What small saw should I buy?
Discussion in 'Chainsaws and Power Equipment' started by lukem, Nov 16, 2024.
  1. Kevin in Ohio
    Kevin in Ohio
    It gets the job done and most of what it would do on a clearing job is soft wood anyway. I use mine for everything. If I was a climber and wanted a high powered/fast cut through the 201 would be in order. For ground work, I can deal with it. It makes fast work of it by my standards. Dealing with brush and small stuff it becomes a safety thing for me. You can contol them and handle most any kickback situation. If you are getting tired near the end of the day because you have been handling a heavier than needed saw, that is when a bad situation can happen. I try to avoid that as I'll put in from sun up to to sundown days.
    I had a ton of honeysuckle on this project and decided to cut everything 1 inch and up for heat. It'll burn quick but at least I'll have my revenge on this nasty stuff. LOL
  2. Ronaldo
    Ronaldo
    How are you guys treating the stumps to kill the roots and prevent re growth?
  3. Eggshooterist
    Eggshooterist
    Erff
    I normally use my echo 2511P for probably 80% of my cutting. I definitely prefer lighter if it is capable enough for the task at hand.
  4. Kevin in Ohio
    Kevin in Ohio
    If I don't dig them out I use Tordon RTU(Ready To Use). I dribble it on a paint brush and hit the whole surface on little ones. Bigger stuff, just hit the outer 3 inches. Stuff works well. Available at most farm stores here.
  5. rusty ranger 44
    rusty ranger 44
    south central Pa
    Whatever it is you decide on, you want dealer support
  6. lukem
    I'm having a hard time getting past the "if it isn't magnesium it's trash" mindset after looking into these smaller saws.
    The one thing that really bothers me is the bar stud threaded into plastic. Am I overthinking this?
  7. Eggshooterist
    Eggshooterist
    Erff
    I recently stripped out a bar stud hole on a mag case, dolmar built makita. It had no flange on the stud.
    If the bar stud has a flush setting flange on the inside of the bar that the bar sets against, the clamping force is between that flange and the nut on the outside that holds the bar on. You can't pull the stud out from over tightening.
  8. Eggshooterist
    Eggshooterist
    Erff
    Stihl sells oversized bar studs for some of their plastic case saws in case they get torn out.
  9. brenndatomu
    Sounds like some people must tighten bars nuts on a 16" ms170 about the same as a 48" ms661..
  10. T.Jeff Veal
    For what it's worth...
    We have a MS180 with MM, my favorite little saw, good 2 handed control, changed to 14" bar...https://youtube.com/shorts/bOkTmWG1TpQ?si=Pa2SPjFUNgFi9ae_
    UNTIL...we got our Echo XS2511T...
    Kevin's port job is awesome on this little saw...it still has the 12" bar-3/8LP chain in it, we added a 3 point dog from WCS, really helps with the chatter. Good 2 hand control with it and easier to 1 hand if needed. Very reliable, better warranty and super light. We have cut brush with both of these saws...
  11. Eggshooterist
    Eggshooterist
    Erff
    I might know a guy...:rofl: :lol:
  12. Eggshooterist
    Eggshooterist
    Erff
    They are fun lil buggers for sure. I have an arborist friend that has 5 or 6 of them. Top and rear handle mix. All ported. He hasn't touched his MS201s in a few years now.
  13. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    I know you said it has to be gas powered… and I don’t know your reason for it. I’m not a big fan of the “electric movement” myself. But it sounds like a 18v Milwaukee hatchet would be perfect for the job. I’ve used mine a lot for clearing small saplings and it will cut anything with the bar fully buried.
    It truly is a impressive little tool
  14. blacktail
    blacktail
    PNW
    I was in a similar position a few years ago when I had a big cedar cut down and wanted a light saw for all the branches. After some reading here, I bought an MS180. I love it! If logs are 12" or less, I use the 180 instead if my 290.
  15. Eggshooterist
    Eggshooterist
    Erff
    I had a little 170 that I really liked too. Of course I had to fiddle with it as I always do. Lol
  16. buZZsaw BRAD
    Stihl 201 rear handle pro saw or its farm/ranch equal MS194 are light nimble saws. I own a 201 RH and really like it for limbing and bucking smalls. My recent purchase in June of a mint 241 has made it a shelf queen. Im running a 14" bar for weight reduction and fewer teeth to sharpen. My 2c for
    A top handle is a nice saw to have in the arsenal. You can one hand cut though not recommended for the inexperienced. I own a 201 & 194 top handle and like them both.
    Owning many saws I go through cycles of which ones I use.
  17. buZZsaw BRAD
    Yes the 201 are very pricey. I was fortunate to get both of mine cheap and both very low hours.
    Do you have any experience with a top handle?
  18. buZZsaw BRAD
    :bug: That has to be the biggest hoard of limb wood I've ever seen. VERY impressive Kevin! :salute:
  19. Kevin in Ohio
    Kevin in Ohio
    Furnace house got stacked in first and burning that this year. About 10 cord in there as it's over 8ft high.
    Last year neighbor let me cut up some of his dead ash so that fills up 2 1/4 bays in the shed. That was 64 cord and nice wood. I stacked it pretty. LOL
  20. lukem
    I've used them enough to know that's not what I want for this job. I don't think they are as safe as a rear handle either....easier to get lazy with your form.
    I think it's between the 194 and 2511 rear handle versions.
