What's on your bench now?
Discussion in 'Chainsaws and Power Equipment' started by Czed, Jun 29, 2020.
  1. Chud
    Chud
    NC
    Was it the oem plug? What manufacturer? I’ve only encountered one loose plug on a chainsaw and only checked cuz it wasn’t running right.
    M2theB likes this.
  2. brenndatomu
    Just commenting on your post, wasn't trying to point anything out...but I will now. There should be 2 electrodes, you were missing one.
    Ohio and M2theB like this.
  3. M2theB
    M2theB
    Central Massachusetts
    I stand corrected. Thank you.
    Ohio and brenndatomu like this.
  4. MuddyPaw
    MuddyPaw
    North Central Ohio
    This mess of an Echo 750 that is getting new seals and fuel lines. Any one have suggestions of a gasket maker for the case halves that also serve as fuel and oil reservoirs? I've used motoseal for cylinders before but will it hold up sealing a fuel tank? The paper gasket is NLA and looks like a nightmare to try and cut.
  5. brenndatomu
  6. Eggshooterist
    Eggshooterist
    Erff
    Porters use motoseal and yamabond for base gasket deletes without issues.
  7. brenndatomu
    Yeah it works great for that...its that gas tank detail that I'm not sure about...probably be fine, but I'd wait for one of these guys who has actually done it.
  8. Czed
    Czed
    Wv
    I've bought over 30 of these new style am Husqvarna pull handles
    They don't hurt my arthritic hands starting high Compression ported saws. IMG_20220808_195854470_HDR.jpg
    It took 4 years but I finally managed to tear all the rubber mounts
    Johnmm on ope cuts down 262/288 spring mounts by 2 coils and runs them on his jonsereds husky 2 series equivalents
    I'm going to try it
    But the runner mounts don't bother me.
    M2theB likes this.
  9. The Wood Wolverine
    What brand plug?
    M2theB likes this.
  10. M2theB
    M2theB
    NGK CMR 6H
  11. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    Yup and it's called a ground strap just like you said...
    Jeffrey Svoboda and M2theB like this.
  12. brenndatomu
    Your model T might have had a "ground strap"...modern engines use plugs with side electrodes...look it up, you will not find a plug manufacturer reference a "ground strap" on a plug.
    Straps are what you got beat with when you brought home yet another F from school. ;)
  13. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    Omg get a life...
  14. Eggshooterist
    Eggshooterist
    Erff
    Looks like you are both right.....
    farminkarman and brenndatomu like this.
  15. brenndatomu
    Right back atcha Skeet...you were the one that felt the need to comment/bring it up again.
  16. brenndatomu
    Nope, they call it an electrode there too...just like I did in my original comment...which apparently was the secret pass word to pandoras box. :picard:
  17. Eggshooterist
    Eggshooterist
    Erff
    Side electrode, you
    Ground strap, Skeeter
    ground electrode, ngk....
    Both ya have half of the nomenclature correct lol.
  18. M2theB
    M2theB
    I think what’s interesting is the dissection above they call the the threads the corrugated ribs and explains why.
    It’s a similar concept to bushing design on high and extra high voltage transformers. A resistor is built through the geometry.
    In this loose plug you can see where the heat and the discharge was before it all Chat the bed
    brenndatomu likes this.
  19. brenndatomu
    Maybe...was that illustration right from NGK? Cuz the one I posted was...and it said "side electrode" just like Honda teaches in tech school...not that I'm not totally over rolling around in the weeds with y'all over this...you can call it a lightning rod/strap/thingy for all I care. :handshake:
    Eggshooterist likes this.
  20. Eggshooterist
    Eggshooterist
    Erff
    To me its the flat thingy that the center thingy sends the blue to.
    I looked up anatomy of a spark plug and the few I perused said it was the ground electrode. That said, it matters not to me. I knew what you meant and what skeeter meant.
