What kind of splits do you run in your OWB?
Discussion in 'OWB's and Gasification Boilers' started by overactor, Nov 29, 2018.
What size splits do you prefer
  1. Smaller more normal sized 3-4" splits 16-18 inches long
    0 vote(s)
    0.0%
  2. Medium sized to larger splits 4-6" x 20-22 inches long
    52.9%
  3. A micture of small and larger splits
    35.3%
  4. Chuck in rounds
    11.8%
  1. amateur cutter
    Mine too, but he said first time problem. Gotta be a draft issue l would think?
    Farmchuck likes this.
  2. Farmchuck
    Farmchuck
    Nepa
    Can be both. Natural without a fan or induced with a fan. Think I’m gonna year the door apart tomorrow & make sure the solenoid is allowing the flapper on the draft to open all the way.
    amateur cutter likes this.
  3. Farmchuck
    Farmchuck
    Nepa
    Oh I didn’t see the small stuff just that gigantic piece of firewood. My dad would have called that “night wood”;)
    Joe Seaton and amateur cutter like this.
  4. Farmchuck
    Farmchuck
    Nepa
    That’s about all that’s left I’m thinking
  5. Farmchuck
    Farmchuck
    Nepa
    Appreciate yours guys helping me try to diagnose my problem.:yes:
  6. amateur cutter
    Yes, & make sure a piece of "something" isn't restricting the damper. Those things are pretty bullet proof, but I've seen chunks of coal get in them. Solenoid will still pull it open, just not far enough. Let us know.
  7. yooperdave
    I didn't know the 6048 had a draft fan on it.
    The first thing I thought of was that the solenoid linkage rod from the solenoid to the draft door was broken, but like I said, I didn't know there was a fan on it. Check the linkage rod anyway......and the operation of the solenoid. Back in the 90's, I had both of them fail at different times. Very easy fix.
  8. Farmchuck
    Farmchuck
    Nepa
    Will do. Thank you.:yes:
    yooperdave and amateur cutter like this.
  9. brenndatomu
    Don't forget...air in equals air out...better make sure the stack is not plugged too...
  10. yooperdave
    That exact thing happened to a OWB burner around here. Plugged the chimney up...never inspected or cleaned it! No, it wasn't the stove's fault in any shape, manner or form.........:picard:
  11. Creekin
    Creekin
    Manitoba
    Cousin's father in law last season, chimney plugged solid
    Easy to check
  12. Farmchuck
    Farmchuck
    Nepa
    Earlier in this post I mentioned that I did inspect chimney/pipe thoroughly & it was clean. However I do believe I may have found the problem this morning. As i mentioned last night I planned on taking the door apart to make sure the solenoid was opening all the way & that there were no physical obstructions preventing air flow. It all checked out fine, however when I took the face cover off the fan motor the screw was quite dirty. Do you think this could be restricting air flow enough to not fuel the fire? I do. As I mentioned earlier any time I opened the door the fire would pick up nicely. I have the fan drafting naturally. If it operates that was sufficiently I may leave the fan of entirely. I will post a picture of what I believe maybe the problem.
  13. Farmchuck
    Farmchuck
    Nepa
  14. Creekin
    Creekin
    Manitoba
    Definitely looks like a problem!
  15. amateur cutter
    Farmchuck, yooperdave and brenndatomu like this.
  16. lukem
  17. yooperdave
    Way too much obstruction there.
  18. JustWood
    JustWood Guest
    Yup, that's the problem.
    With really dry wood , natural draft will prolly work fine.
  19. brenndatomu
    Poor thing was breathing through a straw! :eek:
    Bet it works gooder now! :yes:
    Felter, Farmchuck and amateur cutter like this.
  20. Farmchuck
    Farmchuck
    Nepa
    Working loads better on natural draft than it was before!! I couldn’t even get up to the set water temperature before now no problem.:)
    overactor, Felter, Thor and 2 others like this.
