What y'all using for a coal rake ??
Discussion in 'Modern EPA Stoves and Fireplaces' started by HDRock, Jan 18, 2015.
  1. Mag Craft
    Mag Craft
    South East Wyoming
    Stainless Steel welding rod and some scrap sheet metal.
    Horkn, Sequoia, milleo and 1 other person like this.
  2. Babaganoosh
    Babaganoosh
    Jersey Shore
    Most of the homemade coal rakes look like medieval torture devices.
    Horkn, HDRock and milleo like this.
  3. HDRock
    Nice sifter:thumbs:
    Horkn and Mag Craft like this.
  4. freeburn
    freeburn
    Wis
    Is that a shovel shaped tool or spatula or a hybrid? I can't tell from the pic. Looks like it will do the job nicely.
    Horkn likes this.
  5. Mag Craft
    Mag Craft
    South East Wyoming
    It is shaped like a shovel so that I can scoop up the coals and sift out the ashes and then put the coals to the other side of the stove. It works good even though it looks odd. It is not a rake but I do not need one with this. I know everyone has their own way of handling their stove and what they like to use. I think they are all great and some good ideas.
    Horkn, milleo and HDRock like this.
  6. HDRock
    New people, whatcha got:)
    Horkn likes this.
  7. Kimberly
    Kimberly
    The Kangaroo State
    OK, I read this with interest because I don't have any rake of any kind. What I am interested in hearing is what you like and dislike about your particular rake. I will start searching for something I can use; repurpose, or make.
    Horkn likes this.
  8. chance04
    chance04
    Denton Md
    The only thing I don't like about mine is the length. I wear welding gloves so a shorter stick would suit me fine
    Sent from my SM-G900V using Tapatalk
    Horkn likes this.
  9. HDRock
    Whatcha got? :)
    Horkn likes this.
  10. Kimberly
    Kimberly
    The Kangaroo State
    This popped back up and I was thinking about this earlier; I must be uh, what's the word, .... anyway, I was thinking that I still don't have any sort of rake for coals. I use the shovel; and the shovel is actually a fireplace shovel, and the poker to sort of poke then around.
    Horkn and HDRock like this.
  11. yooperdave
    Does it do the job?
    Perfect!
    Horkn and Eric VW like this.
  12. HDRock
    You can cut slots in one of those cheap shovels and make a rake out of it.
    Or a steel rake you have out in the barn you can cut down to size.
  13. Kimberly
    Kimberly
    The Kangaroo State
    No, it doesn't; which is why I keep saying I need to get something proper. I like the ones I saw on here with the flat rake on one side and the tines on the opposite. I wish I could weld.
  14. Kimberly
    Kimberly
    The Kangaroo State
    I was going to look for something I could modify but the little grey cells let me down; I guess I need to put sticky notes on the windscreen.
  15. Kimberly
    Kimberly
    The Kangaroo State
    For a tine rake for raking coals forward, what should the spacings be on the tines? I know the idea is to rake the ash and coals back, then rake the coals forward for starting a new fire.
  16. saskwoodburner
    saskwoodburner
    I kid you guys (and gals) not, I use a spatula for my coal rake. My stove is shallow enough that this works. I put the spatula upside down and push the ashes back, while having a slight angle to it. The coals lift, and the ashes drop. Then I either pull them forward, or use a piece of wood to drag them forward.
    Loon, Horkn, colin.p and 2 others like this.
  17. bushpilot
    bushpilot
    Eastern Washington
    I am going to go for more of a hoe than a rake. I need to get something.
  18. yooperdave
    A shovel works wonders just as well as a piece of wood does.
    One word of caution with the piece of wood that I should mention now. Be sure to leave it in the stove after you move the coals with it instead of putting it back in the pile!
    Horkn, bushpilot, HDRock and 2 others like this.
  19. HDRock
    Why would you want a hoe?
    A hoe will bring everything forward ashes and all, a rake will bring the coals forward and leave the ashes.
    You can turn a rake upside down and it will act like a hoe
    Horkn, bushpilot and Eric VW like this.
  20. HDRock
    Eric VW
    Are you thinking what I'm thinking with this, hoe theme :rofl: :lol:
