What's on your bench now?
Discussion in 'Chainsaws and Power Equipment' started by Czed, Jun 29, 2020.
  1. LordOfTheFlies
    LordOfTheFlies
    NY
    Still have 10 more 372xps to figure out what's wrong with them. 4 backpack leaf blowers, an 028 I bought to restore for a neighbor (needs new spur sprocket, inner plate shield, chain catch, new bar and chain, new air filter, new plug) , and an 029 I'm keeping for myself that I haven't looked at hard yet.
  2. Czed
    Czed
    Wv
    Serviced these stihls for a friend
    A 290 and 310
    I put a new .325 sprocket and chain on the 290
    And 3/8 on the 310 and new bar and chain.
    He bought me one of these for my trouble
    Handy little saw
    I ordered another for my friend after he tried it for a utv saw.
  3. Czed
    Czed
    Wv
    91 year old neighbor dropped off a 170
    Said it wouldn't run IMG_20220329_173756418_HDR.jpg IMG_20220329_174700084_HDR.jpg
    He'd put bar oil in the gas tank
    Easy fix I dropped it off on his atv.
    Screwloose, M2theB, Horkn and 3 others like this.
  4. J. Dirt
    J. Dirt
    Screwloose and Horkn like this.
  5. Czed
    Czed
    Wv
    A 575/576 fullwrap is easy to fit to a 266/268/272 IMG_20220520_100404196_HDR.jpg IMG_20220520_103853562_HDR.jpg IMG_20220520_105035879_HDR.jpg
    The 365/372 wraps are easy to fit also but you have to drill a new bottom fastener hole. IMG_20220520_190514382.jpg
    You just have to bend the down tube towards the saw
    And grind off some of it's thickness
    So the clutch cover will fit over the bar.
    All existing fastener holes line up great
    I had to cut a piece off a am 272 top cover to fix my broken 266 cover.
    M2theB and Sandhillbilly like this.
  6. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    That’s some good info right there
    Czed likes this.
  7. Czed
    Czed
    Wv
    I don't have fullwraps on all my saws
    of course just a few of my falling saws
    this is my heavily used
    This is before I ground the thickness of the down tube down
    For clutch cover clearance.
    Some kid wanted 200.00 for a beat up oem 266 fullwrap
    that's crazy.
    I have a few oem wraps
    But I actually prefer these oem 365/272 575/576
    30/40.00 wraps.
    Mag Craft and M2theB like this.
  8. M2theB
    M2theB
    Central Massachusetts
    1F9008FD-7623-4704-ADFE-C68D528A7E18.jpeg D3CCDC65-9974-4718-AC2E-7FD0ED32AECE.jpeg 5C2714B0-6E6C-402E-99F9-31F6A0D1976E.jpeg 7EC27503-C6C9-4711-8027-06518D0496B8.jpeg A7C30066-7409-4381-BFF7-CBE3293B7367.jpeg 7C839AD2-10BB-4DFC-A6D9-1B71CFD007C0.jpeg AC3876E9-0F14-42D1-9F91-9FCF3A66D2DD.jpeg
    350
    New seals, intake and clamp.
    New to us p/c. With some grinding under the transfer caps
  9. Mag Craft
    Mag Craft
    South East Wyoming
    M2theB what kind of sealer are you using.
  10. corncob
    corncob
    Somewhere in Lower Michigan
    No pictures but, presently on my bench (reloading) are another 1000 .223 cases being prepped for reloading. Never have enough, I say.
    JD Guy and M2theB like this.
  11. M2theB
    M2theB
  12. corncob
    corncob
    Far as sealer goes, I've gotten away from the box store stuff and went to Kubota 3 bond sealer, it's good stuff but only available at a Kubota tractor dealer. That and Detroit Diesel Anaerobic sealer.
  13. M2theB
    M2theB
    7357F83B-007F-4EAB-8446-7B70705CB300.jpeg B7358916-FB7A-47E2-AFEF-3F4491B1D840.jpeg C0F7181F-608C-41A5-9DF3-BEC56FF2E52B.jpeg
    272XP
    Glad I checked the gasket.
  14. Mag Craft
    Mag Craft
    South East Wyoming
    Yep that is for sure. That would have could for another tear down.
    M2theB likes this.
  15. M2theB
    M2theB
    Except for the brake build, bolt it together.
    SKEETER McCLUSKEY, Mag Craft and Chud like this.
  16. M2theB
    M2theB
    Mostly off the bench.
    Been flicking around with the oiler.
    Finally found the suction side of the pump was packed with tank chit.
    Cleaned it up and it oils great.
    still need to move the brake to a new clutch cover and deal with a wonky pull start.
    Carb clean and kit
    New piston and ring
    Transfer removed from cylinder
    Plug wire
    Crank seals
    Clutch, drum and bearing
    Lots of cleaning.
    Got about $140 into it, including original purchase price
  17. Chud
    Chud
    NC
    Sounds like a solid 272 :yes:
    M2theB and SKEETER McCLUSKEY like this.
  18. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    you guys are living in the past....
    M2theB and Chud like this.
  19. Mag Craft
    Mag Craft
    South East Wyoming
    Yep and some of us like it that way.
  20. M2theB
    M2theB
