What's on your bench now?
Discussion in 'Chainsaws and Power Equipment' started by Czed, Jun 29, 2020.
  1. Eggshooterist
    Eggshooterist
    Erff
    100% correct on all the above. I have two saws currently that he ported and its looking like two more this year. I have a sickness lol.
    Chud, Eric VW and Scotty Overkill like this.
  2. Eggshooterist
    Eggshooterist
    Erff
    Are you the same Walt as the YouTube sensation afleetcommand?
    M2theB, Chud and Eric VW like this.
  3. Czed
    Czed
    Wv
    I worked on a 394 with a well used 18" bar on it
    I asked why
    He said it's to cut willow tree's on
    River and creek banks
    He has contracts to cut in city limits
    Made absolutely no sense to me
    Any 50/70cc saw would've done that job.
    M2theB, Eggshooterist and Eric VW like this.
  4. M2theB
    M2theB
    Central Massachusetts
    Got this Makita 6401 last summer for $20
    Ran nice but the case gasket was burnt out under the muffler, so it leaked oil anytime it wasn’t horizontal
    Splitting the case anyway so new bearings
    228659B8-EEFA-4210-ACE4-09CE75868F9F.jpeg 9B966D93-2B88-47BE-87E9-E8B57744060B.jpeg
    New case gasket and some motoseal
    New seals, FW
    New seal PTO side
    oiler back in
    Spark maker
    Done for the day at the brake.
  5. Eggshooterist
    Eggshooterist
    Erff
    That old girl has some mag rot. My Makita did as well from a previous owner leaving palm tree saw dust all packed in it. I sand blasted it all out, filled with JB weld, used my pencil grinder to smooth everything out then painted it. Its name is Rotten Raspberry because of it. Lol.
    IMG_20210803_143258136.jpg IMG_20210804_112351744~2.jpg IMG_20210805_145955703~2.jpg
    J. Dirt, Haftacut, Christoph and 5 others like this.
  6. M2theB
    M2theB
    That looks great!
    Eggshooterist and Chud like this.
  7. Eggshooterist
    Eggshooterist
    Erff
    Thank you. It was huskihl 's idea. I was just going to run it as a beater. Now its a kind of a ported GTG toy / camp fire wood cutter with a vintage Remington roller nose bar. It's pretty fun. IMG_20210814_161848026~2.jpg IMG_20211213_145248075~2.jpg IMG_20211213_145144919~2.jpg IMG_20211213_145155866~2.jpg
  8. M2theB
    M2theB
    Chud and Eggshooterist like this.
  9. Eggshooterist
    Eggshooterist
    Erff
    Yes sir. This is Kevin testing on it after his magic. Pretty impressive for a 39cc saw. Its converted to .325 x .050 now. Its running 3/8 lp Stihl PS3 chain in his vid.
    walt, Chud and M2theB like this.
  10. Ron T
    Ron T
    Northeast Ohio....Bowdil
    Buttoned up the oiler on the 034 super this morning. 20220117_093234.jpg ⁹
    M2theB and Eggshooterist like this.
  11. M2theB
    M2theB
    Still has some odds and ends to go.
    Other than a new fuel filter, and the stuff above, haven’t done anything to it.
    And some cleaning.
    Pretty good for a $20 saw.
  12. M2theB
    M2theB
    Not even sure how much is in here.
    I may get serious this time
    Ron T, Mag Craft, JB Sawman and 3 others like this.
  13. James Miller
    James Miller
    Hanover PA
    20220122_183453.jpg Hoping to get these two figured out soon.
  14. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    I just noticed what a fancy bench you have. Is that a repurposed item, or did you have it made specially for saw repairs?
  15. Eggshooterist
    Eggshooterist
    Erff
    I've had 8 of those 150 saws. They will make your hands numb lol. Pretty odd looking yet neat.
    James Miller likes this.
  16. M2theB
    M2theB
    salvage from a high school kitchen before demo
    That’s the winter bench in the cellar
    Sandhillbilly and Eggshooterist like this.
  17. Eggshooterist
    Eggshooterist
    Erff
    Its pretty sweet too.
    M2theB and Sandhillbilly like this.
  18. Sandhillbilly
    Sandhillbilly
    Yes it is
  19. Christoph
    Christoph
    SW Colorado
    20211109_173206.jpg 20211109_181211.jpg 20211201_182404.jpg 20211219_134136.jpg
    I have not had much to share in quite some time but sure have appreciated all the good content here on FHC. I've been looking for project and found this non running ms440 on craigslist. I'll try to take more photo's next time, but it had an ugly scored up piston and cylinder. The plastic sure is faded, but I'm ok with that. New meteor piston and cylinder, bearings, case gasket ,fuel lines and rubber parts. I've never split a case before, so it was a good learning project. I tried overhauling the carb, but it was not OEM, and I couldn't get it to idle, so i splurged on a new Stihl carb. So far so good with a tank of fuel through it.
  20. LordOfTheFlies
    LordOfTheFlies
    NY
    From left to right:
    Husky 545 that won't run. Put in new carb gaskets.
    Ms201t that needs a broken clutch spring replaced (doing all 3)
    Echo cs-4600 leaking bar oil now and needs a new bar and chain. Already fixed the non start issue because fuel line was yanked off carb due to utter disintegration of anti-vibration buffers.
    372xp parts for sale that is leaking bar oil through the crank gase gasket right under the muffler. Need to split case and replace gasket and probably use some rtv.
    M2theB likes this.
