s 400$ for a new set of cases sold only as a set
  18. Eggshooterist
    Eggshooterist
    Erff
  19. Czed
    Czed
    Wv
    I've run many gallons of fuel through this coarse thread 1986 266 since stumpshot ported it in 2018 IMG_20230125_160948295.jpg
    I let this guy wearing the steel toed crocs run it and he was the end for the rubber av mounts he got stuck several times and tried to rip it out.
  20. J. Dirt
    J. Dirt
    The Stumpmaster has my 372 in his hands as we speak! Can’t wait to see what kind of magic he can work on it!
