What is the right size tractor?
Discussion in 'Chainsaws and Power Equipment' started by SolarandWood, Nov 22, 2013.
  1. lukem
    That's pretty dang close to what he had...plus a hoe attachment. Very handy. If you go this route make sure the undercarriage and tracks are in good condition. Neither are fun or inexpensive to replace. EDIT: looks like MM made that point already.
    SolarandWood likes this.
  2. ironpony
    ironpony
    Mid Ohio
    No such thing..................
  3. SolarandWood
    SolarandWood
    Syracuse NY
    truth...choose your compromises well
  4. Oliver1655
    Oliver1655
    Central Missouri
    My Oliver (70hp) 1974 model with the loader was $7,200. I wouldn't be able to near as much loader/grapple work without the size/weight. It really save time to be able to just pickup the tree & move it to an open area to cut/load. Then just push the brush into a pile to burn or into a brush pile out of the way for the wild life. Load mill sized logs, no problem!
    SolarandWood and concretegrazer like this.
  5. SolarandWood
    SolarandWood
    Syracuse NY
    Given the right deal, I think a 110 might make sense. Since getting rid of the 410, I have figured out how much I used the commercial loader to do a whole bunch of things you shouldn't do with regular loaders:( Seems like most of the failures have come from backblading, an activity the 410 laughed at with the front wheels in the air. Set up with R1s and a winch, am I good in the woods with a 110?
    The 4x10s and 4x20s appear to be way more than what I want to spend. How about a 1070/990? I think I want one newer/low hour machine that requires less work to keep running rather than a bigger machine that can do things that arguably don't need to be done.
  6. MasterMech
    The problem is that if the 4x10s blow your budget, a 110 is out of the question. They still run north of 20k used in good cond. And if you plan on running a 110 with the backhoe removed, you need a LOT of counterweight to keep it stable. That loader is not easily removable like it is on the 4x10/20 series. But it will take Skid Steer attachments. :)
    A 970/990/1070 is a great tractor but of all the machines in this size range, they have the least capable loaders and no shuttle shift options either.
    If was shopping for you Solar, I would be showing you 45-4710's, 43-4720's, and a smattering of hand selected Kubotas in that range as well, but I'm very choosy when the paint turns orange.
    BTW: the 990 is still available new as the 4005 IIRC.
    http://m.deere.com/wps/dcom/en_US/p...ity_tractor/4005_compact_utility_tractor.page
