What y'all using for a coal rake ??
Discussion in 'Modern EPA Stoves and Fireplaces' started by HDRock, Jan 18, 2015.
  1. HDRock
    Here is mine
    I bought this little True Temper 7-Tine Garden Rake Real Tools for Kids for 10 bucks ,over a year ago ,Cut the handle down, It works great, but, The handle was getting burnt up, So instead of waiting for it to get wasted Or replacing it with steel, I Figured I would find something to slip into it and shield it.
    Found some 1/32 wall Tubing in the shop, Don't remember where the heck it came from but, with a little sanding, it was a slip fit right on.
    I purposely Cut the tubing so I left 8 inches of wooden handle sticking out the other end so It doesn't get hot down there.
    It rakes the coals forward real nice but leaves the ashes .
    I know there is a lot of cool home made ones out there too .
    What are you using for this task ?
  2. jetjr
    jetjr
    Pa/Md line
    My son's have one of those that they broke the handle on. Thinking about welding a piece of pipe on for a handle. Never thought about using a piece of wood at the end to keep it cool.
  3. tuneighty
    tuneighty
    South Central PA
    Sorry for the stock photo, still on my first cup of coffee, too early to get a photo ...
    but this is $4.98 at Lowes... and works SUPERB!
    metalcuttr, HDRock and jeff_t like this.
  4. jeff_t
    jeff_t
    SE MI
    I had been using a shovel up until a couple of weeks ago, which now sucks.
    I made this out of what I had. It's 3/8" rebar and 3"x3"x1/4" angle (former lintel from my former fireplace), so it's way overbuilt and really heavy. I tried to trim up the angle as much as I could to reduce weight, but the blade on my chop saw is getting kinda small. But, work with what ya got. It works.
  5. KaptJaq
    KaptJaq
    Long Island, NY
    I stole my wife's hand cultivator that she used to use in her window boxes...
    KaptJaq
  6. JA600L
    JA600L
    Lancaster, Pa
    I made this last night out of a Redstone poker.
  7. Locust Post
    Made this one up before the burn season this year, it's worked out well.
    metalcuttr, Brad38, jeff_t and 3 others like this.
  8. milleo
    milleo
    Maine
    I just use a spatula that is slotted...:)
  9. BCB
    BCB
    Ocean Co, NJ
    I just use the shovel from the fireplace tool set.
  10. yooperdave
    Using a firepoker, here.
  11. HDRock
    That should last you a very long time
    metalcuttr, jeff_t and tuneighty like this.
  12. HDRock
    Have you had any trouble with the handle getting scorched?
    I was thinking that maybe if you wrapped a wooden handle with some High Temperature Aluminum Flue Tape, it may protect it enough to keep it from scorching
  13. HDRock
    I assume you are using welding gloves or something along with that :MM:
    metalcuttr likes this.
  14. HDRock
    Nice job :thumbs:
  15. HDRock
    Looks like that's up to the task :thumbs:
  16. JoeyD
    JoeyD
  17. tuneighty
    tuneighty
    South Central PA
    It is a metal handle, and it's held up pretty good so far. This is the first season with it, but I imagine it should last a few.
    HDRock and metalcuttr like this.
  18. KaptJaq
    KaptJaq
    Long Island, NY
    The handle is about 15" long. If it is only a few coals then I don't really need the gloves, a couple of quick strokes and all the coals are where I need them. If I reload early and there is a large bed of coals then the elbow length gloves go on for both raking and reloading...
    SWMBO always puts the gloves on, as much for splinters as heat. (Delicate hands)
    KaptJaq
  19. HDRock
    Oh , Sorry , It looked like it was wood handle
  20. HDRock
    Looks shorter in the pic
