What size files do I need for my chain?
Discussion in 'Chainsaws and Power Equipment' started by Kimberly, Jul 22, 2018.
  1. trail twister
    trail twister
    It could work that way. All in the angle you set and which way you move the chain.
    But I have mine set so the chain moves clock wise.
    :D Al
    Chaz and Hammy like this.
  2. Eric VW
    China Freight marketing and photographers probably paid as little as these tools cost.....
    :D
    But hey, a lot of their stuff just plain works....:yes:
    I still have their “Central Pneumatic” framing gun my dad bought in 2000.... shoots nails just fine, and it’s built plenty o’ things.
    :thumbs:
    dougand3, Chaz, Hammy and 3 others like this.
  3. trail twister
    trail twister
    Guess you have never seen one. You set the chains angle so you don't sharpen both sides with the same setting.
    :D Al
  4. stuckinthemuck
    stuckinthemuck
    That’s the only way to set it. The gage that sets the “depth” or amount you take off the cutter is flipped 180 degrees out in the picture... the chain should be running the other way with the cutters facing right and the depth gage should be against the back side of the cutter...
    As depicted, the depth gage would be against the front face of the cutter..
    Can’t tell if your second comment is serious or sarcastic...
    Chaz, Eric VW, Hammy and 1 other person like this.
  5. Eric VW
    Ima err on the side of sarcastico.....:yes:
  6. Kimberly
    Kimberly
    The Kangaroo State
    This did not show for me.
    Hammy likes this.
  7. Kimberly
    Kimberly
    The Kangaroo State
    I looked at the Timberline and that is not in my budget at the moment; however it did look like a high quality tool. Plus, it appeared you could use it in the field as well which is certainly a nice feature. Someone mentioned Harbour Freight and there is one located in Danville, Va. Plus I have a 20% off coupon that can be applied to the sharpener. Also looked on fleabay. Of course I could just hand file but if there is a decent sharpener that could make the job faster working in the shed then I am for that. All the chains; about five I think, are in need of a good sharpening.
    Hammy likes this.
  8. Kimberly
    Kimberly
    The Kangaroo State
    Yes, but compression brings in its own headaches as well.
    Hammy likes this.
  9. Grizzly Adam
    Grizzly Adam Guest
    I only use the middle-out compression by Pied Piper.
    Hammy and brenndatomu like this.
  10. HDRock
  11. brenndatomu
  12. HDRock
    Surprise , good dealer :)
    Chaz, Hammy and brenndatomu like this.
  13. dougand3
    dougand3
    North Alabama
    +1 on the $24 HF grinder. I used to use dremel with diamond stone but grinder is much faster and doesn't heat up as much.
    Hammy likes this.
  14. Kimberly
    Kimberly
    The Kangaroo State
    While some swear by the Miss Muppet algorithm for compression the Tweedledum compression offers much higher compression if you are looking for a lossless compression. The Tweedledee compression algorithm looked promising but it failed to scale.
  15. Hammy
    Hammy
    New Brunswick
    brenndatomu likes this.
  16. shaggy wood dump hoarder
    menomonie
    For the sake of not starting another thread I'm goin to ask the same question, I like the 2 in 1 still/pferd, but I want to have the correct size, I have still rapid super full chisel chain, on the raker is stamped, 3/8, 5 on the links that ride in the bar/on the sprockets, and Stihl c on the tooth/raker link.
    I've tried sharpening by hand before but never had any luck, but I keep hearing about these 2 in 1s being idiot proof. Usually just used a buddies Oregon sharpener but an sick of running there all the time. Any help is much appreciated!
    Chaz, brenndatomu and Hammy like this.
  17. Erik B
    Erik B
    Western Wisconsin
    I have only seen 3 of the Stihl 2 in 1 units. One is a standard 3/8th, one is a 3/8 picco, and the other is a .325. If you know what chain you are using, just buy the one that meets the specs of your chain. I don't know if they would work on skip chain.
  18. shaggy wood dump hoarder
    menomonie
    So I should go with the 3/8 standard right? Just a round file?
  19. Erik B
    Erik B
    Western Wisconsin
    They each come with the correct round file for the chain along with a flat file for the rakers. What chain are you using?
  20. Erik B
    Erik B
    Western Wisconsin
    I have the 3/8 regular for my 029 that I typically run semi-chisel chain and I use the 3/8p for my 192t. Each of those use a different size round file.
