What's on your bench now?
Discussion in 'Chainsaws and Power Equipment' started by Czed, Jun 29, 2020.
  1. Chud
    Chud
    NC
    Is there some symbolism happening there, or just out of beer?
    M2theB likes this.
  2. huskihl
    huskihl
    I think it means the Red Sox have zippers on their bottoms…:whistle::D
    Chud and M2theB like this.
  3. M2theB
    M2theB
    Central Massachusetts
    Can’t think of better time to hide in the garage to get this running than in middle of a heat wave.
    Ran, or wouldn’t run, last time I tried. 5+ years ago.
    Ron T and Eggshooterist like this.
  4. Chud
    Chud
    NC
    Are you gonna do some ice fishin?
    Ron T, Eggshooterist and M2theB like this.
  5. M2theB
    M2theB
    watching the weather…..
  6. Eggshooterist
    Eggshooterist
    Erff
    Is that a tecumseh on top?
    M2theB likes this.
  7. M2theB
    M2theB
    it is.
    Have any experience with this ?
    Has a Tecumseh branded carb but I’m thinking it’s something another line.
    Looking for a new kit and what might be an equivalent item
    Eggshooterist likes this.
  8. buzz-saw
    buzz-saw
    Ct.
    BR600 blower on my bench.
    Bad fuel line and what looks like a crank seal starting to go. Parts on order from my local dealer.
    Eight years old and never even looked at the spark plug. Going to give a special treat and install a new plug while I am at it and give it the recommended valve adjustment.
    After eight years I guess this might be considered routine maintenance.
  9. Eggshooterist
    Eggshooterist
    Erff
    A fair amount. I had an old Scotts mini tiller given to me with that same engine. Or one very similar anyway. It really lacked power so I ended up trimming the governor vain on mine and changing out a spring so it would rev higher. That worked well for a couple years till the trans stripped out. It then became my first oil test victim.
    Mrxlh and M2theB like this.
  10. Smokinpiney
    Smokinpiney
    "South" Jersey
    I started out this afternoon getting into an 031av that I've had laying around then i realized it had no spark and more than likely points issues. So i threw that back on the shelf for another day and started on a 365 special dad picked up at an auction for dirt cheap a while back. It had almost no compression so I went ahead pulled the jug. Ooof! Looks like a perfect candidate for a 372 top end :D.
    Czed, M2theB, Ohio and 4 others like this.
  11. Eggshooterist
    Eggshooterist
    Erff
    Something going on right here.....
  12. The Wood Wolverine
    That sucks. I love these top ends after proper port work is done.
    M2theB and Smokinpiney like this.
  13. Smokinpiney
    Smokinpiney
    "South" Jersey
    Haha just a little nick. She'll be fineeeee ;)
  14. Eggshooterist
    Eggshooterist
    Erff
    Make sure you use the original rings too. Lol
    Ohio and Smokinpiney like this.
  15. Smokinpiney
    Smokinpiney
    "South" Jersey
    Ooo good idea! Haha
  16. M2theB
    M2theB
    ring is in backwards
    That’ll do that
  17. Mrxlh
    Mrxlh
    Dat Boot
    I thought the 268 I picked up recently had an an air leak. Finally found the air leak after pressure testing the the saw, never looked at the carb until yesterday…
    4F70C6B9-DA53-41FA-8AAD-62DDCC349019.jpeg 3FDA0137-749C-4238-BA7C-224505780258.jpeg
    Czed, M2theB and Chud like this.
  18. M2theB
    M2theB
    where is the air leak?
    Chud likes this.
  19. Mrxlh
    Mrxlh
    Dat Boot
    The carburetor is fretted on both sealing faces, it evidently was ran for quite a while loose. The strange part is the intake skirt is spotless, hard to believe not than many fines went through it, so it had to be a pretty minor leak.
  20. Mrxlh
    Mrxlh
    Dat Boot
    BEF98894-720C-4238-A671-3F70D18F3EBA.jpeg FF064FED-A8AE-4D89-9023-BEC00407871E.jpeg
    Chud likes this.
